  1. Jun 28, 2021 at 5:23 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Started the truck up, and played around with my new schmancy check valve for my brake booster vacuum line.
    Vacuum generated by engine means I had it backwards in this photo.
    Check valve should hold vacuum on booster when the truck is off. Lesson learned.
    Drive gingerly up the road to the chapel to make this post in crocs, underwear and a T-shirt. Brakes still feeling excellent.
    Played around with the vacuum line whuke truck was idling. Listened to booster. Hisssssssssss. Removed vacuum line, and no more hiss. Normal? Booster due for replacement?
    Yall tired of all my booster related questions? I post the same question about once a quarter. :rofl:
  2. Jun 28, 2021 at 5:23 AM
    And 12 in the middle
    NUDRAT, bmf4069[QUOTED] and Tundra2 like this.
  3. Jun 28, 2021 at 5:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Still can't find that damned squeak, but I have a new plan.
    I'll spray pb blaster, Kroil, WD-40 or other liquids on each fastener that I touched when I redid the front end one by one until I find that damned thing.
    NWPirate, onesojourner and Sirfive like this.
  4. Jun 28, 2021 at 5:48 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    The automovive equivelent of turn it off, then turn it back on:
    take it apart, then put it back together. But add grease.
    bmf4069 and Tundra2 like this.
  5. Jun 28, 2021 at 5:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't have that kinda time anymore. :rofl:
    When I find whatever it is, I'll make time though. I'll strip that whole front end if I have to. :muscleflexing::curls:
    Darkness and Sirfive[QUOTED] like this.
  6. Jun 28, 2021 at 8:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Felt like wrenching and ended up cleaning MAF and throttle body(CRC MAF cleaner and CRC TB cleaner) and plug change out....all was done 10K miles and 18 mo ago. All plugs looked good(.033/.034) compared to new(.031), plugs were still holding german tight. Placed an order with McGeorge for IG coils given orig/previous owner did not show records of change. While they still look in good shape(no cracks or arc marks), after 193K miles, I decided it's time....wanta see Denso decal if nothing else :)
    magnetized sparkplug tool from Napa....credits to PHM(RIP)
    Installing new spark plugs, over tightened my first one
    plugs - Denso K20R-U(gap .031)
    McGeorge Toyota online parts order....
    Ignition coils 90919-02259(replaces 90080-19027)
    Starter Motor(2.0KW) 28100-50100-84
    NUDRAT, oscardog86, hammeron and 8 others like this.
  7. Jun 28, 2021 at 8:32 AM
    Orange devil
    Orange devil New Member
    Working on some custom headlight filler panels 20210626_180141.jpg 20210627_215308.jpg
    NUDRAT, tacoguybill, CodyP and 12 others like this.
  8. Jun 28, 2021 at 10:13 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Orange devil we need to see more of your truck. These little teaser shots are not enough.
    By the way I forgot to mention, when I flat towed the beetle home I stayed with OD off at 60mph for 110 miles. Trans temp stayed at 149F and my indicated mpg for the trip was 14.5. Outside temp was around 80f. I couldn't even feel the weight on the freeway.
  9. Jun 28, 2021 at 10:33 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I Also played around with towing with OD off and on this weekend. On the way out I was trying to get through some hills and traffic and I got up to 220 in the torque converter. I had OD off. I was definitely pushing things and hanging with traffic. It was 92 degrees outside according to the truck. I only got to that temperature once. Most of the time it would get up to 210 by the time I got to the top of the hill. The pan almost got up to 200 once but it stayed in the 190's for the most part.
    On the way back OD was off on some of the downhills and flats. I did see a mpg better or so when I did that. There is no power to climb though. It was raining and temps were 40 degrees coolers or so overall. I was also not in a hurry.
    Sirfive and Darkness like this.
  10. Jun 28, 2021 at 10:45 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    How does that behave at highway speeds? Does it flap around at all?
  11. Jun 28, 2021 at 11:17 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Haven't tried it yet at highway speeds. I'm sure it will flap a bit but it does have a few horizontal reinforcement bars under the cover to maintain some rigidity along with velcro on the outer vertical edges.
    w666[QUOTED] likes this.
  12. Jun 28, 2021 at 3:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  13. Jun 28, 2021 at 3:55 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i want to see so much more.
    Orange devil[QUOTED] likes this.
  14. Jun 28, 2021 at 6:20 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    3 pieces need to go to powder coat... the de plasticifcation of my engine bay will commence soon.... looking for a nice aluminum coolant res and p/s res too. but thats later down the line
  15. Jun 28, 2021 at 6:35 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Got some snow on the big mtn last night so I took the Tundra up top and backpacked in to see if a fav lake had iced-off enough to soak some flies. Thought I'd share some frosty pics for those of you in hotter climates. A very purty lake nestled in a cirque at about 10.5K elev. The Tundra performs well on the high tundra, literally. Very close to home, blessed to live up here. Cheers! :cheers:
    [​IMG]2021-06-28_06-50-57 by GhostCreekMine, on Flickr
    [​IMG]2021-06-28_06-50-40 by GhostCreekMine, on Flickr
    [​IMG]2021-06-28_06-51-16 by GhostCreekMine, on Flickr
    Objective.
    [​IMG]2021-06-28_06-48-17 by GhostCreekMine, on Flickr
    Success.
    [​IMG]2021-06-28_06-50-12 by GhostCreekMine, on Flickr
    [​IMG]tkg 1 by GhostCreekMine, on Flickr
    [​IMG]2021-06-28_06-47-27 by GhostCreekMine, on Flickr
    Caught lots of Cutthrout Trout... didn't keep any. Good alpine adventure!
    [​IMG]2021-06-28_06-46-50 by GhostCreekMine, on Flickr
    NUDRAT, tacoguybill, MS22 and 15 others like this.
  16. Jun 28, 2021 at 6:47 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    How far is that from your house? How many months of the year can you get up there?
  17. Jun 28, 2021 at 9:46 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    The road is about 5 minutes away. Takes me roughly 45 min to wheel about 12 miles to the top.
  18. Jun 28, 2021 at 10:59 PM
    NWPirate
    Zach
    WA
    Thank you, looks amazing. Much appreciated!
    It was only around 116°F in WA today.
    Glock 40[QUOTED] likes this.
  19. Jun 29, 2021 at 2:08 AM
    First Gen Tundra Guy
    First Gen Tundra Guy New Member
    2001 SR5 2001 Limited
    It won't flap around at highway+ speeds if you secure the side velcro strips.
    NUDRAT and Lil Steve[QUOTED] like this.
  20. Jun 29, 2021 at 5:09 AM
    I feel like we all glossed over these metal Timing belt covers. What model are they off of?
    Darkness and Jack McCarthy like this.
  21. Jun 29, 2021 at 5:22 AM
    empty_lord
    05 rollover special
    3uz
    Jack McCarthy and onesojourner like this.
  22. Jun 29, 2021 at 5:28 AM
    Wonder why the switch to metal covers. Manifolds went form metal to plastic. Timing bet cover went from plastic to metal.
  23. Jun 29, 2021 at 5:33 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Can they be polished? Are we voting?
  24. Jun 29, 2021 at 5:33 AM
  25. Jun 29, 2021 at 5:38 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I've taken my truck on 10 adventures this year. One ski trip to CO, eight camping trips in the Ozarks and one in IA. The truck has been a fantastic upgrade over the old 4runner. Legendary.
    Double cabs are the best adventure vehicles.
    NUDRAT, CodyP, Darkness and 2 others like this.
  26. Jun 29, 2021 at 5:43 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Added some DIY splash guards made from the non slip rubber mat stuff from carpet section @HD. Not sure if I like it or not.
  27. Jun 29, 2021 at 5:45 AM
    Looks good to me. I mean maybe I wouldn't have cut them out with rusty garden shears, but they work. :rimshot: sorry, I got jokes this morning.
  28. Jun 29, 2021 at 5:57 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Hey! That shits tough to cut with scissors. If you're referring to the white that's the wax pencil. Lol.
  29. Jun 29, 2021 at 6:13 AM
    Maybe because the plastic timing covers can crack. At least mine did.
  30. Jun 29, 2021 at 6:15 AM
    3uz, eh? Time for me to hit the salvage yard! :D
