Owned Several Tundras, Have New (uneven) Issue w This One
Discussion in 'New Member Introductions' started by Sawman, Jul 6, 2021.
  1. Jul 6, 2021 at 6:29 PM
    Sawman
    Sawman [OP] New Member
    Hi from Tucson.
    I bought a used Tundra w 54k miles that was a lifted 2017 2x4. The driver's side sits 1" lower, so the Front Left tire drags, but ONLY in reverse and turning the wheel to the Left.
    What's most likely culprit for this uneven sit and what's the best corrective measure?
    Thanks for any helpful info.
    ~Saw
    Prostar 190 and YardBird like this.
  2. Jul 6, 2021 at 6:34 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! That driver's side lean is very common among Tundras. All of the added weight seems to be on the driver's side (gas tank, etc.) Best corrective measure? Not sure unless you want to even it out with your lift.
    Sawman[OP] likes this.
  3. Jul 6, 2021 at 6:36 PM
    Sawman
    Roger. Makes sense. Thanks for that.
    Love your tagline, by the way. Biblical wisdom - tragically scarce these days...
    Bakershack and MoneyMan55 like this.
  4. Jul 6, 2021 at 6:37 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Sounds like the common ‘tundra lean’.
    Driver side has more weight; battery, fuel tank, driver.
    Fix is shims for the coil over. Coachbuilder sells em
    Sawman[OP] and AircareTundra like this.
  5. Jul 6, 2021 at 6:39 PM
    Sawman
    Roger. Will seek out & apply. Thanks for that scoop.
    gosolo likes this.
  6. Jul 6, 2021 at 6:41 PM
    18" TRD Off Road Wheels
    The Tundra lean. It's not uncommon, especially on a lifted truck. The stock springs are usually longer on the driver side to account for this, but aftermarket lifts are symmetrical. @gosolo pointed you to the most common fix.
    Sawman[OP] and gosolo like this.
  7. Jul 6, 2021 at 6:47 PM
    Sawman
    Thanks. I went ahead and reached out for the shims. Glad it's a simple fix. There's enough leaning Left in this country without my truck joining the madness.
  8. Jul 6, 2021 at 6:54 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Oh oh. Here it comes :crapstorm:
    And welcome from CA (noooo not that one. Central Alabama).
  9. Jul 6, 2021 at 7:39 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Hey, I'm from THAT California, and I can assure everyone there is nothing wrong with this state that a 2 mile high tsunami or half a dozen nuclear warheads couldn't fix.
    Oh, and welcome from SoCal!
    Sawman[OP], Oey12, D4x4TRD and 3 others like this.
  10. Jul 6, 2021 at 7:53 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. Jul 6, 2021 at 11:42 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  12. Jul 7, 2021 at 1:46 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  13. Jul 7, 2021 at 2:39 AM
    Welcome from Ohio
  14. Jul 7, 2021 at 3:18 AM
    Welcome from NY.
  15. Jul 7, 2021 at 4:14 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks! And you're exactly right - Any news source will confirm the scarcity without even mentioning it!
    :rofl::rofl::rofl: You better watch what you say on that. Although I get the impression that the vast majority on here would agree with you, the mods don't allow anything politically controversial. It's a good rule. The only controversy allowed has to be about Tundras.
    GODZILLA likes this.
  16. Jul 7, 2021 at 4:20 AM
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    Don’t forget to take your daily “constitution” before you get in your truck, this may help alleviate the lean..ha ha
  17. Jul 7, 2021 at 5:35 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
    Thank you for your Service for Us
  18. Jul 7, 2021 at 6:01 AM
    Welcome
