Fuel beast
Discussion in 'Wheels & Tires' started by 13igtymer, Jun 27, 2021.
  1. Jun 27, 2021 at 10:02 AM
    13igtymer
    13igtymer [OP] New Member
    2016 toyota tundra crewmax limited
  2. Jun 29, 2021 at 5:08 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    I went with +1 fuel avengers. The difference between +20 and +1 is just 19 mm, more or less 3/4”. Divided by 2, its 3/8 on each side. With 275/55-20 tires sits 2” proud of the rear fender.
    My next tire will be 295/55-20 which is 3/4” wider than stock, again divided by 2, thats 3/8” on each side. My guess is that at the end they will be sticking out 2 3/8” off the fender. This set up is only good for non - off road truck.
  3. Jun 29, 2021 at 1:47 PM
    13igtymer
    Thanks for the reply. Do you have a picture on the front? I want to see the stance.
  4. Jun 30, 2021 at 7:17 AM
    FirstTruck
    Stock, for now
