Daytime Running Light Bulbs
Discussion in '2.5 Gen Tundras (2014-2021)' started by nowayout, Jun 21, 2021.
  1. Jun 21, 2021 at 7:35 AM
    nowayout
    nowayout [OP] New Member
    NY
    15 Dbl
    Anyone know where I can find OEM Toyota bulbs for the DRL?
    One of mine burnt out and the Napa replacement looks dim and not as orange, I dont like it
  2. Jun 21, 2021 at 7:42 AM
    Just go to the dealer....they aren't that expensive.
    WBW and nowayout[QUOTED][OP] like this.
  3. Jun 21, 2021 at 8:39 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Sylvania 3157NA Long Life or the Philips would probably be the best for easy to find replacement. I used the Sylvania until I switched to LED's.
  4. Jun 21, 2021 at 8:46 AM
    These are very bright and you can't beat the price. There is a 25% off coupon that brings it to $12.74 + tax.
    https://www.amazon.com/dp/B00PHVUWR8/ref=cm_sw_r_cp_apa_glt_fabc_V2QYZ0WM9KCSB14CZGGB?_encoding=UTF8
    Black Wolf likes this.
  5. Jun 21, 2021 at 9:11 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I 2nd this suggestion and will add that you'll want to buy the sockets at the same time because they tend to get hot and burn over time. I've replaced these on my 2015 SR5 CM and a friend's 2008 SR DC. If I recall correctly it was about $20 for two CK bulbs and sockets. It took me all of five minutes to replace them.
  6. Jun 21, 2021 at 9:31 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you add dielectric grease to the sockets they won't burn out.
    nowayout[OP] and WBW[QUOTED] like this.
  7. Jun 21, 2021 at 10:19 AM
    WBW
    WBW Resident lurker
    Bruce
    AH!!! Good to know! I'll do that tonight or tomorrow when I get off work.
