Katzkin Issue?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Jun 21, 2021.
  1. Jun 21, 2021 at 8:03 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Is this normal? I've had my katzkin for less than a week and there is this section where the leather now feels thin and loose. I can literally grab this between two fingers. What is causing it? IMG_4060.jpg
    Same panel on passenger side for comparison
  2. Jun 21, 2021 at 8:31 AM
    Hopefully @jhuey8947 can answer that for you.
  3. Jun 21, 2021 at 5:26 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Doesn't seem right. Maybe add some padding in that one to tighten it up?
  4. Jun 21, 2021 at 5:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    Is it just a wrinkle? Maybe try a little steam to see if it tightens up?
  5. Jun 21, 2021 at 5:30 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you do the install or did a shop do it? Kinda looks like the hog rings in the front crease didn’t get done quite right.
  6. Jun 22, 2021 at 8:35 AM
    Rocko9999
    Rocko9999 New Member
    Ask Katskin?
