  1. Jun 30, 2021 at 1:49 PM
    #6961
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Looks awesome. Putting some great work into the house.
    AZTundra[QUOTED] likes this.
  2. Jun 30, 2021 at 1:56 PM
    #6962
    AZTundra
    Paul
    Phoenix, AZ
    Thanks. Been a long process, but we made it through. Next up will be resealing the stamped concrete on the patio, front walkway, and around the pool to bring back the shine.
  3. Jun 30, 2021 at 3:54 PM
    #6963
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    This 100%. Dig out the rot, fill with Bondo, sand it down, paint it, drink a beer. I have a lot of experience with wood rot from water. Unfortunately.
    IMG_20191018_111648483.jpg IMG_20191018_111731218.jpgIMG_20210630_175257550.jpg
  4. Jul 1, 2021 at 2:30 PM
    #6964
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Thanks everyone
  5. Jul 1, 2021 at 2:32 PM
    #6965
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I meant to ask and forgot, got a link or anything to that storage shed? we'll be getting a pool in the next few months-year and am wanting somethign like this to help store items
  6. Jul 1, 2021 at 4:08 PM
    #6966
    csuviper
    Broomfield, CO
    Lowes.com. Craftsman shed. All my HOA will allow is a half height shed.
    Fotnot[QUOTED] likes this.
  7. Jul 1, 2021 at 5:38 PM
    #6967
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Ripped off my back deck this past week. Putting in an 18x20' Bluestone patio.
    IMG_5759.jpg IMG_5706.jpg IMG_5701.jpg IMG_5700.jpg IMG_5695.jpg IMG_5693.jpg
  8. Jul 1, 2021 at 6:38 PM
    #6968
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
    Bilstein 5100,toytec. Fuel D671
    BeachBaum107 likes this.
  9. Jul 1, 2021 at 6:39 PM
    #6969
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
  10. Jul 1, 2021 at 6:45 PM
    #6970
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That looks great. Is the shower stall level with the rest of the floor, or is it below that?
  11. Jul 2, 2021 at 7:16 PM
    #6971
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    I bought a thing.
    206852670_4405732252772203_9207672984071_261bcb39b19a7399129af06dbfb82ba93a253bd1.jpg
  12. Jul 2, 2021 at 9:57 PM
    #6972
    CoachJ
    CoachJ New Member
    J.
    2021 Tundra Trail
    TRD Pro Exhaust Muffler Delete
    Finished the yard…
  13. Jul 3, 2021 at 6:43 AM
    #6973
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Mowed a Butt load of grass AGAIN. Sure hopes it rain every damn day for about 30 minutes and I can do it all again next week
  14. Jul 3, 2021 at 7:00 AM
    #6974
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Been trying to troubleshoot my central air conditioning the last few weeks to no avail.
    Steps I've tried (some are stupid but they're the only suggestions I could find on Google):
    • Confirmed thermostat is set to cool, fan is set to auto and temperature is set correctly (duh)
    • Cleaned air return grates
    • Cleaned air supply vents
    • Confirmed the filter is clean. (Unlikely any of the previous were the cause as we didn't have issues with heat from the furnace this past winter - *knocks on wood*.)
    • Confirmed evaporator drain line is clear
    • Condenser coils were clean but I ran a vacuum over them anyway and cleaned the leaves and duct tape out of the bottom.
    • Did an ohm test on the capacitor end of the compressor wires. Everything tested fine, assuming the various metal points I was testing against are actually grounded. Can't test the wires right at the compressor unless I magically grow 4 gorilla arms.
    What I'm seeing:
    • Air coming out of the vents is not cooled at all vs the room air.
    • If I turn the system on, it will run for 12 hours straight non stop without cooling the house at all.
    • Condenser fan is running fine.
    • Compressor sounds to my inexperienced ear like it's running fine.
    • The temperature of the line leaving the condenser is the same (by touch) as the one entering it. (Note: the line leaving the condenser is insulated all the way but there are small bare sections right where it exits the condenser and enters the evaporator (inside the ducting at the furnace outlet).
    Possible causes:
    • No flow through the compressor. But if that were the case, shouldn't it sound like it's surging or something like that?
    • No/low refrigerant in the system. I don't see any signs of large leaks. Not sure if there could have been small leaks over the years. But shouldn't whatever is in the system still get a bit of cooling across the condenser?
    A friend of mine keeps going on and on about how I need to check the Schrader valves for oil in the system but, if the system has those, I can't find them. Also, I would think the compressor should sound like it's having issues if it's trying to compress oil.
    Any other thoughts on possible fixes I can try myself? I have a service call booked for 2 weeks from now but am not ready to give up on fixing it myself yet.
  15. Jul 3, 2021 at 8:46 AM
    #6975
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Wyze Video Doorbell installed
  16. Jul 3, 2021 at 8:58 AM
    #6976
    TomC843
    Tom
    Charleston, SC
    low on refrigerant. Don't know what good you checking the valve cores if you can't hook up some gauges and check the pressures. Basic Google pic of service valve and valve core
  17. Jul 3, 2021 at 9:00 AM
    #6977
    TomC843
    Tom
    Charleston, SC
    Also turn it off till you can get the freon checked. Can overheat the compressor and trip overload.
    TaquitoBandito likes this.
  18. Jul 3, 2021 at 9:07 AM
    #6978
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, it's always off except when I'm testing it. Thanks.
  19. Jul 3, 2021 at 11:32 AM
    #6979
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    That's what it sounds like to me too. And without gauges you can't check. Everything that you checked is working, so not much left except refrigerant. A lot of times the leak is at the service valves, but you could have a soldered joint leak or mechanical damage. You could try soap testing the service valves, but if all the freon dumped that won't tell you anything.
  20. Jul 3, 2021 at 11:44 AM
    #6980
    Tremor F-250, Roush Mustang, Jeep Crawler
    The patio project has begun. Pulled all the pave stones up, pulled back the sand/dirt. This project will have gaps in finishing. We have a budget and it went over.
    The first stage is the foundation. I will go put up a mini excavator on Monday.
    Next will be electrical conduit and natural gas piping.
    Then we are putting in a 6” slab.
    Hot tub will be ordered and placed.
    The kitchen, walls, patio portion will have to wait a few months to save up around 10K more.
    B7730B76-7785-43CA-B67C-672071C4A047.jpg F69046D9-1E38-462C-8B18-0EDADB98AF22.jpg
    Wife and kids are finishing the coop and building a 6’ fence.
  21. Jul 3, 2021 at 3:07 PM
    #6981
    Our youngest (but biggest) dog decided to take out the builders trash can pull out kit, so I went and upgraded that today along with a ceiling fan for one of the kids rooms
  22. Jul 3, 2021 at 3:09 PM
    #6982
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    You just love putting in ceiling fans, eh?
    T-Rex266[QUOTED] likes this.
  23. Jul 3, 2021 at 3:19 PM
    #6983
    All sorts :D
    Only one room to go, but his room stays pretty neutral.
  24. Jul 3, 2021 at 4:33 PM
    #6984
    Squatting Pigeon
    Holden
    North Texas
    He needs this:
  25. Jul 3, 2021 at 4:38 PM
    #6985
    Outbound
    Aaron
    Northern Alberta
    I thought that would go above @Jim LE 1301's dinner table.
    TaquitoBandito, 1UPPER and Fotnot like this.
  26. Jul 3, 2021 at 4:55 PM
    #6986
    Squatting Pigeon
    Holden
    North Texas
    You mean the official mustard on watermelon club?
    Bet.
    jewsNbrews and Outbound[QUOTED] like this.
  27. Jul 3, 2021 at 5:28 PM
    #6987
    Outbound
    Aaron
    Northern Alberta
    :rofl::fistbump:
  28. Jul 3, 2021 at 5:49 PM
    #6988
    GatorBodine
    GatorBodine New Member
    100% low on refrigerant.
  29. Jul 3, 2021 at 6:52 PM
    #6989
    Superman ???
  30. Jul 3, 2021 at 6:55 PM
    #6990
    Outbound
    Aaron
    Northern Alberta
    That'd be better. That's a Marvel comics fan. Superman is DC, therefore superior in every way.
