  1. Jun 25, 2021 at 8:03 AM
    #6931
    Kung
    KG, VA
    What bwh said. I actually had some installed post-build (into my house) to ensure proper airflow.
    bwh likes this.
  2. Jun 25, 2021 at 8:45 PM
    #6932
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Installed a few blink cameras I ran across last minute on prime day. Install wasn't too bad. 3 cameras around the house at points of entry. Quality seems good and had great reviews. Time will tell how much I like them.
  3. Jun 26, 2021 at 4:18 AM
    #6933
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    New house has bamboo flooring. Seems the installer didn't know what he was doing. Seller of the house has been super cool with this because the issues didn't appear until humidity shot up the week of closing and it totally missed home inspection.
    We went from this.
    VJiMQf99J92UbexvASmIHl2_6YGyQqZq2QJ8xjg9_67c0c1a5f5593dca2a79644ac4f4b46fe94c75d9.jpg
    To this.
    Oyxx-RcByJt0UMm5BYrVd7lPcFmNC7SFLr4hD8LC_efdecd942a6a0488e89e9918b8c20dd8a576b130.jpg
    To this
    mUYAbCZFuDupRYdoOSx_GqU9akHssUljGIQYDTKA_a96fde73ad586657f968d4624fc06638b71ba51a.jpg
    Where we found he glued the planks to the transitions.
    Jix8JvX57ozQnGR-q_udxamEnQ_L9uSopww_KC4A_b4e31fec4a0118a6f5e4d9095f6bdd3e10f64057.jpg
    I had the guy doing the repair (I can't get down there because arthritis in my knee) cut transitions between the rooms. Original installer had it all flowing from one room to another. When he cut this section the floor shifted 1/8 inch from the releif of stress the floor was under. CHeck the seam lines of those planks. They were single planks before the cut.
    lx01MnxhMxHuexQ5evZyVjyE-ccqYJNw04jUkPr5_06349812804ad940e9a9de874f96b43c44a914dc.jpg
    And now we have this. The installer didn't clean up the floor before installing the bamboo. Nails from the carpet tacks were still in place. He didn't undercut the door jambs, he cut out the planks where they were snug fit and no room for movement.
    0xW8Qbcpjtk2KCOxuMjpNvxz3kLMMbswt6K9ClvY_4386aad4c9cfcb50384cc07f8b1a576436e36663.jpg
    There's some subfloor issues but it's a 120 year old house. Those will be addressed. Now we have to get some transition around the fireplace harps.
  4. Jun 26, 2021 at 4:44 AM
    #6934
    Tremor F-250, Roush Mustang, Jeep Crawler
    These are from developers that need them out of the way.
  5. Jun 26, 2021 at 5:32 PM
    #6935
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    9444C848-E81D-43F1-AD2F-1C4A4F13DBB3.jpg New faucet in the master bathroom. I hate plumbing almost as much as painting.
  6. Jun 26, 2021 at 8:42 PM
    #6936
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Copied you for our backyard. It adds a nice touch for sure!
  7. Jun 26, 2021 at 10:55 PM
    #6937
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Continuing from 7112. Roof wood is done and plumbing has started on the interior of the house. Sheathing inspection then the exterior wrap and roof to be completed. It’s been very dry here so all the water on the inside has vaporized. Instead of a third car garage, I have the RV option.
    B1DC2A33-AF05-43E2-BB9D-0018D5199971.jpg CC6ECAF4-1773-4796-B14F-2458CBE61154.jpg 4DA67193-EB98-41C9-B4AE-0F289716F8DF.jpg 41CED4C1-E139-4ECA-BF03-C066BA317032.jpg 1148CF7B-E965-48B4-B9DD-5E70175A856D.jpg E4EA076E-6824-44C3-9208-AEED26E9A7C7.jpg E756E7A8-9B2E-484A-95A7-C241E6BA95CC.jpg
  8. Jun 28, 2021 at 4:34 AM
    #6938
    Rolodetective
    Rolodetective Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    Nice! Did you get the same brand as KPARROW? I'm about to do the exact same thing, but as usual analysis paralysis is kicking in and the endless process of evaluating the reviews results in me not buying anything.
  9. Jun 28, 2021 at 5:24 AM
    #6939
    alee891
    Now/here
    Shitbox
    Yep, same lights. Picked them up for a slight discount on prime day. I put 16 total in our backyard.
    Rolodetective[QUOTED] likes this.
  10. Jun 28, 2021 at 7:16 AM
    #6940
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Adding sheds. Need to level it better and build the second shed. Thoughts on best way to level? Sand?
    AZTundra, drobb and Fotnot like this.
  11. Jun 28, 2021 at 8:42 AM
    #6941
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd probably use pea gravel. Sand may wash away too easy.
    Kung and NewImprovedRon like this.
  12. Jun 28, 2021 at 9:28 AM
    #6942
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I'd third that motion. "Form" it in with some ground-contact wood and level those up, then fill with pea gravel.
    BlueRibbon4x4 likes this.
  13. Jun 28, 2021 at 10:32 AM
    #6943
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I just did my retaining wall and my basement hardwood floor. Get some Puc when I get home
    Fotnot likes this.
  14. Jun 28, 2021 at 10:43 AM
    #6944
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  15. Jun 28, 2021 at 11:02 AM
    #6945
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Base rock, ¾ rocks…since it not anything big, you could go 2-3 inches. Or use 2x4 to form a concrete pad level it and pour
  16. Jun 28, 2021 at 11:50 AM
    #6946
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    We finally got our new driveway and front porch/sidewalk installed last week
    Now I just need to keep it sealed on a yearly basis. Anyone have suggestion on good sealer?
  17. Jun 28, 2021 at 4:43 PM
    #6947
    Buckeye1977
    Buckeye1977 New Member
    Nice huge driveway! Less mowing love it!
    personally I would get a sealer from your local concrete company vs HD,Lowe’s, menards
    kparrow likes this.
  18. Jun 28, 2021 at 8:33 PM
    #6948
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    It’s not perfect as I kept getting particles from under the window frame around the edges but got some frosted window film installed on the front door and front window for some privacy. Will be adding a doorbell cam soon so no need to look through. Let’s hope the edges stick after they dry out. Had to do it fairly quick between feedings of kiddo while she’s asleep.
  19. Jun 28, 2021 at 9:33 PM
    #6949
    drobb
    Lol…..We had almost the exact same sign when our kids were young. I know the feeling!
    kparrow[QUOTED] likes this.
  20. Jun 28, 2021 at 10:53 PM
    #6950
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  21. Jun 29, 2021 at 5:02 AM
    #6951
    purplenova
    Tom
    Ohio
    I will getting the sealer from a local concrete company that one of my friends work for.
    Talked to him about it yesterday. At $172.00 for 5 gals, a little pricey, but its better than
    replacing all this again...
  22. Jun 30, 2021 at 12:14 PM
    #6952
    Had new gutters installed last week. Discovered the Hardie Board is rotted in this pic where the end of the gutter touches it. Previous owners never installed any diverter/flashing to keep rain off the siding.
    How difficult would it be to replace that one rotted piece? Zero experience with anything like this.
  23. Jun 30, 2021 at 12:19 PM
    #6953
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Hardie backer don’t rot, they water proved and fire proved.
  24. Jun 30, 2021 at 12:20 PM
    #6954
    csuviper
    Broomfield, CO
    Cant tell what that taller black piece is but you need a kickout flashing if that wood is rotted out
  25. Jun 30, 2021 at 12:24 PM
    #6955
    I know. I asked the gutter guy to install said flashing and he did not install what I asked. But what I'm asking is how hard it would be to replace that single piece of Hardie siding. The white piece of trim leading to the column isn't rotted yet but the brown piece of siding is.
  26. Jun 30, 2021 at 12:27 PM
    #6956
    Well, I'm not sure what to say but this one is rotted. Wish I had snapped a pic before he re-installed the new gutters over it.
  27. Jun 30, 2021 at 12:28 PM
    #6957
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Have to take out gutter, maybe a piece of flashing, ply the second piece out a little and take out the nails, cut a new piece put it in and face nail.
  28. Jun 30, 2021 at 12:33 PM
    #6958
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    All siding started at the bottom, need a lot of skills to change bottom piece maybe repair is a better option
  29. Jun 30, 2021 at 12:34 PM
    #6959
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Cut out the rot and use epoxy or bondo to repair
    Melikeymy beer likes this.
  30. Jun 30, 2021 at 1:35 PM
    #6960
    AZTundra
    Paul
    Phoenix, AZ
    Patio furniture was delivered today. We also got a large cantilever umbrella that I'll set up this weekend after I get the sand for the base. The umbrella will cover a small portion of the shallow end of the pool. The umbrella is 11x11.
