Towing problems- No transmission cooler on 2020 TRD Pro
Discussion in 'Towing & Hauling' started by RIck729, Jun 16, 2020.
  1. Jul 7, 2021 at 5:34 AM
    #271
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    If this is the case, Toyota just wants to build soccer mom trucks. Which I hope is not the case. Camry engine in the Tacoma. LS engine in the Tundra? Who knows what Toyota has for marketing right now.
  2. Jul 7, 2021 at 5:54 AM
    #272
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I think I read Ford actually went this way as well outside of the raptor in their new f150. They are just using the heat exchanger as well. Could be wrong though
  3. Jul 7, 2021 at 6:13 AM
    #273
    Kanobi13
    Kanobi13 New Member
    I have tried using both with same trailer and route. For my personal vehicle it likes to be in D o do not hunt for gears or have any issues. I have a vehicle the has an integrated cooler so not to concerned. I just think its funny no matter what thread it turns into you need a aux cooler because the 07-18 has one.
    Oey12 likes this.
  4. Jul 7, 2021 at 7:21 AM
    #274
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Braking aid when descending long grades. Holding TC lockup in 4th or 5th gear while ascending long grades.
  5. Jul 7, 2021 at 8:39 AM
    #275
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    You won't be using S1 descending a grade. I guess I am the only one that manually shifts? Taking off with a heavy load or pulling boats up a ramp, its always S1 for me.
  6. Jul 7, 2021 at 8:41 AM
    #276
    AZBoatHauler
    So.Arizona
    Off-road, I’m in S1 while descending frequently. #savethebrakes
  7. Jul 7, 2021 at 9:10 AM
    #277
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    I figure I'll just run it in D in T/H mode, but monitor temps and if they start increasing unreasonably or gear hunting, I will pop it over into S4. In my first outing with it, I did a bit of each and didn't see the temps go down appreciably when I switched from D to S4. On my next trip in a couple weeks, I'll have lots of highway miles and will try to measure the temp differences between D and S4 to see if it's worth the worry.
  8. Jul 7, 2021 at 11:20 AM
    #278
    AZBoatHauler
    So.Arizona
    Once the heat is built - it can be hard to dissipate. if you move it to S4 around 205-210 the heat will stop building in my experience - granted I'm in a 2017.
  9. Jul 7, 2021 at 12:22 PM
    #279
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Pulling my 5k+ lb TT in D t/h I have accidentally chirped the tires giving it too much gas. I have no problem getting it rolling in D or S4. Pulling is not my issue. Now payload.....
  10. Jul 9, 2021 at 12:09 AM
    #280
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    I installed a cooler on my ‘21 Tundra SR5 at around 13k miles. I went with Genuine Cooling Systems.com. I went with the top of the line cooler he offers... everything else is Toyota factory, ie, the thermostat, hard lines etc. the kit comes with a billet bracket that mounts directly in front of the radiator. All the mounting hardware is stainless. Not cheap. I spent $1000 for everything. Not having a trans cooler on a truck built to tow is insanity.
    I’m running all AMSOIL in everything but the TC. Everything mounted right up exactly right. The holes in the block that used to be where the hard lines mounted are even still there. Detailed easy to understand instructions are included.
    I spoke to the engineer’s at Schaeffer Oil months ago about trans fluid before I bought the Tundra. In their words any trans fluid that sustains a 240deg temp or higher will begin to lose its lubricating qualities and so forth.
    I’m going to down load some photos for you. Crap, I’m having trouble with the download. I’ll try later.
    By the way, violating your warranty will not happen. Toyota still sells all the factory parts for the cooler. All the parts in my kit said Toyota right on them including the part numbers. The only thing in my kit not factory was the cooler itself.
    One last thing. My kit came with the Toyota factory thermostat. It was pinned in the open position to allow continuous flow since adding 1.5 qts of fluid is required after installation. The method of checking proper fluid level in the transmission is quirky to say the least and either myself or the guy at GenuineCoolingSystems can walk you through it. Check his website as there are also some tools you may need to do the job.
    I run with my thermostat open as I am in the desert Southwest.
    Doxiedad, szabo101 and sask3m like this.
  11. Jul 9, 2021 at 3:09 AM
    #281
    glowblue
    glowblue From time to time
    VA
  12. Jul 9, 2021 at 5:28 AM
    #282
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Except that the owner's manual clearly says the truck is not intended for towing.
    hagrid and Clemsonman14 like this.
  13. Jul 9, 2021 at 7:08 AM
    #283
    Lifer
    Lifer New Member
    Vince
    I guess I better read my manual. Why a tow package then?
  14. Jul 9, 2021 at 7:14 AM
    #284
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I know when not towing on hot days my 19 runs cooler in S4 than D. Have not checked it on cool days yet. When I tow my boat I’ll use Tow Mode and try both S4 & D, then use the one that runs coolest, probably S4. Guessing the difference is the Torque Converter lock up?
  15. Jul 9, 2021 at 7:37 AM
    #285
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Hear, hear!
    Tundra, while a towing champion, is intended for deployment during the following activities:
    - conveyance to and from the ice cream parlor
    - carrying yon lady friend to Victoria's Secret to procure lacy/see-through unmentionables, the net weight of which not to exceed 4.996523 picograms
    - cartage of no more than 2 delightful kats in furtherance of veterinary care
    - posing at the mall
    - posing on TacoWorld
  16. Jul 9, 2021 at 7:57 AM
    #286
    glowblue
    VA
    You forgot conveyance to and from the food club for cartage of bulk food items and pallet-loads of toilet paper when a traditional grocery-getter would not suffice.
  17. Jul 9, 2021 at 8:04 AM
    #287
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If yon lady friend's unmentionables are large enough to weigh more than 4 kg, I'll pass on having her in my truck.
  18. Jul 9, 2021 at 8:05 AM
    #288
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    No pallets, plz.
    Even an empty pallet, once placed onto the bed of a MY2019+ Tundra, will cause the trangsmission to instantly achieve supercriticality and collapse inward upon itself resulting in a quantum singularity with a surface temperature of 63.3 million Kelvin.
  19. Jul 9, 2021 at 8:06 AM
    #289
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Obviously not a leather fan...
    IndianaGeologist and Black Wolf like this.
  20. Jul 9, 2021 at 8:08 AM
    #290
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Didn't know they sold those type at Victoria's Secret.
    IndianaGeologist likes this.
  21. Jul 9, 2021 at 8:13 AM
    #291
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Fine.
    Let's poke holes into the continuity of Spraynard's finely hewn missives.
    There... I fixt it.
    Black Wolf likes this.
  22. Jul 9, 2021 at 8:18 AM
    #292
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Much better.
  23. Jul 9, 2021 at 8:40 AM
    #293
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    That sounds like Fake News to me.
  24. Jul 9, 2021 at 8:43 AM
    #294
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Funny enough he's not lying:rofl:
  25. Jul 9, 2021 at 8:58 AM
    #295
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Harrumph!
    hagrid likes this.
  26. Jul 9, 2021 at 9:25 AM
    #296
    timsp8
    NY
    Primarily a passenger and load carrying vehicle.
  27. Jul 9, 2021 at 9:37 AM
    #297
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    This makes sense for any 1/2 ton in my opinion. Not that you said it but I don’t think that “not-intended” is the best description. Otherwise why have a non-existent transmission cooler, tow hitch, or brake controller?
    It’s more than capable when done within reason and CLEARLY not for commercial purposes…
  28. Jul 9, 2021 at 9:53 AM
    #298
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    My 2007 owners manual says the same thing.
    A quick search online of a Ford F-150 owners manual also states basically the same caveats about placing additional stress on the engine, brakes, etc.
    szabo101, glowblue and Oey12 like this.
  29. Jul 9, 2021 at 9:57 AM
    #299
    glowblue
    VA
    My lawn tractor is primarily designed for cutting grass, but nothing says I can’t use it for transportation to make a beer run down the road.
  30. Jul 9, 2021 at 10:23 AM
    #300
    timsp8
    NY
    Yeah I agree. I think all 1/2 tons are mainly daily drivers and occasional towing or hauling.
