Bad Oil Leak 2004 Double Cab 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by gargra03, May 14, 2021.
  1. May 14, 2021 at 8:20 AM
    gargra03
    gargra03 [OP] New Member
    Gary
    2005 Tundra DC
    leveling kit MT Tires LED Camper Shell
    Hey guys,
    When I got home yesterday I noticed a large puddle of oil in the driveway under my 04 Tundra. It had not been driven that day so I climbed underneath and there is oil constantly running out where the engine and trans bolt up together. Has anyone ever seen this before? Even while parked and not running there is a steady drip.
  2. May 14, 2021 at 8:23 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sounds like a rear main seal has failed completely. I don’t remember if there’s oil galley plugs back behind the trans or not. But either way, transmissions gotta come out
  3. May 14, 2021 at 9:15 AM
    gargra03
    Gary
    2005 Tundra DC
    Thanks, looks like I am going to try and limp it over to the shop this weekend, really sucks I just had the timing belt and pump done.
  4. May 14, 2021 at 9:17 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    My redflagometer goes up when someone just had something done.
  5. May 14, 2021 at 9:23 AM
    empty_lord
    05 rollover special
    Considering the water pump and timing belt are on different sides of the motor this is much less likely. BUT. If the engine was really overfilled with oil, you could end up with a random extreme failure of a seal like this
  6. May 14, 2021 at 9:28 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    If they pulled the valve covers they could have forgotten to reseal the back U plugs and that would leak bad
    15whtrd likes this.
  7. May 14, 2021 at 9:32 AM
    empty_lord
    05 rollover special
    This is very much true. But I don’t know why they’d remove the covers for a t belt replacement. Unless they did cam seals too
    15whtrd likes this.
  8. Jun 16, 2021 at 4:55 AM
    gargra03
    Gary
    2005 Tundra DC
    Just to update, finally pulled the trans out and it is not coming from the rear main, the flywheel has to come out next.
  9. Jun 16, 2021 at 4:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Bummer. Snap some pics if you can.
  10. Jun 16, 2021 at 5:00 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    On all the 2UZFE timing belt/wp's I've done, I never touched anything that would cause an oil leak.
    Glad it wasn't your rear main. Too bad you had to pull the tranny to diagnose that. My 05 had a rear main fail four years after I bought it new, so the factory warranty covered the whole repair.
  11. Jun 16, 2021 at 5:12 AM
    gargra03
    Gary
    2005 Tundra DC
  12. Jun 16, 2021 at 5:16 AM
    Fred
    Hand Protectors
    Thanks for the pics. Looks like you’re tracking things back to the Transmission being the leak?
  13. Jun 16, 2021 at 5:24 AM
    gargra03
    Gary
    2005 Tundra DC
    yes sir, at this point it looks to be more of a transmission leak and the flywheel is coming out today. Should know more once that happens.
  14. Jun 16, 2021 at 12:54 PM
    speedtre
    speedtre New Member
    Inland Northwest
    So it turns out the fluid was ATF and not engine oil?
    Fosters2004TundraV8 likes this.
  15. Jun 16, 2021 at 7:47 PM
    empty_lord
    05 rollover special
    only 2 things that can leak there (well 3.. but coolant is obviously not oil.. trans fluid can be confused if its burnt. Transmission input seal. (VERY RARE unless the trans has been out before.) or rear main seal/retainer
  16. Jun 18, 2021 at 3:42 AM
    gargra03
    Gary
    2005 Tundra DC
    The guys at the shop replaced rear main and pump seal, should have it back today just waiting on trans mount to show up.
  17. Jun 18, 2021 at 4:45 AM
    Fred
    Hand Protectors
    So the Rear Main was a problem.
    The Pump Seal you refer to is the Oil Pump Seal on the front of engine?
  18. Jun 18, 2021 at 7:02 AM
    gargra03
    Gary
    2005 Tundra DC
    Yeah rear main seal adapter, I believe the pump seal is called auto trans fluid pump seal. They also discovered 3 broken bolts where the transfer case mounts up.
    Fosters2004TundraV8 and ToyoLife like this.
  19. Jun 18, 2021 at 1:06 PM
    Fred
    Hand Protectors
    Post up a copy/pic of the Invoice with Part Numbers if you don’t mind. I’d like to see exactly what was done in their words. Thank you.
    speedtre likes this.
  20. Jun 22, 2021 at 3:58 AM
    gargra03
    Gary
    2005 Tundra DC
    Will do, should be picking her up today. Had to wait on a new trans mount.
  21. Jun 22, 2021 at 6:45 AM
    Pretty sure that's where mine is leaking, rear main. Curious to know how many dealership dollars that is to replace. Also terrified to let them do it. Such a big job though. Draining and pulling the trans and transfer case. Disconnecting the drive lines. Removing the flywheel, replacing the seal and then re-installing everything. Good time for fresh trans fluid, filter and new U-joints all around. It's gonna really have to start pissing in the driveway for me to want to tackle that.
  22. Jun 22, 2021 at 7:03 AM
    Fred
    Hand Protectors
    Ye. I’ll wait to do this job when:
    1) That Rear Main really starts leaking and then just do the Transmission Rebuild at the same time.
    2) When the Transmission blows.
  23. Jun 22, 2021 at 7:51 AM
    When our Rav4 was leaking from the rear main the stealership quoted me almost $2,000 to fix the seal. Thankfully it stopped leaking almost 3 years ago and hasn't happened since.
  24. Jun 22, 2021 at 1:16 PM
    I switched to 20W-50 with some stop leak in my old S-10 when the rear main seal went out on it. It stopped leaking.
  25. Jun 25, 2021 at 6:03 AM
    gargra03
    Gary
    2005 Tundra DC
    Hey guys, description of repairs :
    Removed transfer case and transmission. had to replace some transmission mount bolts, crossmember bolts, drilled out bolts in the transfer case to transmission bolts that broke off in the extension housing of the transmission. Replaced front seal in transmission pump, removed rear main seal adapter, resealed adapter plate and replaced the rear main seal. Reinstalled transmission and topped off transmission fluid
  26. Jun 25, 2021 at 6:13 AM
    Good for another million smiles
  27. Jun 29, 2021 at 3:50 AM
    gargra03
    Gary
    2005 Tundra DC
    It goes to the fabricator today, a new rear diff cover to fix seepage. I went with the Barnes heavy-duty diff cover. I will post photos once complete.
    Sirfive likes this.
  28. Sep 3, 2021 at 3:49 AM
    gargra03
    Gary
    2005 Tundra DC
    So I am finally back on the road, the fabricator cut the old diff cover off and welded on a new Barnes heavy duty diff cover, also replaced the axle seals. Then it was over to the exhaust shop to replace the resonator and pipe. So far so good.
    Jack McCarthy and bmf4069 like this.
  29. Sep 3, 2021 at 5:27 AM
    Pics of the new diff cover?
    Fosters2004TundraV8 and shifty` like this.
  30. Sep 3, 2021 at 6:13 AM
    And in addition to pics ....
    How much did that one set you back?
