Rear brake recommendations
Discussion in '1st Gen Tundras (2000-2006)' started by jphillixv, Jun 18, 2021.
  1. Jun 18, 2021 at 7:12 AM
    jphillixv
    jphillixv [OP] New Member
    Howdy, looking to get rear brake drum/shoe kit recommendations. Seeing what people have used in the past to tow. Going to be towing about 6k lbs whats worked best for y’all thanks!
  2. Jun 18, 2021 at 12:07 PM
    Professional Hand Model
    Fred
    Hand Protectors
  3. Jun 18, 2021 at 12:22 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    nothing wrong with the stock brakes. And the front brakes do most of the work anyway, so if you wanted to upgrade that is where I would start vs the rear.
  4. Jun 18, 2021 at 12:49 PM
    I"ve got NAPA premium brake shoes and OEM drums. Haven't towed anything though.
  5. Jun 18, 2021 at 5:09 PM
    jphillixv
    Facts I Got front brakes upgraded already. Could one of y’all attach a link if you don’t mind for drums/shoes. I’m a noob when it comes to no pads and am getting confused with do all the components come inside new drum? Responses much appreciated.
  6. Jun 18, 2021 at 5:15 PM
    Fred
    Hand Protectors
    I’ll post up some Prices/Part#’s tomorrow after Scones and Coffee.
  7. Jun 18, 2021 at 5:28 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    New shoes, hardware kit, drums if you'd like (chances are you could get them turned).
    Something like these
    https://www.amazon.com/Raybestos-764PG-Professional-Grade-Brake/dp/B000CKBK34
    https://www.amazon.com/Raybestos-H17343-Professional-Grade-Hardware/dp/B0015RMU78
    Maybe have the self adjuster kits just in case
    https://www.rockauto.com/en/moreinfo.php?pk=12195105
    https://www.rockauto.com/en/moreinfo.php?pk=12195101&pt=1752
    https://www.rockauto.com/en/moreinfo.php?pk=11669189&cc=1426935&pt=1744
  8. Jun 19, 2021 at 5:36 AM
    Fred
    Hand Protectors
    While waiting on the Scones, here you go.
    Kimosabe likes this.
  9. Jun 19, 2021 at 9:04 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to how bad of a shape, some parts can be simply cleaned up using same procedure as bellcrank repair.
    tvpierce likes this.
