Rear shock how-to
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, Jul 5, 2021.
  1. Jul 5, 2021 at 7:46 AM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Haven't found it in 1 place but is there a how-to for rear shock replacement? What I'm mainly looking for is the long handle wrench that makes it easier. Ran across it a while back but striking out searching at the moment
  2. Jul 5, 2021 at 8:06 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Jul 5, 2021 at 8:06 AM
    Heavyopp
    Heavyopp New Member
    2000 V8 Tundra AC
    I just did a 2000 with original shocks in it — 68,000 miles and it just had it’s frame replaced 1 month ago — top shock nuts where just removed/reinstalled withe the frame replacement
    I figured they would come right off — not a chance — I wrestled for over an hour before I just cut them off — dealer mechanics must have put them on with the bed off — maybe even red loctite
    Drop the spare tire and you can get easy access to the drivers side — pass side wasn’t so bad from wheel well
    I ended up using a cutting torch on the drivers side, worked great but lit the rubber bushings on fire — was a bit of a scramble — pass side I used a dremel and about 10 cut off wheels
    Figure out how to cut them with whatever is available to you — you’ll be happier
    Darkness likes this.
  4. Jul 5, 2021 at 8:09 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Socket and a dewalt impact driver
  5. Jul 5, 2021 at 8:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I knew I was throwing away my old shocks at 316k miles. I got a 4 inch angle grinder and a grinding wheel. I ground two flat places on the shock strut. Not the body of the shock.
    That let me put vice grips on the shaft so it wouldn't spin while I turned the wrench to remove the old shock. New shock went in with a 5mm Allen wrench in the end of the shock shaft. 19?mm wrench was what tightened the nut for the shaft.
    The Allen wrench kept the shaft from spinning while I tightened the nut.
  6. Jul 5, 2021 at 8:19 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Install use ranch, taking it off use impact driver, with WD 40
  7. Jul 5, 2021 at 9:20 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    There's no room at the top of the shock for an impact wrench on first gens.
    onesojourner and Jack McCarthy like this.
  8. Jul 5, 2021 at 9:21 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Does ranch work like never seize?
    :D
    Jack McCarthy, Darkness and 2mchfun like this.
  9. Jul 5, 2021 at 9:30 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I discovered that there are 12" sawzall blades when I changed my shocks...
    tvpierce and Jack McCarthy like this.
  10. Jul 5, 2021 at 9:37 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Huh, I must be lucky. I don't recall using any special tools or techniques when I replaced mine. Twas an easy job.
    ...and I think ranch is delicious on everything.
  11. Jul 5, 2021 at 9:46 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    It's all coming back to me now, kind of depends on the FGT truck on how difficult or not this is. I ordered some ICONS for the rear and now I'll order the "wranch".
    Gonna replace the BJ bolts here in a bit then I'll spray that rear shock mounting areas down. The shocks look like shit, hopefully the hardware isn't too bad. I can't wait till this is done hopefully reduces the little bounce I think I'm getting from having the stiff Icons up front and shitty tuff country worn out in back....Ranch is good but Orlondo's is my new fix all where ranch used to be. It's local to me. https://www.orlondos.com/
    onesojourner and Darkness like this.
  12. Jul 5, 2021 at 9:49 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Btw, somethings missing....are there no 300 memes allowed anymore? Or are those members on voluntold vaca? I haven't seen as much.
    Thanks for the input no matter the generation. Much love, hope everyone had a great 4th!
  13. Jul 5, 2021 at 9:55 AM
    Sawzall FTW
  14. Jul 5, 2021 at 10:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Jul 5, 2021 at 10:28 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Jul 5, 2021 at 10:45 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not on a first gen. Later models are very different.
    Tundra2 likes this.
  17. Jul 5, 2021 at 10:49 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Some of the later generation crowd complained and some of us got threatened with vacation over the memes.
    That said, I saw no warnings about gifs
  18. Jul 5, 2021 at 10:50 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Darkness[QUOTED] likes this.
  19. Jul 5, 2021 at 11:17 AM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Really? That's too bad. I'm 55 and find many of them very creative and witty at getting a point across, like the ones Tundra2 posted above. I saw a 300 one somewhere on here yesterday while searching where Leonidis was kicking a red 2nd gen down the sewer hole with the words "This is first gennn". Pretty good stuff.
  20. Jul 5, 2021 at 11:26 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. Its apparently seen as hostile, but it has always been done in good humor as an attempt to keep bad info out of the first gen threads. So many things that work for them don't apply to our trucks.
  21. Jul 5, 2021 at 11:30 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    That meme has won awards.
  22. Jul 5, 2021 at 11:32 AM
    Desert Dog
    Understood.
    Tundra2 likes this.
  23. Jul 5, 2021 at 11:34 AM
    Desert Dog
    I can believe it. I laughed pretty good at the creativity of it.
    Darkness and Tundra2 like this.
  24. Jul 5, 2021 at 11:35 AM
    Desert Dog
    I probably should figure out the multi-quote function...
  25. Jul 5, 2021 at 11:35 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Doesn't look too bad, hopefully after it's sprayed it'll be cake. The Allen key feels pretty fucked though. Can't get a good picture....off this subject without starting a new thread... probably gonna regret this....Can I replace lower ball joint bolts 1 by 1 just jacking up each tire individually or maybe while on ground? Seems there is more stress on that set up when left to hang. Then a separate jack is needed to push arm into place.
  26. Jul 5, 2021 at 11:50 AM
    Lil Steve
    Gilbert, AZ
    The "shooing" was always just a joke, never intended make anyone feel unwelcome but it unintentionally went a little sideways in this thread. https://www.tundras.com/threads/can-anyone-give-me-some-recommendations-on-wheels-and-tires.88452/
    Click "Multi-Quote" on any/every message you'd like to quote then you'll see "Insert Quotes" when you reply. Or you can click "Quote" (<---is that redundant?) on different messages to insert each message individually.
  27. Jul 5, 2021 at 12:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I never had luck with the multi quote button. I found that if you quote somebody, and before you lost go hit quote on another post, it works pretty well to add in.
    As far as rear shock, the method I used was to cut off the sleeve on the shock to expose the shaft. Then I used a grinder to make a flat spot on the shaft and held that with big vise grips. Then a ratcheting box end on the top with lots of lube.
  28. Jul 5, 2021 at 12:29 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    kind of a thousand island guy myself
    Darkness and Sirfive[QUOTED] like this.
  29. Jul 5, 2021 at 12:44 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont think vinegar would make for long lasting lubricity.
    Tundra2 likes this.
  30. Jul 5, 2021 at 1:25 PM
    Ranch is not a lubricant. :D
    jimf909 likes this.
