  1. Jul 6, 2021 at 9:04 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    Finally got around to installing the RCI Bed Rack. RCI changed their rack design a bit on the shoulders, it now has rivets and a more modern design. I think it also has more slots on the cross bars, not sure though. It also comes with 9/16 hardware vs the 3/8 their instructions say. All in all, very happy with the rack, it's very solid clamped in by the bed cover. I didn't drill into the bed, I wasn't ready to do that on a truck with 11,000 miles, but if needed I can do it in the future.InkedIMG_3121_LI.jpg IMG_2950.jpg IMG_2951.jpg IMG_2952.jpg
  2. Jul 6, 2021 at 9:22 AM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    @Part_time, Here you go -
  3. Jul 6, 2021 at 9:27 AM
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    @equin The pix you posted appear to show the plates looking a little rough/oxidized. Is that an accurate appearance? Did they come looking like that? My RCI aluminum engine skid came looking like a mirror for reference.
  4. Jul 6, 2021 at 9:28 AM
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    I didn't want to do any drilling either, which is what I liked about the ADARAC. It uses inserts that drop into the stake pockets and then clamp to the side rails for a drill-free install. That RCI rack looks like it'll support a lot more weight. That should be great for RTT.
    itsmerh85[QUOTED] likes this.
  5. Jul 6, 2021 at 9:32 AM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Wait, what? Can you take a picture in the light? I have a sway bar and this is new to me!
  6. Jul 6, 2021 at 9:41 AM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Hauled five loads of bag mulch from LOWE’S over the weekend. Best calculation, about 1,500 lbs each load. Of course, no problem for the truck, but was impressed how little sway there was with the sway bar. Noticeable from other trucks I’ve had. Fender height was two inches lower with the load.
  7. Jul 6, 2021 at 10:54 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    922C4292-87A0-46D4-8DB5-74D595802271.jpg I think we all can see the irony in a Chevy with an “American trucks” decal parking specifically next to me to flex ;);)
  8. Jul 6, 2021 at 11:19 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Mine are the 1/4" bare aluminum, but I'm not sure why they look like that in the pics. They didn't look like that when I unboxed them 15 minutes prior to installing, but they weren't a mirror finish, either. Despite my best efforts, it's possible they got scratched or dirty from the parking lot asphalt and maybe even the Igloo cooler, which admittedly wasn't the cleanest when I used it to prop up the back end.
  9. Jul 6, 2021 at 11:21 AM
    equin
    Ed
    DFW, TX
    Curious, did you rotate it for better fitment because of a rear lift? I ask because I have the rear TRD Pro sway bar also, and am considering a 1" rear shackle lift.
  10. Jul 6, 2021 at 12:03 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    You placed yourself + 1,500 pounds in the rear of your truck?
    What's your payload rating? Running bags? Sumo Springs? Shackles?
  11. Jul 6, 2021 at 12:46 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Thanks I have the skid and want the bumper. Surprised at the answer.
    Thanks for the pics.
    One more forgot to ask what winch did you go with? I am thinking about the Badlands 12k.
  12. Jul 6, 2021 at 1:01 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Is there a write-up somewhere on what needs to be installed for the easiest possible oil changes (like not having to remove a skid plate and having an easy way to drain and replace the filter)?
    I have a 3/2" Readylift with spacers in the skid plate. I also have spacers on the front sway bar, which I've heard make it difficult/impossible to install an easy access skid plate.
  13. Jul 6, 2021 at 1:02 PM
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Cool, thanks for your time. Not that it really matters as it is gonna get weathered regardless. Just curious.
    equin[QUOTED] likes this.
  14. Jul 6, 2021 at 1:06 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Before I buy this, does anyone know of any reason this wouldn’t work for a 2017? Sparks shows it for 2019-21 models.
  15. Jul 6, 2021 at 1:32 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Get the motiv wrench and fumoto valve. Then there's a thread to add a door to your stock skid for the oil filter somewhere.
  16. Jul 6, 2021 at 1:56 PM
    El Two
    Lisa
    Warn Zeon 12-s and did not have to relocate the control box.
    Part_time[QUOTED] likes this.
  17. Jul 6, 2021 at 2:41 PM
    CoachJ
    CoachJ New Member
    J.
    2021 Tundra Trail
    TRD Pro Exhaust Muffler Delete
    i took a ride in the Tundra @ 1 am so i could be at Yosemite Valley by 4am to setup camera for sunrise…
    this is one of my shots (oh and people asked about the truck)44534AC1-DB1A-4AAD-8284-F957AAADA335.jpg
  18. Jul 6, 2021 at 3:14 PM
    equin
    Ed
    DFW, TX
    Wow!
    CoachJ[QUOTED] likes this.
  19. Jul 6, 2021 at 3:16 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Delivered today, hoping within the next two weeks it will be installed. After this and my rear elocker install I will have the coolest trunk on the planet in my eyes.
    I have waited for this day since January 7th of 2017 which is the day I bought my truck. It took this long to save enough on the side and breakdown the wife.
    I used it as a leaning thing for my three kids, work hard, save your money, do the right thing and you can get things you want.
    Sorry, I’m rambling but this is a big day for me and if any group of people can understand, it’s all of you.
  20. Jul 6, 2021 at 3:31 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    You're damn right we can understand, that is freaking awesome!!!
  21. Jul 6, 2021 at 3:32 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    I will try and remember to get one tomorrow.
    Yea, I lifted the rear about 3in, sway bar was sitting at at about 110 degrees now its closer to 80 degrees. I think ideal would be at 90 degrees.
  22. Jul 6, 2021 at 4:24 PM
    Velocity72
    Upstate SC
    2021 Platinum
    Standard springs, Bilstien 5100’s, not bottomed out.
  23. Jul 6, 2021 at 4:42 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I’m patiently saving with the same goal in mind. Please take notes as you go and let us know what works best. If you live near Princeton and need someone to help measure 0-60 times post install just let me know!
    :bikewheelie:
  24. Jul 6, 2021 at 5:05 PM
    1UP
    1UP Truck Gang
    Your payload should be something like 1200 lbs. So 1500 in mulch plus you plus whatever else you got (floor mats, passengers, etc...) puts you quite a bit past what an engineer said was safe and rated the truck for.
    No judgement. Just FYI if you weren't aware.
    a522467 likes this.
  25. Jul 6, 2021 at 5:15 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Finally put my Bilstein 6112 together on 1.9” setting. I plan to install them Thursday it’s supposed to cool down to 68. I’m going to do 2 shims on driver and 1 on passenger. My current 5100 are on top setting and they’re stiff so I think the 1.9” will be good.
  26. Jul 6, 2021 at 5:49 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Smoked the tails and marker light. It’ll do until the Morimoto XB’s are available to purchase ¯\_(ツ)_/¯ A3B2BEE4-1DC1-46F2-90C2-09F687C8082D.jpg D33AA553-9990-4BD8-AB0D-E6216F6CE24A.jpg C485F65E-CB7E-4595-8D5A-E0C6D4D844C8.jpg
  27. Jul 6, 2021 at 5:55 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    SOOOOOOOOOOOOO JEALOUS BROTHER! I showed my wife and she's like nope. How'd you convince yours with having 3 kidos
  28. Jul 6, 2021 at 6:02 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    You do realize the majority of us are legit excited for you!
    MaxPower, 3xYOTA, Aught16TSS and 4 others like this.
  29. Jul 6, 2021 at 6:37 PM
    You don't have to rotate it for 1 inch of lift.
    equin[QUOTED] and SpooledReel like this.
  30. Jul 6, 2021 at 6:55 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    or for 2".
    equin likes this.
