My alignment after 3/2 lift
Discussion in 'Suspension' started by Hotdog, Jun 22, 2021.
  1. Jun 22, 2021 at 4:30 PM
    Hotdog
    Hotdog [OP] New Member
    2010 Tundra Dbl cab
    So here is my print out on my alignment today after putting in my 3/2 lift. Truck feels pretty good rides straight. A little different resistance on turning but over all not too bad, but to be honest I'm not well versed in the area of alignment specs. Does this appear to be a decent result?
  2. Jun 22, 2021 at 5:30 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I am no expert either but I say all green is good!
    What kit did you use for the lift?
  3. Jun 22, 2021 at 6:06 PM
    Hotdog
    2010 Tundra Dbl cab
    I installed the Readlift SST 3/2 with diff drops and sway bar spacers. Plus added bump stop extensions.
  4. Jun 22, 2021 at 6:19 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    You've got more positive caster now (the one with the big tire icon) so the wheels will want to go straight on its own rather than wandering. Toe looks good for your size tire.
    Hotdog[QUOTED][OP] likes this.
