Mpg down then up?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dirtytruck, Jun 16, 2021.
  1. Jun 16, 2021 at 11:01 PM
    Dirtytruck
    Dirtytruck [OP] Overkill it
    2021 SR5
    I’ve got a ‘21 SR5 double cab std bed. It’s got just under 13k miles.
    Right around 12k miles I added a transmission cooler, changed engine oil to AMSOIL 0w20, and both diffs to AMSOIL SG75w90. It had the factory 75w85 in the diffs. I’m also still running the ATF WS Toyota trans fluid.
    Immediately my MPG dropped literally by 5 mpg’s. I tested my mileage using the trucks mpg display along with the tank to tank calculation. The difference between the two was 2/10 of a mile. The result average was 11 to 12.1 city and 13.5 to 16.1 highway. It’s been this way for about 800 miles now. I spoke to AMSOIL and they were as as baffled as I was.
    Today I go and fill up the gas tank and run another mileage test. One running the a/c and the other without. I drove identical routes and speeds. The route was 18 miles. 9 miles up a gradual grade and 9 miles down same grade with the first and last 3 mile segments in the city.
    To my astonishment the mpg without a/c was 20.6 and with a/c was 19.8! This is right where it used to be and just a little better.
    What am I missing here?
  2. Jun 16, 2021 at 11:04 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t have an explanation, but I have never seen 20 miles per gallon in my truck, ever
    Ely010606 and 2mchfun like this.
  3. Jun 16, 2021 at 11:08 PM
    Dirtytruck
    2021 SR5
    The 20mpg can be attributed to the 9 miles downhill part I’m thinking. Two days ago I did the same downhill but extended it to about 18 miles downhill and only got 16.1mpg.
    I’m stumped.
    15whtrd likes this.
  4. Jun 17, 2021 at 4:46 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    So you compared your display mpg and hand calculations and they were both down by 5mpg? I ask because if it was only display settings, and your battery was disconnected, it could be reading odd until things smoothed out. Sounds very strange.
    On a side note though, I've sniffed 20mpg but it was a similar setting as you, just a 40 mile round trip that was perfectly flat to go fishing and back home after a fill up. Then normal driving happened and I came back to my normal 15-16.
    15whtrd likes this.
  5. Jun 17, 2021 at 4:51 AM
    Eventually you will figure out that mpg don't matter and that there is no need to worry about it. You will have to get gas when empty no matter what. Same concept as paying no matter what the gas prices are.
  6. Jun 17, 2021 at 4:55 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'm solving my MPG issues via the Harrop protocol.
    scheduled for next week.
    triharder, 1UP and 15whtrd like this.
  7. Jun 17, 2021 at 5:02 AM
    15whtrd
    15whtrd Mr. Blonde
    For sure! I think he was just concerned with such a huge margin of change.
  8. Jun 17, 2021 at 5:13 AM
    The trucks mileage computer is always grossly off, if you hadn’t been doing actual tank to tank calcs before, you won’t know if your numbers now are askew or not. Start trying to calculate smiles per gallon instead; much easier and beneficial to do.
    15whtrd likes this.
  9. Jun 17, 2021 at 5:14 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed. never let your total tank MPG exceed your avg air fuel ratio.
  10. Jun 17, 2021 at 5:18 AM
    Bammer
    Monroe, CT
    Tank MPG will be all over the place , and short hopping isn't going to give you any useful info, it's a V8 ! Now if you go extended distances it'll make a difference. I just did a 230 mile, mostly highway trip, never over 70 and going easy on the throttle , I hand calculated 19.8 mpg. I snapped a pic of my distance to empty after filling up.
  11. Jun 17, 2021 at 5:22 AM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Based upon my short ownership, IMO any reading the the dash is giving me is a big "so what" as it is pretty much meaningless big picture. Hand calculations on when you fill up your tank after driving hundreds of miles is the way to do it. And to have accurate comparisons tank tank, you should really try to use the exact same gas pump as there can be differences between pumps on when they shut off, meaning one pump might give you an extra quart or two which obviously changes your mpg, especially on short fill. Just my 0.02.
    15whtrd likes this.
  12. Jun 17, 2021 at 5:26 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Short tripping in these trucks and driving over 70 mph kills the gas mileage in these things. I average 17 mpg’s but I avoid short trips when possible. After a year of ownership I have have many trips where I average 18ish but they were all highway. The sweet spot was when I was on back country roads doing 55 to 65…I got just about 20. It’s not fun driving on the conservative side but you CAN get respectable (for a 5.7) mpg’s out of the Tundra. And I never idle…
    15whtrd likes this.
  13. Jun 17, 2021 at 11:11 AM
    Dirtytruck
    2021 SR5
    I appreciate all the input.
    This is my 4th tundra. Of all of them this one has averaged the best in mpg. I should have mentioned the tank to tank calculation vs the computer readout was done a week ago driving over 120 miles on mostly country roads. 2/10 of a mile difference. Pretty darn close if you ask me.
    The battery was never disconnected but I’m glad y’all brought it up anyway. Something to remember next time the battery is disconnected.
    Just another unsolved mystery.
  14. Jun 17, 2021 at 11:20 AM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    10 to 11 MPG crew reporting in. :thumbsup:
  15. Jun 17, 2021 at 11:33 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Is yours a Flex Fuel truck? Sometimes the computer gets confused (I've read, never experienced) after a tank of E85 and takes a few tanks to fix itself.
    11mpg member here!!
  16. Jun 17, 2021 at 3:58 PM
    Dirtytruck
    2021 SR5
    No flex fuel.
    10-11 mpg? Sheeeesh!! Sounds like a ‘78, 3/4 ton Dodge Power Wagon I once had. Good ole birdbath hood, too. Towed and hauled like a tank.
  17. Jun 17, 2021 at 4:06 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have a 21 CM and there is only 1 situation i get 22 mpg, per the computer. Going down a 9,000 ft elevation mountain road for 45 miles, then going 70mph for 45 miles on a flat, open highway. All other times i average 15 mpg.
  18. Jun 17, 2021 at 5:40 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
  19. Jun 17, 2021 at 6:57 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    My commute is 12miles each way (takes 25-30 minutes) and I grab a bite to eat in town for lunch. Avg 36 miles a day, mostly City streets or congestion. If the highway is empty I drive 80mph. 36 miles driving per day….
  20. Jun 17, 2021 at 9:00 PM
    Dirtytruck
    2021 SR5
    I appreciate your input as it confirms what I kinda suspected. Heavier gear oil equals better protection but less mpg. 5 mpg less got my attention, though.
    Subject change: I ask an AMSOIL rep if there are any particular differences doing a AMSOIL transmission flush compared to the ATF WS flush since Toyota has multiple fluid temperature requirements when working with WS. His response was “that’s why alcohol was invented after having to deal with all the quirkie transmission fluid temperature requirements Toyota came up with!”
    He also said to do exactly what Toyota requires as if using WS.
    Getting a flush done next week with the AMSOIL ATL.
  21. Jun 18, 2021 at 3:32 AM
    Bammer
    Monroe, CT
    Ummmm NO.... How is the required fluid killing MPG?
  22. Jun 18, 2021 at 4:34 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Viscosity is by definition the resistance to fluid flow. A higher viscosity fluid takes more energy to make it move. This means the carrier and ring gear will have more resistance as it moves through a thicker fluid than a thinner one. If you ever see a truck with a clear diff cover you'd be amazed just how violently the fluid is churned around in there. It also means it takes more forces between the gear surfaces before there's enough to squeeze enough out to make metal contact; this is the more load and shock protection quality.
    Fuel mileage is why Toyota switched to 75w-85 instead of the prior 90w spec; why car companies went to thinner 0w-20, 0w-16, even upcoming 0w-12 engine oils because it's less drag on the oil pump to make it move.
    If you went more extreme and ran 85w-140 you'd see a few mpg loss. On my 4 cyl truck I tried it once and it definitely affected it. With 75w-85 it routinely got 22-24 mpg, once 28 mpg. With 85w-140 my best hypermiling efforts couldn't ever break 19 mpg.
  23. Jun 18, 2021 at 4:42 PM
    Bammer
    Monroe, CT
    I think the difference between 75w90 and 75w85 is negligible.
  24. Jun 18, 2021 at 5:22 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    That's what I thought and why I just used mobil 1 75w-90 when I drained the factory fill and break in shavings. Then the truck almost never got up to 15 mpg over three years, unmodified suspension plus a tonneau cover, 255 width stock size P-rated tires, and not so much as a passenger for added weight. For kicks I switched back with the redline 75w-85. The difference is noticeable if you're watching numbers real-time. Plus the aggressive engine braking I was so used to is almost completely gone because it wasn't really engine braking at all, it was oil drag.
    Most people wouldn't notice. Most people haven't gotten over 15 mpg with E85 on a 5.7L either.
