02 Tundra won't shift into 4wd, no lights
Discussion in '1st Gen Tundras (2000-2006)' started by Cajunman007, Jul 31, 2019.
  1. Jul 31, 2019 at 9:55 PM
    Cajunman007
    Cajunman007 [OP] New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    When I push the button, nothing happens. No lights, no noise, nothing. Fuse is good. Never had this issue before. Anyone have anything similar? I pulled the climate control to check out the switch, but it's part of a circuit board and not a simple switch.
  2. Aug 13, 2019 at 8:35 PM
    Cajunman007
    Shane
    Lafayette, LA
    Well I found out that the 4WD ecu went bad. Wasn't getting any power out of it. Changed it and it worked like a champ. Just wanted to update.
  3. Aug 13, 2019 at 9:34 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Where the heck is the cpu?
  4. Aug 13, 2019 at 9:39 PM
    Cajunman007
    Shane
    Lafayette, LA
    It's in the kick panel on the passenger side at the very right. Have to remove the molding for the carpet, then there is one little screw cap. Have to pull the kick panel molding off and it's right there. It slides off the rails that it's attached to. I'll post a pic tomorrow if you need
  5. Aug 14, 2019 at 6:39 AM
    Filthyphil
    Phil
    Wow I had no idea there was one that’s good info to have in case one day I get the same problem you had.
  6. Jul 6, 2021 at 10:40 AM
    Jeff709
    Jeff709 New Member
    2002 tundra
    Do you have a part number?
  7. Jul 7, 2021 at 2:02 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  8. Jul 7, 2021 at 3:58 PM
    Cajunman007
    Shane
    Lafayette, LA
    Part number 89533-34010
    Computer, 4WD Control
    des2mtn likes this.
