"We got no food, we got no job, our SEAT'S TRIM is falling off!" - LLoyd Christmas
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 21, 2021.
  1. Jun 21, 2021 at 10:53 AM
    KNABORES [OP] Sarcasm incoming
    Anyone else have this issue? Anyone have a lasting solution?
    My driver's seat trim at the seat back hinge has been falling off since I bought the truck 16 years ago. I drilled a small hole and ziptied the two pieces together, but the main issue is it won't stay clipped to the seat frame. When you sit in the seat, it presses down on the trim and dislodges it.
    -Tacky and unhappy in Arkansas
    Darkness likes this.
  2. Jun 21, 2021 at 11:00 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    204534501_10159194868645275_168363229054_9899412bbdf3fbf8ad8892b2c75125bd71c79ff4.jpg
    grandpa bolted his.
    bmf4069, NWPirate, Beefnbread and 3 others like this.
  3. Jun 21, 2021 at 11:03 AM
    Hmmm. On the extreme end. Certainly sturdy.
  4. Jun 21, 2021 at 11:11 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I wholly approve of grandpa's mod. :bowdown:
    (pssst, it's Mangler Monday)
    bmf4069, Beefnbread, Sunnier and 5 others like this.
  5. Jun 21, 2021 at 11:12 AM
    Also Jealous of the adjustable lumbar support. I've always joked that my Limited meant limited options. No keyless, No power passenger seat, hell until recently I didn't even realize many of the Limited's came with cloth! Now I know it also didn't come with adjustable lumbar support. Maybe it wasn't available in 2000.
  6. Jun 21, 2021 at 11:19 AM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    Alaska
    2020 DC TRD-OR, Cement
    BEST MOVIE EVER!
  7. Jun 21, 2021 at 11:20 AM
    Honestly, I would try to source those parts from a junkyard. Maybe replace the entire seat if you can find one the same color.
    bmf4069 likes this.
  8. Jun 21, 2021 at 11:23 AM
    Hmmmm, wasn't expecting an even more extreme repair solution. Thought the giant lag bolts would keep that title. Junkyard Tundra's are hard to come by around here. Scoring a Tundra seat in better condition than mine would be like capturing a unicorn with hen's teeth. The issue is the flimsy plastic friction clip used to secure the trim to the seat frame. The seat is fine, albeit worn with time and sun fade. The trim is in decent shape. It just won't stick.
    Glock 40 likes this.
  9. Jun 21, 2021 at 11:24 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Slap a new plastic christmas tree at the front and add about 12 feet of 3M VHB tape and you should be set.
    KNABORES[OP] likes this.
  10. Jun 21, 2021 at 11:40 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I had to do the same with my father's '98 Acura RL, I used measured lengths of 1/2 CPVC pipe as internal spacers.
  11. Jun 21, 2021 at 11:40 AM
    Hadn't noticed that the front clip was removable. Upon further inspection. it is. Dug through my bin of many friction tabs and found one really close. Fits in there nicely. We'll see how it holds up.
  12. Jun 21, 2021 at 11:45 AM
    I'm quite jealous of your stash you have there and I appreciate your organizing.
  13. Jun 21, 2021 at 12:20 PM
    Amazon score. Those little tabs always break when disassembling doors and dashes and outside trim bits. This little bin of friction tabs has been great. Came with a set of panel tools as well. In the $15 neighborhood if I remember right.
  14. Jun 21, 2021 at 12:51 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Not sure when they were added but my 06 DBL Cab has this option.
    des2mtn likes this.
  15. Jun 21, 2021 at 1:25 PM
    Legender
    Legender New Member
    Carlton
    DFW
    2006 Tundra DC Limited 2WD
    None yet.
    My new to me 2006 Limited DC came with cloth but previous owner installed some cheap leather that already needs replacing on the driver's seat. I do have the lumbar support and power seat on the driver side at least. It certainly has limited options/features compared to the same year Toyota Avalon. But it is a truck after all.
  16. Jun 21, 2021 at 2:10 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Grandpa is no mangler. Thats just how you fix something once.
    201421517_10159195250095275_219270694759_16a0e350b5f8f96abe9369507f8fb3ae2a47580e.jpg
    drilled and tapped his wheel key, then ground down a piece of all thread so you dont have to fish for it.
    202932950_10159195249415275_878423630831_ad1419b1fc28128c008a633c944d104bb28b3c6b.jpg
    get a good deal on a different size battery, just make a new stick.
  17. Jun 22, 2021 at 8:24 PM
    NWPirate
    Zach
    WA
    One of the first things I fixed when we got the rig, drove me crazy.
    I removed the inner piece of plastic trim, my jeans were always catching on it anyway.
    I drilled a hole through the plastic molding on the inside and on the metal tab. Grabbed a thick HD zip ty and pulled it toight.
    Been happy since.
  18. Jun 26, 2021 at 7:44 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Upgrade to a Sequoia driver's seat...same deal. Put a power one in my 2000 with cloth bucket...and it goes further back just enough to not cramp my hinky left knee...because of that weird floor pan plateau on the driver's floorboard.
