2003 overhead console upgrade?
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, Jun 27, 2021.
  1. Jun 27, 2021 at 12:33 PM
    RR60
    RR60 [OP] New Member
    2003 SR5 Tundra long bed
    I noticed the overhead consoles are upgraded over my 2003.
    Would a 2004 - 2006 ebay one bolt right in.
    Does the home link button actual work well with newer garage door openers.
    Thanks
  2. Jun 27, 2021 at 1:17 PM
    Which console are you looking at? the one for the Tundras that came with a sunroof?
  3. Jun 27, 2021 at 1:46 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    This? If so it comes on the limited dbl cabs...pretty sure it would require a lot of fab work.
  4. Jun 27, 2021 at 2:18 PM
    The mounting holes are similar placement in the console, but not sure they line up with the holes in the AC. Don't imagine it would take much fab work. The electronics likely couldn't be hooked up without a lot of work though.
  5. Jun 27, 2021 at 3:07 PM
    RR60
    Yes, something like that pic. Also mine is a 2003 Regular cab and no sunroof.
  6. Jun 29, 2021 at 3:46 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I'm afraid it would take more work than you think. I looked into that with my 2003 AC and bought one to try and fit. None of the holes matched up and the space would require cutting of more than just the headliner. I think the rear-view mirror was different too. The 2003 it's connected to the windshield and the newer console has the mirror attached.
  7. Jun 29, 2021 at 4:05 PM
    RR60
    Thanks not worth the trouble.
  8. Jun 29, 2021 at 4:59 PM
    Bummer! looked like a cool mod.
