  1. Jul 2, 2021 at 3:20 PM
    SAGE63
    San Diego County
    yup a shim..
  2. Jul 2, 2021 at 3:22 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    I did it too. All 4 doors.
    the ER kid and Taco-Spike like this.
  3. Jul 2, 2021 at 3:36 PM
    Taco-Spike
    Two Trucks
    Not sure? Maybe a short or surge occurred. You do a reset and disconnect the battery for a while?
  4. Jul 2, 2021 at 3:38 PM
    Taco-Spike
    Two Trucks
    I did all six in my Tacoma. Much better but still needs and amp or at least the kicker key to bump it up a bit. Still happy with it
    Lassie[QUOTED] likes this.
  5. Jul 2, 2021 at 4:11 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Nice! Where did you get those?
    TK1979 and TNTundra16[QUOTED] like this.
  6. Jul 2, 2021 at 4:26 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
  7. Jul 2, 2021 at 4:29 PM
    DPhung
    DPhung Measly Mechanic
    North AL
    2016 MGM Tundra CM
    Do I have to use it alongside the collars for a 3” lift?
  8. Jul 2, 2021 at 4:30 PM
    SAGE63
    San Diego County
    I do not know what you bought... and there are probably many others that know more than me
    DPhung[QUOTED] likes this.
  9. Jul 2, 2021 at 4:34 PM
    DPhung
    North AL
    2016 MGM Tundra CM
    Well just to put it out there it’s Westcott preload collars for 6112s.
  10. Jul 2, 2021 at 4:35 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you get the kit for 5100s? I believe you add the collars with the perch set at top, then add the shims to complete the lift.
    edit: saw your reply about 6112s. Same idea.
  11. Jul 2, 2021 at 4:38 PM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    Can I get a hallelujah and an amen?
    King 2.5 OEM shocks installed on the front and rear. Started with the easier rear shocks first. Added 1/8” rubber sheet to the driver’s side as a rock shield.
    After working up the courage, next was the King 2.5 OEM extended travel coilovers with 650lbs spring rate on the front. Also swapped in SPC UCAs. Dear Santa, if you’re listening, all I want for Christmas this year is a 40” breaker bar.
    UCAs going in:
    Coilovers installed. The craftsmanship on these is a thing of beauty.
    Stats for the front (Didn’t get measurements for the back):
    Front passenger side @ 35 psi -
    From ground to fender: 35 5/8”; after King install: 37 1/2”
    From center hub to fender: 21”; after King install: 22 3/8”
    Front driver side @ 36 psi -
    From ground to fender: 36 3/16”; after King install: 37 1/2”
    From center hub to fender: 21 1/4”; after install: 22 1/2”
    The fronts were ordered with a two inch lift. Looks like the weight from the bumper and winch accounted for ~3\4”.
    I want to put another 10k on the stock tires before replacing them with Cooper Discoverer AT3 XLTs. I’ll have to wait till next week for the alignment - ugh, want to get the truck on the road.
    Many thanks to everyone on the forum that shared their experiences (the good, the bad, and the ugly) with installing shocks and UCAs. The info was invaluable. Special thanks to @csuviper for posting the suspension torque specs - very helpful and saved me from hunting for the info.
  12. Jul 2, 2021 at 4:41 PM
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
  13. Jul 2, 2021 at 4:45 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    This is what the blue kit looks like on mine, hope this helps.
    Wallygator, TK1979, GAknight and 3 others like this.
  14. Jul 2, 2021 at 4:47 PM
    jimbrophotodotcom
    Hawaii
    Looks plenty bright enough. Blue is illegal where I’m at so I’ll just go with a white light
    TILLY[QUOTED] likes this.
  15. Jul 2, 2021 at 4:58 PM
    Steve18
    Steve18 New Member
    Virginia Beach
    2016 Black 4Runner Trail and 2021 Black Tundra TRD Pro
    Got away from people for the week.
  16. Jul 2, 2021 at 5:00 PM
    Taco-Spike
    Two Trucks
    Interior color lights are illegal?
    Long Duck Dink likes this.
  17. Jul 2, 2021 at 5:06 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Are they pretty secure? I have been wanting to get some but read that they don't fit on the Pro Grills
    TNTundra16[QUOTED] likes this.
  18. Jul 2, 2021 at 5:06 PM
    jimbrophotodotcom
    Hawaii
    most definitely in Hawai’i. Anything to put us down apparently.
    TK1979 and Taco-Spike[QUOTED] like this.
  19. Jul 2, 2021 at 5:10 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    And the logic of that is?
    TK1979 and Taco-Spike like this.
  20. Jul 2, 2021 at 5:11 PM
    jimbrophotodotcom
    Hawaii
    Honestly not sure. Cops have blue lights. (?)
  21. Jul 2, 2021 at 5:36 PM
    Taco-Spike
    Two Trucks
    Let me know if that works. Curious what’s going on. Shouldn’t be happening but some trucks act different than others, not sure why when same years and trims act differently?
  22. Jul 2, 2021 at 5:38 PM
    Taco-Spike
    Two Trucks
    Crazy. Well, if you go white, I’m a fan of the 5500k and 6000k color temps. Depends on what other interior light you have to match.
  23. Jul 2, 2021 at 5:40 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Jego, D4x4TRD, aelarson and 20 others like this.
  24. Jul 2, 2021 at 6:02 PM
    AggiePhil
    College Station, TX
    Took her to the beach.
    Jego, coldcanuk, D4x4TRD and 11 others like this.
  25. Jul 2, 2021 at 6:09 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    This is the way
  26. Jul 2, 2021 at 6:27 PM
    Ó Brádaigh
    Ó Brádaigh New Member
    S. Polychronopolous
    21MGT
    Patiently waiting...
  27. Jul 2, 2021 at 6:29 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    During their sale it's $1,000 with free shipping. My truck is super new so the installation was legitimately like 12 minutes.
  28. Jul 2, 2021 at 6:47 PM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    TRD rear sway bar, and boy does it make a difference.
  29. Jul 2, 2021 at 6:59 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Haha, agreed.
  30. Jul 2, 2021 at 7:17 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Funnyguy713[QUOTED] likes this.
