Headlights, how do I fix this...?
Discussion in '1st Gen Tundras (2000-2006)' started by Solid Snake, Jun 20, 2021.
  1. Jun 20, 2021 at 4:58 PM
    Solid Snake
    Solid Snake [OP] The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    So, my newly acquired 2006 Tundra has headlights that are "frosted over" from age. How do I fix this? Is there a way to clean them? Or do I have to replace them?
    DarkMint likes this.
  2. Jun 20, 2021 at 5:02 PM
    Kelvin
    Kelvin New Member
    Replacing would be the easiest. If you’ve got the skill you can sand and clear it. Or for a quick fix you can polish.
    DaWhiteTundra and Rex Kramer like this.
  3. Jun 20, 2021 at 5:02 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I'd replace them with aftermarket, not very expensive.
  4. Jun 20, 2021 at 5:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I used this on my corolla with some succes.
    https://www.amazon.com/dp/B084RQKLV8/ref=cm_sw_r_cp_apa_glt_fabc_XYM3V8PT345QHFRNR14C?_encoding=UTF8
  5. Jun 20, 2021 at 5:05 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  6. Jun 20, 2021 at 5:06 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    There are various headlight refinishing kits out there, basically different buffing setups.
    Something like this, https://www.canadiantire.ca/en/pdp/...vh0rfaqRBsGpIJFH6FBoCV0MQAvD_BwE&gclsrc=aw.ds
    They are a temporary fix at best and won’t look like new but will be pretty clear. I have done similar fixes many times (not that specific one, that’s just the first one I saw), you will need to redo it from time to time, I did mine about 2 years ago and they’re ready to be done again.
    N84434 likes this.
  7. Jun 20, 2021 at 5:11 PM
    Ebeast
    Ebeast New Member
    2021 Super White Tundra SR5
    Lift Front: Eibach Pro Stage 2 coilovers set at 2.5 Rear: Eibach Shocks. Deavers 3 leaf progressive pack added to stock leafs 1.5 Tires: Falken Wildpeaks AT3 295/70R18 Bed Rack: KB Voodoo High rise bars. RTT: Tuffstuff overland Ranger Tent
    Start by cleaning the headlights with soap and water. Then get a tube of toothpaste that has the baking soda in it. Get a soft bristle brush or a toothbrush and rub it in then wash off.
    Darkness likes this.
  8. Jun 20, 2021 at 5:39 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Headlights have always been a wear item. Previously for bulbs that went bad, nowadays for plastic that can't handle the sun. My PO had a fenderbender so the insurance company paid for replacing the aftermarket headlight with a genuine Toyota part. When I got the truck I could see a difference (small but noticeable) so I replaced the other after market headlight with a Toyota part. I doubt it's worth the additional $150 for the Toyota part from a lighting perspective, but from my OCD perspective I can rest better with two matching parts.
    For the price of aftermarket assemblies I'd just replace instead of trying to buff it out if you're keeping it for more than a year or two.
    Glock 40 likes this.
  9. Jun 20, 2021 at 5:51 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I usually polish mine once or twice a month. The yellow doesnt go away, but the fog does.
  10. Jun 20, 2021 at 5:51 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replaced mine with new OEM housings.
    pock, jimf909 and Tundra2 like this.
  11. Jun 20, 2021 at 5:53 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
  12. Jun 20, 2021 at 6:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I did the same on my truck when I was fed up with my projectors.
    Rex Kramer[QUOTED] likes this.
  13. Jun 20, 2021 at 7:58 PM
    Hotdog
    Hotdog New Member
    2010 Tundra Dbl cab
    This is what I did : bought a can of 2K clear coat the kind that has the 2 stage hardener inside a capsule within the aerosol can . Tape off around headlight lens. Wet sand with 400grit, 500grit, 800 grit, 1000 grit, 1500 grit. Dont have to kill yourself just a good thorough scrub with every grit. Clean it all off. Spray with 2 coats of the clearcoat. It looks as good as new.
    Darkness, HBTundra and 2006 Tundra AC like this.
  14. Jun 21, 2021 at 8:43 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I did a similar thing with my Fogs (Acrylic Assys). Used Rustoleum Acryic Shpray from big box ($8) and looks good! Did the same basic prep as you with sand and clean. I’ll keep in mind your idea on the 2Stage for the head assy in the future.
    New aftermarket headlight assys are nice in the $120-150 range.
    Hotdog[QUOTED] likes this.
  15. Jun 21, 2021 at 8:50 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If I'm not mistaken its pretty hard to find aftermarket replacements for 05/06 access cabs. They have a different molding than prior years where the turn signals are.
    I would try the cleaning route first. Toothpaste works but you'll need some sort of sealant after. I have yet to try the clear coat method. I have used a few different restoration kits, most last a month or two. McGuire lasted almost a year because they include a polish that protects the plastic.
    I might try that Cerakote since it is @Tundra2 endorsed. I would replace mine except I did an HID retrofit. I had to do it while my wife was out of town, can't risk her seeing me throw headlights in her oven.
  16. Jun 21, 2021 at 8:57 AM
    Fred
    Hand Protectors
    Yeah. I polished my OEM Headlights back in 2010 with temporary success. Did it again and didn’t last but 1/2 as long.
    I say do the @Hotdog Shpray 2K Technique and see how she rolls.
    Hotdog likes this.
  17. Jun 21, 2021 at 9:04 AM
    Fred
    Hand Protectors
    Before pic is with prep done prior to shpray.
    After pic is after Acrylic Shpray. You’ll notice some crackling going on (probs from Acetone Cleaning) but the Lens is so much clearer and has held for 2 years well. I could always sand it back down and redo in the 2k but it still looks good from 10 ft.
    Beefnbread, Darkness and Glock 40 like this.
  18. Jun 21, 2021 at 1:09 PM
    Solid Snake
    West TN
    2006 AC 4x4 V8
    Thanks for all the input. I'm seeing polishing kits on shelves. Never knew that was a thing since this is the first vehicle I've owned that had this issue. I think I'll try that first.
  19. Jun 21, 2021 at 4:35 PM
    AWilliams
    AWilliams New Member
    Are some aftermarket replacements better than others on the Amazon & ebay for an 03?
  20. Jun 21, 2021 at 6:11 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I'd go the wetsand and 2k (UV rated) clear coat route. The OEM headlights seem to have the best optics and adjustments, unless going for a complete retrofit.
    Hotdog likes this.
  21. Jun 21, 2021 at 6:32 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I had great results with Turtle Wax’s headlight restore kit. Small amount of money with awesome results!
    I would use masking tape around the lens to help protect the metal painted surfaces.
  22. Jun 21, 2021 at 6:52 PM
    Twowheelssoar
    Twowheelssoar New Member
    NC
    2021 Cement SR5 6-Seater
    I’ve had success with some polishing compound and a wax applicator pad. Just keep going until it’s clear, wipe with a wet microfiber rag. If you still see haze, repeat.
    That combo will also remove the fingernail scratches that develop under your door handles.
  23. Jun 21, 2021 at 7:45 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    polish and sealing is the best option. Aftermarket housing are inferior. The optics are junk compared to OEM. Cut off lines are much less sharp.
    HBTundra and DaWhiteTundra like this.
  24. Jun 21, 2021 at 7:56 PM
    jimf909
    Washington or Idaho
    This sounds like good advice. My only suggestion is to say that removing the headlight assembly is relatively easy so consider removing for easy handling, repositioning and avoidance of the tape, untape step.
    FWIW, YMMV.
    HBTundra and Hotdog[QUOTED] like this.
  25. Jun 21, 2021 at 7:57 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Wet sand em… then compound em. I like the 3M products for these things. Or check out certifit… they typically have good deals
  26. Jun 22, 2021 at 10:29 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm not sure what other experiences have been with sanding and using different compounds as far as longevity, but mine wasn't ever great. I've got an old Accord that I'd sand and compound and wax and they never stayed clear for more than a couple months. After that I'd have to do it again. Save yourself the repeated work every few months and buy new buckets. I'm glad I finally did for my Honda. Below is the difference between new and old. I've had the buckets since Nov and they still look new.
  27. Jun 22, 2021 at 12:08 PM
    Hotdog
    Hotdog New Member
    2010 Tundra Dbl cab
    This is why it's better to use a 2k clear coat. Better UV and scratch resistance.
  28. Jun 22, 2021 at 1:30 PM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    I had a good outcome from polishing my 2002 foglight lenses. My experience with various of these huge plastic headlamp assemblies is that they can be brilliantly polished on the outside, which then leaves the inaccessible inside haze more visible. I bought the truck last December and the lenses were nearly opaque. I first installed some aftermarket units from Amazon and found the light pattern lousy. Sprang for a pair of OEM replacements, which have been perfect. I also put in a Susquehanna Motorsports headlight harness and 2.0/+100% Hella bulbs. Since my see-in-the-dark card was revoked at age 65, I need the lumens.
  29. Jun 23, 2021 at 6:12 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Best kit I ever used from the parts store was the Sylvania Kit. When you register it, it comes with a lifetime warranty (which they honor). One of the issues I found was that when the car wash sprayed their bug & tar remover on the headlights, it also removed the clear coat.
    SO, I replaced the headlights with new aftermarket ones.
  30. Jun 23, 2021 at 9:34 AM
    Fred
    Hand Protectors
    Agreed. New Assys, too.
