'05 Lower Ball Joints
Discussion in '1st Gen Tundras (2000-2006)' started by jberkut4, Jun 24, 2021.
  1. Jun 24, 2021 at 1:22 PM
    jberkut4
    jberkut4 [OP] Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Figured I would get new lower ball joints before even thinking about buying a new wheel and tire setup, after looking at mechaincs estimate, I found the parts he was going to use. He quoted for the Movotech TXMS86564 and 86565 parts numbers, has anyone used the movotechs? found them for a lot cheaper online than what hes able to get them for, just wanted to see what others opinions on them were.
  2. Jun 24, 2021 at 1:25 PM
    Noooooooooo! No Mevocraps for Lower Ball joints! That is a rapid fail part, likely the cheapest he could source. Factory is best, not cheap, but reliable. A few (myself included) have had luck with Moog.
  3. Jun 24, 2021 at 1:26 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Do you have a link to where you got the moogs from? And yeah thats why i figured id ask lol
  4. Jun 24, 2021 at 1:28 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I no longer do parts look ups for your year, but if I was you I’d do an online search for Toyota Parts Programme and only use OEM Lower Ball Joints. Your local Stealer may participate for free pick up.
    Plug in your VIN# and will probably find them priced in the $110-140 range for Toy OEM.
    flyfisher and FrenchToasty like this.
  5. Jun 24, 2021 at 1:29 PM
    I would price the Toyota OEM lower ball joints at one of the online dealer discount sources and compare. It's worth the cost if you can afford it. If money is tight, then the Moogs I ordered came from RockAuto.
    More Information for MOOG K80522 (rockauto.com)
  6. Jun 24, 2021 at 1:29 PM
    Fred
    Hand Protectors
    Do new OEM Bolts too!
    KNABORES likes this.
  7. Jun 24, 2021 at 1:30 PM
    I know for a fact one of mine is stripped right now.
  8. Jun 24, 2021 at 1:30 PM
    2mchfun
    Go factory on lower ball joints, when they go it's not a pretty site! Wheel falls over sideways and the chassis hits the pavement.
  9. Jun 24, 2021 at 1:31 PM
    and the wheel hits the fender and the fender hits the door and the truck hits another car or a tree or a ditch. indeed.
  10. Jun 24, 2021 at 1:33 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Ha! Same here. I'm gonna tap the knuckle (insert meme of choice) on one of the next Mangle Mondays.
    Lil Steve likes this.
  11. Jun 24, 2021 at 1:45 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Pick your preferred Toyota parts retailer and confirm your VIN with them.
    x1 Driver Lower Ball Joint - 43340-39595
    x1 Passenger Lower Ball Joint - 43330-39825
    x8 Bolt Flange - 90105-A0187
  12. Jun 24, 2021 at 1:47 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    I think I was able to find OEM ones for about $125 each, does that sound about right?
    Parts are 43330-39825 and 43340-39595
  13. Jun 24, 2021 at 1:50 PM
    Fred
    Hand Protectors
    Do new bolts, too! Price is right!!!
    des2mtn likes this.
  14. Jun 24, 2021 at 1:53 PM
    des2mtn
    SW
    Tonto cover
    tnr6769 likes this.
  15. Jun 24, 2021 at 1:54 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Just added the new 8 bolts, website I was able to find them on is Checkered flag toyota. Not sure if its an official toyota website, but should this site be fine to order on?
    des2mtn likes this.
  16. Jun 24, 2021 at 1:59 PM
    Fred
    Hand Protectors
    Trying to keep this simple: If your local Stealer has Online Pricing (Parts Programme) then you may be able to pick up locally saving any shipping cost to your home. Sometimes shipping is $$$ and sometimes no big deal. I have a local that is close and can pick up free. The Parts Dept is helpful, too.
    If shipping is about the same across all Stealers, then shop the cheapest one and just ship it to your house.
  17. Jun 24, 2021 at 4:29 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    I was able to find a website thats only charging $12 shipping for everything together, so I think I am going to go with them. Also going with the ranco 2.5 inch leveling quick struts, since I need new shocks anyway and want to replace the cheap 3 inch block up front
  18. Jun 24, 2021 at 4:43 PM
    Cummins3500
    Logan
    My local stealer prices matches. I find it the cheapest I can online then call those incompetent idiots, they order it from the warehouse, and Parts in hand next day.
  19. Jun 24, 2021 at 5:19 PM
    Fred
    Hand Protectors
    This is another good way to do it.
  20. Jun 25, 2021 at 5:07 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I paid 126.81 per BJ about a month ago from a dealership an hour and half away from me. Why the bolts? Just incase they are stripped or is there something that I have learned on here where they need to be replaced each time? Now y'all got me worrying lol.
  21. Jun 25, 2021 at 5:21 AM
    Applying torque during install will stretch the bolt, and when torqued beyond it's specs, can damage the bolt. The threads can strip, the head can twist in addition to stretching. Retorqueing this bolt could result in a lack of stretch (already stretched) which leaves less holding power and could even result in breakage. If you've only ever used the bolt for it's designed purpose, always used a torque wrench to apply the prescribed amount of torque and it hasn't been subjected to excessive heat or corrosive compounds, you could reuse the bolt. External engine heat isn't enough to matter. Brakes typically do not get hot enough to matter, although they can in some situations. These lower ball joint bolts are subjected to corrosive conditions in some areas. Are under a good deal of stress (holding the front suspension together) and it would be good practice to change them for a few bucks vs. the catastrophic failure cost. I have re-used mine being in a non-corrosive area and using a torque wrench to install, but I still have one that stripped. It may have been cross-threaded during install. New bolts would be the way to go.
    des2mtn, Hi06silver and FrenchToasty like this.
  22. Jun 25, 2021 at 5:33 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    This is what I was leaning towards but wasn't going to describe it quite that well. Thanks! Looks like I'm getting new bolts even though they've been done right from my workings.
  23. Jun 25, 2021 at 10:58 AM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Local dealership wants about $150 per ball joint, but said they would price match if other dealerships online were 125 each. Does anyone know a website link to other dealerships that would be cheaper? doesnt have to be in my state, just need to prove others are cheaper
  24. Jun 25, 2021 at 12:37 PM
    flyfisher
    flyfisher Member
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
  25. Jun 25, 2021 at 12:57 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
  26. Jun 25, 2021 at 2:11 PM
    jberkut4
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Got my local dealer to price match everything, Total is going to come out to $260 including the 8 new bolts, thanks for all the help everyone. Do OEM ball joints need to be greased after installing?
  27. Jul 7, 2021 at 8:19 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
  28. Jul 7, 2021 at 8:27 AM
    des2mtn
    SW
    Tonto cover
    Glad it worked out for you. The OEM LBJs are sealed and they don't need greasing. Should be good to go for another 100k/ 10 years at least.
    No experience here, sorry.
