2013 Double cab running boards.
Discussion in '2nd Gen Tundras (2007-2013)' started by Oriolesfn12, Jun 13, 2021.
  1. Jun 13, 2021 at 7:56 AM
    Oriolesfn12
    Oriolesfn12 [OP] New Member
    Hey! Will a 2014 stock running boards fit on my 2013 Rock Warrior Tundra? There’s a set for 100 bucks I’d like to buy..
  2. Jul 5, 2021 at 12:39 PM
    Ger
    Ger New Member
    Toyota Tundra 5.7 V8 Flexfuel 2011
    - spyder taillights (smoke, dark, LED) - spyder headlights (got the wrong ones from the U.S. new ones coming in, also smoke, dark, LED) - spyder 3rd break light (smoke, dark, LED) - bushwacker fender flares (smooth black style, rivet) - go rhino RB20 running boards - K&N drop in filter - 100L gas tank donut under the bed - 100L gas tank cilinder in the bed - double gas distributor (Prins) - ecu controlled valve oil system (Flashlube) - 20” XD SERIES® - XD778 MONSTER Matte Black - Cooper Discoverer AT3, 275/55/20 - upgraded audio system: - Pioneer EVO9, 9” display - 12 Channel xfire, Digital Sound Processor (DSP) - 6x 8” 750W RMS xfire, subwoofers in a custom underseat - 6x 8” 150W RMS xfire, pro audio midrange woofers in custom door panels - 4x 150W RMS xfire, GT20 bullet tweeters - 2x 600W RMS xfire, 2000.4 amplifier - 1x 4500W RMS xfire, 4500.1 amplifier (mono) - 2x yellow top upgraded batteries And some more I forgot at this moment and will add later one, along with also next year a new black leather interior with red stitching and a Super Charger!
    Hi,
    As far as I’m aware of, the frame didn’t change between 2nd and 3rd gen tundra’s. So in that case they should fit.
  3. Jul 5, 2021 at 12:59 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Should fit fine.. Congrats
  4. Jul 5, 2021 at 1:11 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Yes as long as it's off a double cab and going on a double cab. Crewmax steps are different.
  5. Jul 5, 2021 at 1:16 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    I could be mistaken, but don’t they bolt up into the rocker panel? The ones I took off my 15 did if I recall. So bolts might line up different between 13-14 DC. So frame might be same but not necessarily the holes for the bolts. I’d double check before just buying them.
