Withdrawn - Midland MXT275 (new)
Discussion in 'Marketplace - Other' started by Tundra-in-Cement, Jun 17, 2021.
Thread Status:
Not open for further replies.
  1. Jun 17, 2021 at 8:16 AM
    Tundra-in-Cement
    Tundra-in-Cement [OP] Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    I have a brand new Midland MXT275. I did plug it in once, but the unit is new otherwise.
    Asking $125, free shipping. Located in Dayton Ohio.
    About this item
    • 2-WAY RADIO - This 2-Way Radio features 15 high power GMRS channels with 8 repeater channels.
    • 50-MILE RANGE - Full 15W Radio with an external magnetic mount antenna for extended range.
    • 142 CTCSS/DCS PRIVACY CODES - The privacy codes give you up to 3,124 channel options to block other conversations.
    • NOAA WEATHER SCAN + ALERT - NOAA Weather Scan will automatically scan through 10 available weather (WX) band channels and locks onto the strongest weather channel to alert you of severe weather updates. NOAA Weather Alert will sound an alarm indicating that there is a risk of severe weather in your area.
    • INCLUDED IN THE BOX - Radio, Fully Integrated Control Microphone, Mount, Detachable Antenna with Magnetic Mount, Microphone, Microphone Holder, 12V Power Cord with Car Power Adapter, Owners Manual, and Quick Start Guide
    • COMPACT - Features a Fully Integrated Control Microphone ideal for vehicles with limited dashboard space, allowing the radio base unit to be stashed away.
Thread Status:
