'05 trd rusty bed advice
Discussion in '1st Gen Tundras (2000-2006)' started by YarbianTheBarbarian, Jul 9, 2021.
  1. Jul 9, 2021 at 8:46 AM
    YarbianTheBarbarian
    YarbianTheBarbarian [OP] New Member
    Ian
    Bloomington, IN
    '05 SR5 TRD 4x4 double cab
    None yet!
    First off, I'm super stoked to find this forum. Looks like a great community y'all have here!
    I just bought this outwardly beautiful '05 trd with $150k.
    I'm very eager to get it sorted for a family adventure vehicle. I am primarily interested in mountain biking and canoeing road trips, so my goal is to get a nice cap for it.
    The truck is completely sound as is except for the rust around the bed and bed supports. The frame is in great condition amazingly, so I think it's worthwhile to invest in fixing the bed.
    I'm seeking advice on the best way to do this. Is there a way to rebuild/replace the bed pan so the existing good condition paneling and paint can be salvaged? Should I just look for a donor bed?
    I should mention, the body shop I went to thought it's still fine structurally for several years, so this doesn't need to be addressed immediately, but I'm sure looking for a donor bed (maybe even color matched ), will be a long process.
    Thanks y'all!
    Sirfive likes this.
  2. Jul 9, 2021 at 8:48 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    You might have overpaid a bit.
    Can you weld?
  3. Jul 9, 2021 at 8:49 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    lol, oops. 150k miles. I was typing on my phone so I could drop the photos in. :D
    I cannot weld, but I have a friend who can do *some* welding. Otherwise it'll be finding a shop that's capable.
    Sirfive likes this.
  4. Jul 9, 2021 at 8:51 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    You should update your location. A rusty bed is not usually where the worst rust is. Was the frame replaced?
  5. Jul 9, 2021 at 8:58 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Updated. The frame was not replaced, but it is somehow in much better condition than the bed.
  6. Jul 9, 2021 at 8:59 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Lookit upper rear shock mounts?
  7. Jul 9, 2021 at 9:02 AM
    terrward
    terrward New Member
    2004 DC SR5
    I would clean it up as best as you can with a wire brush and regularly apply some fluid film until you can source a color matched bed.
  8. Jul 9, 2021 at 9:02 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  9. Jul 9, 2021 at 9:08 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Do ppl normally upload full images or thumbnails?
    Driver's side
    Passenger
    Driver's side shock looks pretty bad.
    Sirfive likes this.
  10. Jul 9, 2021 at 9:11 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
  11. Jul 9, 2021 at 9:11 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Welcome to the forum! Read through my rebuild thread and see what I did. I manufactured those angles that the bed sits on while bolted to the frame. It would entail pulling the bed off and cutting out the rusty support angles and then fabricating/welding the new ones on. You could also buy some Z angle and just bolt it to the bed floor in place of the original angles that were attached at the factory.
  12. Jul 9, 2021 at 9:29 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Holy crap. Yes a replacement bed is probably more my speed! I wish I had your skill set and drive, that's amazing work!
    N84434[QUOTED] likes this.
  13. Jul 9, 2021 at 9:31 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    you dont get it by taking the easy route. If you replace the bed, fix the old one.
  14. Jul 9, 2021 at 9:41 AM
    terrward
    terrward New Member
    2004 DC SR5
    Your missing the bumpstops on your leaf springs too, replace those when you replace the rusted rear shocks.
  15. Jul 9, 2021 at 9:45 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Nice catch, I didn't notice that
  16. Jul 9, 2021 at 10:13 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Engine bay photo for reference on the rest of the truck's condition.
    Sirfive likes this.
  17. Jul 9, 2021 at 10:17 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    To each their own.
    if i was in your shoes:
    Winning8, Brewster, Glock 40 and 4 others like this.
  18. Jul 9, 2021 at 10:20 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Not exactly subtle, hahah! Do they have utility beds that specialize in hauling bikes, camping gear, and/or canoes?
  19. Jul 9, 2021 at 10:23 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Ladder rack and ratchet straps.
  20. Jul 9, 2021 at 11:30 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Thanks much..
    Like @Sirfive stated, keep the bed and practice, practice, practice...
  21. Jul 9, 2021 at 11:48 AM
    Something doesn't look right there. It almost looks like the frame has more rust than it's showing and that someone covered it with something. I'd start poking around with a screwdriver on that frame. Drop the spare tire and look there too.
  22. Jul 9, 2021 at 11:52 AM
    Run the VIN on your truck to see if it's a previous frame replacement. Wouldn't surprise me based on all of the delaminating rust you can see on other components. Surely you can find a replacement bed with a straight floor pan and frame section and have your bedsides and tailgate welded on. The replacement will be cheaper if there's existing panel damage. You won't need them if you use yours.
  23. Jul 9, 2021 at 12:00 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    The Tundra version of the lady at the end of the dark bar at 12:30am....
  24. Jul 9, 2021 at 12:12 PM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Do you mean on the Toyota site or is there someplace else it might be recorded? I'm not seeing anything that would indicate a frame replacement had been done.
  25. Jul 9, 2021 at 12:18 PM
    Any dealer should be able to take your VIN and tell you, or there's a website for recalls also. The alternative is that the frame has been coated and hasn't suffered like the rest of the parts. I just doubt that's the case. It's not important for your problem, but would be good to know.
  26. Jul 9, 2021 at 12:36 PM
    If you go to https://www.toyota.com/owners you will be able to create an account. You can then enter your VIN and pull up any work ever done on that truck at a Toyota dealer.
  27. Jul 9, 2021 at 12:54 PM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    It's apparently never been to a dealership. :monocle:
  28. Jul 9, 2021 at 1:01 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    That's possible....
  29. Jul 9, 2021 at 1:08 PM
    The only time we've seen the rest of the truck more rusty than the frame is if the frame was replaced. Since you can't find any records, that concerns me. It looks like someone may have painted over the frame rust and you can see areas where it's starting to flake off. I'd be digging around a bit further.
    Jack McCarthy likes this.
  30. Jul 9, 2021 at 1:09 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Someone here said something along the lines of ‘look with a hammer’
    BubbaW likes this.
