How rare is the 8 Ft bed Tundra MAX?
Discussion in '1st Gen Tundras (2000-2006)' started by TonyinCC, Jun 27, 2021.
  1. Jun 27, 2021 at 7:51 AM
    TonyinCC
    TonyinCC [OP] New Member
    Tony
    White 2005 Tundra MAX 4WD regular cab 8Ft bed 4.7 Automatic 182K miles
    Currently has 265/75/16 AT tires on steelies.
    I am in Cape Coral, FL and just bought a 2005 Tundra Max 4WD with the 4.7 and Automatic. Regular cab with a bench cloth seat that actually fits 3 adults since there is no center console.AC ,Vinyl floor mats,and sliding rear window.
    It has Toyota chrome badges on the tailgate that say Tundra Max 4WD.
    I have very rarely seen 8 foot bed Tundras before so I grabbed this one.
    I can't seem to find ANY info on this model.
    When doing searches for parts, this configuration doesn't even show up.
    It was owned by an engineering/survey firm locally in SW Florida and it has a company fleet number in the 30's so was probably a special order and they must have had at least 30 trucks in their fleet... It has 265/75/16 all terrain tires on steelies, was that size was standard on this configuration? Will have to check with GPS to see if speedo is reading correct speed.
  2. Jun 27, 2021 at 8:17 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    I'm interested to learn what a Tundra MAX is.
  3. Jun 27, 2021 at 8:19 AM
    I think that was the previous owners nickname for the truck, or something like that and they added the badge
  4. Jun 27, 2021 at 8:19 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Tundra MAX is a dealer or regional package, it's like 'special edition'.
  5. Jun 27, 2021 at 8:21 AM
    ^^^What Rex said^^^
    Welcome from NY.
  6. Jun 27, 2021 at 8:25 AM
    TonyinCC
    Tony
    I can't even find the single cab 8 ft bed configuration when searching for parts. So maybe it came with big all terrain tires from the factory? Any info on the package? The badges and their placement sure seem like they were factory.
  7. Jun 27, 2021 at 8:27 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  8. Jun 27, 2021 at 8:51 AM
    Go to Toyota's owners website and put in your VIN#, you will get all the information about your Tundra.
    :worthless:
    Rex Kramer likes this.
  9. Jun 27, 2021 at 9:19 AM
    TonyinCC
    Tony
    I just checked the website it came back as a 2005 Tundra DLX. Never seen info about that model either...... Maybe DLX is the generic default for a regional or dealer special edition package? Left truck at the tire shop for balancing will post some pics later...
  10. Jun 27, 2021 at 9:25 AM
    Rex Kramer
    Georgia
    My 2007 SR5 is also identified as a DLX on Toyota's site.
  11. Jun 27, 2021 at 9:26 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  12. Jun 27, 2021 at 9:47 AM
    TonyinCC
    Tony
    AC Air Conditioner
    CK All Weather Guard Package
    FE 50 State Emissions
    FW Full Wheel covers
    LD Limited slip Differential
    TO Towing package
    WR Sliding rear window
    FN 43 interior
    056 Natural White exterior
    • Model 2005 Tundra
    • Grade DLX
    • Exterior Natural White(056)
    • Interior Fn43
    • Engine 8-CYL
    • Body Type Regular Cab
    • Drive Type 4WD
    • Transmission 5AT
    • Selling Dealer
    • Servicing Dealer None Selected
    • Date of First Use March 03, 2005
    Additional Vehicle Details
    Order Date:
    10/2004
    Plant of Manufacture:
    Body Style:
    REGULAR CAB 4X4 V8
    Tire Make/Brand:
    Tire Size:
    Spare Tire Brand:
    PORT OR FACTORY INSTALLED EQUIPMENT
    • AC Air Conditioner
    • Factory
    • CK All Weather Guard Package Includes
    • Factory
    • FE 50 State Emissions
    • Factory
    • FW Full Wheel Covers
    • Factory
    • LD Limited Slip Differential
    • Factory
    • TO Towing Package w/ClassIV Hitch,130 Amp Alternator,Transmission oil Cooler,7 Pin Connector w/Converter
    • Factory
    • WR Sliding Rear Window
    • Factory
    • mechanical & performance
      282 HP 4.7L i-Force V8 w/VVT-i Engine 5 Speed ECT-i Automatic Transmission Touch Select 4 Wheel Drive System Coil Spring Double Wishbone Ind Fr Suspension w/Stabilizer Bar Power Assisted Rack & Pinion Steering Power Vented Fr Disc & Rr Drum Brakes 16" Steel Wheels w/P245/70R16 Tires
    • comfort & convenience
      Cloth Bench Seat w/Adjustable Headrests Fold-Down Center Armrest AM/FM/CD w/4 Speakers Speedometer,Gauges & Digital Clock Windshield Wiper w/Mist Control Cigarette Lightr & Two 12v Power Outlets Dual Cupholders 1 Driver & 2 Pass Assist Grips Vinyl Flooring 4 Pin Trailering Wire Harness
    • safety
      4 Wheel Anti-Lock Brake System Dr & Fr Pass Dual Stage Airbags w/Pass Airbag Cut-Off Switch 3 Point Dr & Pass Seat Belts w/Pretensioners & Force Limiters Tire Pressure Monitoring System Side-Impact Door Beams Center High Mount Stop Lamp
    • exterior
      Color-Keyed Grille & Chrome Bumpers Dual Outside Mirrors Double Wall Cargo Bed w/Tie Down Hooks Locking Tailgate w/Rail Cap
    No SR5 badges so I don't think it is an SR5, just Tundra MAX 4WD on tailgate. That is the only badging on the entire truck aside from the front grill. Bench seat is straight across no notch, has 3 headrests and a fold down center armrest.
    FrenchToasty and Sirfive like this.
  13. Jun 27, 2021 at 9:57 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Convert it to a diesel, and you can have a 1-of-1 tundra max-d.
    Tundra2 and FrenchToasty like this.
  14. Jun 27, 2021 at 9:58 AM
  15. Jun 27, 2021 at 10:03 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wait? The bed I bought for my truck also said tundra max. Is it actually a thing? LOL
  16. Jun 27, 2021 at 10:07 AM
    empty_lord
    05 rollover special
    [​IMG]to me it just looked like a badge someone slapped on
    Rex Kramer and Darkness like this.
  17. Jun 27, 2021 at 10:13 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    ive seen the ‘kylie’ edition audi s5’s. And the ‘lesliey’ edition s550’s. Ive thought about a ‘f*** off’ edition titan for years… my tundra is too classy. Maybe more of an ‘excuse me’ edition.
  18. Jun 27, 2021 at 10:15 AM
    empty_lord
    05 rollover special
    mine grew up to an TRD
    pff802, tunyota, abcinv and 5 others like this.
  19. Jun 27, 2021 at 10:20 AM
    TonyinCC
    Tony
    I will take a pic of my truck once I get it back. I wonder how many of this package were sold and how widespread.
  20. Jun 27, 2021 at 10:22 AM
    I always wanted to modify the work Nissan to the “TIT”
    I was the only one driving it for a while so I didn’t want to riskit for the biscuit
  21. Jun 27, 2021 at 10:28 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If the Motor Trend review I ran across was accurate, it’s whoever wanted to pay $411 for the Max truck package !
    DJenerated and Black Wolf like this.
  22. Jun 27, 2021 at 10:36 AM
    empty_lord
    05 rollover special
    sooo... it is a thing? i wish i had the vin off the truck i got the bed from
  23. Jun 27, 2021 at 10:44 AM
    TonyinCC
    Tony
    So is it sort of a sub-model like SR5 then? Max package #1? That implies there was more than one package. What is bright pop up? Tool box is long gone from mine if it had one. The badges are pretty cool.
  24. Jun 27, 2021 at 10:54 AM
    jimf909
    Washington or Idaho
    It sounds like a work truck Pkg. I wonder what a Bright Pop-Up is? Possibly a reflective cone for roadside visibility?
  25. Jun 27, 2021 at 10:56 AM
    empty_lord
    05 rollover special
    That would be my guess
  26. Jun 27, 2021 at 11:04 AM
    TonyinCC
    Tony
    Mine was definitely a work truck. In its new semi-retired life it will probably carry 50-100 loads of free mulch a year from the county for my yard and carry a mini bass boat in the bed.
    Rex Kramer and FrenchToasty like this.
  27. Jun 27, 2021 at 11:06 AM
    We need pics of this mini bass boat too, sounds fun!
  28. Jun 27, 2021 at 11:08 AM
    TonyinCC
    Tony
    It will be a Twin Troller X10 , I am planning to order it very soon...
    jimf909 and FrenchToasty like this.
  29. Jun 27, 2021 at 11:45 AM
    jimf909
    Washington or Idaho
    I just watched a couple of vids for the boat. What a cool little boat, it looks like it's the first gen Tundra of small boats.
    https://youtu.be/gJBAYB3OLTc
  30. Jun 27, 2021 at 11:50 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The only Max I knew of
    tvpierce, DJenerated, tunyota and 6 others like this.
