Good 6.5 components or good 6x9 component speakers?
Discussion in 'Audio & Video' started by Handbanana, Jul 1, 2021.
  1. Jul 1, 2021 at 8:15 AM
    Handbanana
    Handbanana [OP] New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    What are you guys running in the front door of your tundra? Which speakers would you choose? A good 6.5 or a good 6X9 speaker? I’m looking for a good mid bass but also able to get loud I do have some offers already and a pair of JL component speakers in the rear. At the moment I have a set of 6 x 9 three way focal speakers in the front but I feel that the sound is being directed towards your feet’s because the dash speakers have been unplugged. all the speakers are amplified. I am open to other options but these are the speakers I’m kind of looking at. These are top-of-the-line alpine speakers. This would allow me to buy a adapter and install the tweeter back in the dash. I also have extra sail panels that I could drill and mount the tweeters on the sail panels.
    Rica25 likes this.
  2. Jul 1, 2021 at 12:39 PM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    I would just reach out to James @james@tech12volts. I did and he hooked it up with a nice setup. I haven't finished it SMH but I've got the sound mat in place. Hopefully this weekend I'll get a chance to make a dent.
    Rica25 and panicman like this.
  3. Jul 1, 2021 at 1:07 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I ran a focal set up in my f-150 and it rocked. I ran those alpines in my taco and it sucked comparatively. I'd go listen before you waste a bunch of money, I'll never go alpine again. Focal is a little more "clear" or "tinny" but still had solid bass. The alpines just never got as clear, and the bass wasn't as good either, they were bad on every level compared to my focal set up.
    I'm waiting for my Tundra to come in, but maybe its more on where the speaker placement is, and you might need to put in some custom speaker set ups to bring the level up, or get it tuned where they can make it sound like they are higher. I am not a pro, so there might be better options, my big warning is to listen to those alpines before you blow the cash.
    06’DCXSP likes this.
  4. Jul 1, 2021 at 5:01 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Jeez, at $700 you’re halfway to an actually decent 5 channel system that’s plug and play.
    $1300 and a weekend installation with a few beers and you will be WAY happy.
    another vote for James. That dude is SOLID.
  5. Jul 1, 2021 at 6:27 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Round speakers will always sound acoustically better than oval speakers.
    Rica25 likes this.
  6. Jul 1, 2021 at 6:58 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    I have the kenwood xr1801 in the fronts and alpine type r on rear
    TK1979 and Rica25 like this.
  7. Jul 3, 2021 at 6:59 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    So after reading this I decided to get Polk Audio 3-way 6x9s to replace my rear door speakers. I wonder if I'll notice any difference from the 6.5 Kickers I currently have there?
  8. Jul 4, 2021 at 6:00 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    So I assume 6x9’s will work in a 21 crewmax without checking with James? I will have to check with him to see if he makes the custom mounting plates for 6x9. I only see on his website for the 6.5.
  9. Jul 4, 2021 at 1:43 PM
    Handbanana
    2018 TSS CM 4x4
    He only offers hertz and those are more of a mid grade speaker
  10. Jul 4, 2021 at 1:44 PM
    Handbanana
    2018 TSS CM 4x4
    I already have aftermarket 6x9 and the fit fine and they have a huge magnet. Crutchfield is wrong all 6x9 fit perfectly.
  11. Jul 4, 2021 at 1:45 PM
    Handbanana
    2018 TSS CM 4x4
    This is my second option. Apparently these were made for Toyota.
  12. Jul 4, 2021 at 1:48 PM
    Handbanana
    2018 TSS CM 4x4
    6x9 don’t fit the rear only the front. 6x9 in the front only. That’s the oem size for the wrong.this is why I’m going with component speaker with tweeter in the dash or maybe a 3.5 in dash with 6x9 midrange in front door. If you decided to put the 6x9 in front door use the provided bracket to mount the speaker. I have a video on YouTube showing the 6x9 focals rcx690 in front doors and how they fit
  13. Jul 4, 2021 at 1:49 PM
    Handbanana
    2018 TSS CM 4x4
    Did you power them with a amp?
  14. Jul 4, 2021 at 2:43 PM
    panicman
    Eric
    Yes, and a mid grade speaker set is a night and day improvement over the cast diarrhea they installed at the factory.
    You need an amp for decent sound or you're just jerking off no matter how good quality the speakers are.
    06’DCXSP and Handbanana[OP] like this.
  15. Jul 4, 2021 at 3:01 PM
    Elduder
    Elduder New Member
    Was waiting for this, but have really given up on arguing this point. But just for the hell of it, why don’t you give me an all encompassing reason why the shape alone dictates a subjective outcome that is different for everyone as everyone’s ears and taste are different.
    :D
  16. Jul 4, 2021 at 3:09 PM
    Handbanana
    2018 TSS CM 4x4
    Yes they will. The brackets usually come with any speaker you buy.
    Here a video
    https://youtu.be/2WWIhpbwgwk
    TK1979 likes this.
  17. Jul 4, 2021 at 3:11 PM
    Handbanana
    2018 TSS CM 4x4
    This is a blanket state. May be back in the day but now manufacturers are making 6X9 speakers which produce more mid bass. I’m just confused because usually all Dash speakers come with mid range tweeters if you want to call them in the dash but people usually swap them out for tweeters. I wish the people who say 6.5 speakers are better than 6X9 speakers could hear my alpine system in my newer ram. Sounds hell of good very clear and lots of bass even at high volumes.
    TK1979 likes this.
  18. Jul 4, 2021 at 3:13 PM
    RusPro21
    Don
    Pa.
    Yeah I was up with my audio guy who own the store. Discussing Hybrid audio components and not using the center channel. They have done all my installs over the years. I had them in my Tacoma a few years back and really sound good.
    TK1979 likes this.
  19. Jul 4, 2021 at 3:47 PM
    Elduder
    Elduder New Member
    I just have to remember this forum is a general truck forum, I've spent too much time on other sites like DIYMA and tend to blend approaches.
    6x9s having more surface area, assuming the same xmax, power, sensitivity, etc. will likely produce more SPL, therefore more "bass" that you can feel at least.
    The typical response is more aimed at beaming, which assuming someone used midrange speakers, went 3-way or tuned with large tweeters capable of reaching low enough, could be addressed with x'overs. So if you have the tools that goes out the window.
    Materials make a significant difference in sound properties, so blanketing it with a shape as the determining factor is too vague. For the most part, for the Tundra, 6x9s that fit and sound really good without tuning are harder to find.
    Beyond that, 6x9s typically produce more SPL with the same power and are typically referred to as being better at producing bass. If you're counting on your door speaker to produce the whole bandwidth of your music (for those that want to argue a 6x9 sucks at high freq.), I wouldn't suggesting claiming what "sounds the best" without anticipating some retort. You shouldn't be asking a speaker that low in placement to produce the freq. responsible for staging, vocals, etc. Unless you want it to sound like the singer and instruments are on both sides of the truck at about knee level, lol.
    That's why its subjective though, a lot of people will never even care about those things and that's good as long as they're happy with their system.
    Hell, Im saying all this and running 6" Morels. Too many factors present.
    My advice, as always, try to find a place to listen in person.
  20. Jul 4, 2021 at 5:02 PM
    Handbanana
    2018 TSS CM 4x4
    My man. I still don’t understand why switch out 6x9 for 6.5, especially if you have the room. I guess crutchfield has them all fooled. So I need your option which set up would you go with the kenwood with 3.5 midrange tweeters in the dash or alpine with 1inch tweeters in dash?
  21. Jul 4, 2021 at 5:40 PM
    Elduder
    Elduder New Member
    I ran 3.5” Infinity Ref for a bit in the dash. Definitely need to cap them if you don’t have a separate channel on the amp that has a x’over. They did get a bit of distortion at volume on the stock HU.
    Do you have a DSP or aftermarket HU?
    Darkness likes this.
  22. Jul 5, 2021 at 2:07 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Yes. Alpine are not good sounding speakers. I sound deadened everything as well. I think they were good when I was kid maybe? Probably not, but people didn't know better.
    They aren't BAD, but they aren't good and I have no idea how they got the reputation they did. I'd put them in the middle end of aftermarket but they are priced towards the higher end. Obviously not the extreme high end, but for general population.
  23. Jul 5, 2021 at 6:29 AM
    Handbanana
    2018 TSS CM 4x4
    Alpine halo9
  24. Jul 5, 2021 at 8:22 AM
    Handbanana
    2018 TSS CM 4x4
    I could always try them and send them back if I don’t like them.
    woods[QUOTED] likes this.
  25. Jul 5, 2021 at 9:31 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I gotta say I've been very happy with my Focal Performance PS 165FX components..
    Focal Performance PS 165FX Performance Expert Series 6-1/2" component speaker system at Crutchfield
    Amazon.com: Focal PS165FX Flax 6.5” 2-Way Component kit, RMS: 80W - MAX: 160W
    Running them off a Kenwood HU and an Alpine PDX V9 5 channel amp.
    I bought OEM JBL door sails and put the tweeters in them.
    Ended up disconnecting all 3 dash speakers..
    tac0tune$ makes some really nice thick plastic speaker adapters..
    Also if I had to do it over again, I would have mounted the speaker crossovers under the seat with the amp instead of in the door.
    These pics are the MDF spacers I made that fell apart after a couple years.
    43A85727-0BAB-4627-9E77-856E38144C8A_zps_d580c31adfdf8f8f74fc23d46f26e9ff6ff02c07.jpg
    689D6A5A-12D7-46ED-8E04-46779903642B_zps_0f109f91e58e6181d356bb2dda8374e726b270f0.jpg
    1ECB6E14-BF8F-4061-A381-7658882F713C_zps_15789867293837ea534aa3826e873538f392a669.jpg r7df2zr7_zpscoegh5fw_e14e4e071c704d230b554daebfcc38c675bc6089.jpg
    Focal Performance 165AC in the rear.
    I ripped out the stock speaker and used them for the mounting bracket.
    Focal Performance 165AC Access Series 6-1/2" coaxial speakers at Crutchfield
    DBC6ABDD-3326-4B38-9BD4-21DCA4A06E84_zps_f38c9da9f0aab853cbfd5f7d48e0873a14b5363c.jpg D470B1E9-862B-45C9-AD11-BC86D3147A51_zps_945497655f68e1de10974ee3d7480303181eab49.jpg C69F30A1-305D-4183-AAAF-7C8763CEDAAB_zps_98684c173115fd9478977114c43367331d12f429.jpg
    TK1979, 06’DCXSP, MTRock and 2 others like this.
  26. Jul 5, 2021 at 10:58 AM
    Elduder
    Elduder New Member
    I'd just go with the 3.5" coax in the dash. If you really wanted to go all out and didnt want to get into active x'overs I'd go with a 3 way component set and put the mid in the dash and the tweeter in the door sail.
    Otherwise, yeah 3.5" coax in the dash and put a capacitor on the wire if needed.
    TK1979 and MTRock like this.
  27. Jul 5, 2021 at 11:32 AM
    Handbanana
    2018 TSS CM 4x4
  28. Jul 6, 2021 at 2:15 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    These are the focals I had, they rock.
    @Handbanana I'm going hard on Alpine, they aren't as bad as I'm saying, but I think people need to understand they are NOT top of the line speakers and if you listen to a lot of music and like it loud you will not be happy. There just is not the depth to the music and full sound that you get from a good speaker, I don't know how else to explain it as I know what I like to hear but not sure of all the right lingo.
  29. Jul 6, 2021 at 2:44 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    Front dash, shaved the dash cover..
    Front doors, shaved the inside of the door panels, tight fit but impressive sound!
    TK1979 likes this.
  30. Jul 6, 2021 at 5:50 AM
    Handbanana
    2018 TSS CM 4x4
    These are three way 6x9 coxials plus with the 3 1/2 mid range tweeter in the dash it would be way too bright for me. I’m more of a clean clear smooth warm sound kind guy. With a 6x9 component you get good mid bass more then a 6.5 and separation of sound with a midrange in the dash.
