My first Tundra, time for cool tunes!
Discussion in 'Audio & Video' started by ravingndrooling, Jun 26, 2021.
  1. Jun 26, 2021 at 4:55 PM
    ravingndrooling
    ravingndrooling [OP] New Member
    2021 Gray TRD
    Good afternoon all, long time listener, first time caller…
    Gots my new Tundra CM(non JBL) a couple days ago and am getting everything together that I need to upgrade my tunes. Any and all opinions are welcome, as well as thanks in advance! Here we go…
    I already have my amps- Audiocontrol D4.800 and an LC1.800 as well as a pair of Alpine Type R components and a pair of Type R 10s in a sealed box. I will be keeping the stock HU for the time being and the Alpines aren’t necessarily going in this install.
    My first thought is to get another set of type R components and hook up both pairs and calling it good. Could even get a pair of coaxial for the rear fill and just use the Type Rs in the front…
    Second scenario would be an Audiofrog GS front stage and maybe a pair of Sundown SDs in a vented box behind the rear seat.
    Third would be a Dynaudio Esotan front stage and Sundowns.
    I will be mounting the tweeters in the sail panels, and will need another set of sails. Is it worth it to source a pair with the tweeter grills? Any one know how big of a tweeter I can mount in the prefab sails behind/flush in the stock grill holes? Should I just stick with the stock style and flush mount my tweets?
    I’ll need some speaker adapters as well, if I go with the Alpines or Audiofrogs, I’ll be using 6x9 mids in the front. From what I’ve read here, there are a couple sources most people use for adapters. I’ll need a couple wire harnesses as well, suggestions for trouble free options? I will be using passive crossovers just for the sake of keeping fronts and rear speakers. The Alpine sub will be in use until I upgrade my HU, although it may end up being in a ported style box.
    Amps will be mounted under passenger seat, anyone have a good templet for an amp rack?
    Sound deadening, wiring up the amps, running speaker wire I gots…although I’m sure I’ll have more questions as I get there. I would be interested to hear from those running Dyns or ‘Frogs for sure! Depending on my mood and what I can find, I have contemplated adding some mids to the dash holes and running them active and the components with their passive crossover. If I’ve missed anything, please, help a brother out! Thanks!
  2. Jun 26, 2021 at 5:23 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  3. Jun 27, 2021 at 2:54 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
    Sounds like a nice plan
  4. Jun 27, 2021 at 3:21 AM
    Welcome from NY.
  5. Jun 27, 2021 at 6:11 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Jun 27, 2021 at 6:17 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    Welcome:thumbsup:
  7. Jun 27, 2021 at 7:42 AM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon
  8. Jun 27, 2021 at 12:33 PM
    ravingndrooling
    2021 Gray TRD
    Thanks all, glad to be here!
  9. Jun 27, 2021 at 1:44 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
