Will any Tacoma struts/shocks fit 1st generation Tundras?
Discussion in 'Suspension' started by Jacoma77, Jul 15, 2019.
  1. Jul 15, 2019 at 9:37 AM
    Jacoma77
    Jacoma77 [OP] New Member
    Jay
    I was curious.... Will the newer Tacoma’s struts/shocks fit the first generation Tundras? Thanks!
  2. May 11, 2020 at 3:29 PM
    FLJ23
    FLJ23 New Member
    2004 DC 4x4
    Stock for now
    did you find out if they do?
    I see 2nd and 3rd gen Tacoma shocks for real cheap
  3. May 17, 2020 at 3:23 PM
    MartyE12345
    MartyE12345 New Member
    Martin
    2000 Toyota Tundra SR5 Access Cab
    I was curious of this as well. Seeing a lot of people taking new Bilsteins of their Tacoma’s and are ending up for sale.
  4. May 17, 2020 at 4:02 PM
    KENNY
    KENNY New Member
    What about 4runners? Just pulled a set off a 2019 4R with 10k on em
  5. May 17, 2020 at 5:03 PM
    FLJ23
    FLJ23 New Member
    2004 DC 4x4
    Stock for now
    Anyone find out?
  6. May 18, 2020 at 1:59 PM
    MartyE12345
    Martin
    It sounds like a lot of people put Tundra coils on Tacoma’s and 4 runners for a lift. I think the shocks fit too but I think I saw somewhere that the top hat is different on the 3rd gen Tacoma and Tundra and you need to swap them.
    I see Tundra suspension components on Tacoma’s a good bit and there are a ton of threads on it. However, I have yet to see people putting Tacoma suspension components on a first gen Tundra. I feel like there has to be someone on this forum that has tried it (or at least knows the answer). The spring rates looks fairly comparable.
  7. Jul 10, 2020 at 5:29 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Resurecting an old thread.
    I was wondering the same thing. I see Gen-3 Tacoma take-offs for sale frequently. Would be great if they fit my Gen-1 Tundra.
    Anyone have an update?
  8. Jul 10, 2020 at 6:36 AM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    You could look up the part numbers for different manufacturers, and find out if they're the same number or not
    tvpierce likes this.
  9. Jul 10, 2020 at 7:57 AM
    tvpierce
    Maine
    I did check the part numbers and they don't match -- which is what I would have expected. And you can tell by looking at them that the design is slightly different but quite similar. It would be interesting if someone had access to some Tacoma shocks/spring take-offs when they were doing suspension work on their 1st Gen Tundra to do some fitting.
  10. Jul 10, 2020 at 8:31 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Will not work. Even if the top cap bolt pattern were the same, lower sleeve, reservoir mount... valving would be way off, and the compressed & extended lengths are also way off. Specs below:
    (05+ Tacoma) Fox 2.5 Coilover 0-3″ FOX-880-02-418 compressed: 17.59 extended: 22.48 <-- uses a 13x600lb spring
    (00-06 Tundra) Fox 2.5 Coilover 0-3″ FOX-880-02-420 compressed: 14.550 extended: 19.940 <-- uses a 16 x 650lb spring
  11. Jul 11, 2020 at 3:31 AM
    tvpierce
    Maine
    Thanks!
  12. Dec 16, 2020 at 5:24 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    What about rear shocks???
  13. Jul 8, 2021 at 4:00 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    I’m wondering the same thing I’m looking at some rear shocks off a 2019 Tundra, I’m wondering if they will fit on my 2004
  14. Jul 9, 2021 at 7:13 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    157594382_10158940435495275_673352894582_c53c78edf80c7eed1178ab297a204e16c5c669c7.jpg
    gonna try a little harder when i get uca’s.
    155451870_10158940436125275_460627186309_46d30e1160c1e664190726ee36fd27a53499d16c.jpg
    HulkSmurf14 likes this.
  15. Jul 21, 2021 at 7:22 PM
    RETR0spec
    RETR0spec New Member
    01 AC 2WD limited/ 17 Tacoma AC 6MT
    You ever try switching to the Tacoma coils?
  16. Jul 21, 2021 at 7:25 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Not yet, ill try it when i do my bushings and maybe get some uca’s. Probably wait another couple months for things to cool off outside.
    RETR0spec likes this.
  17. Jul 21, 2021 at 7:34 PM
    RETR0spec
    I’ll see if I can borrow my buddies take offs. Might give it a shot next week
    Sirfive likes this.
