TRD Front Sway Bar Installation Procedures?
Discussion in 'Suspension' started by newTundraGuy2, Dec 19, 2020.
  1. Dec 19, 2020 at 5:34 AM
    newTundraGuy2
    newTundraGuy2 [OP] New Member
    2021 Tundra SR5
    Hello everyone!
    New 2021 Tundra owner here and I am really liking the truck! I picked up the truck a couple weeks ago and installed the rear sway bar and the installation details and grease were included with the parts. (FWIW it made a pretty significant difference and has reduced the body roll.)
    The TRD front sway bar however is just the bar and I was wondering if there are similar instructions from Toyota on proper installation procedures/torque specs/etc. Also looking at some youtube videos I see that you are supposed to grease the bushings and since this part didn't come as a kit no grease was included. I want to make sure I use the right grease for the job so figured this was the place to ask! Another item people mention is using an anti-sieze compound but there are apparently many kinds - some of which are corrosive - does Toyota use anti-sieze from the factory?
    Any guidance/advice is appreciated, thanks!
    YardBird likes this.
  2. Dec 19, 2020 at 5:42 AM
    Welcome from NY.
    newTundraGuy2[OP] likes this.
  3. Dec 19, 2020 at 5:52 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  4. Dec 19, 2020 at 6:08 AM
    newTundraGuy2
    2021 Tundra SR5
    Thanks! do you happen to remember if you used Aluminum, Copper, or Nickel?
  5. Dec 19, 2020 at 7:21 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You don't have any extra bushing grease left over from the rear sway bar install do you?
    The torque values will be the same as stock.
    Stabilizer bar-to-link nut:............................111 ft-lbs
    Stabilizer bar link-to-lower control arm nut:....89 ft-lbs
    Stabilizer bar bracket-to-frame nut/bolt:........51 ft-lbs
  6. Dec 19, 2020 at 7:26 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Is there any difference between the standard sway bar and the TRD one? Regarding the front sway bar
  7. Dec 19, 2020 at 7:28 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Its bigger, which makes it stiffer. Well, thay didn't come out right. Lol
  8. Dec 19, 2020 at 7:35 AM
    newTundraGuy2
    2021 Tundra SR5
    No unfortunately not, the directions explicitly tell you to use all the grease.
    Wynnded[QUOTED] likes this.
  9. Dec 19, 2020 at 7:37 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  10. Dec 19, 2020 at 7:38 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The diameter is the same, the wall thickness is greater on the Sequoia bar and even thicker on the TRD bar.
  11. Apr 30, 2021 at 7:38 PM
    Mighty_Mike88
    Mighty_Mike88 New Member
    2015 Toyota Tundra
    6'' Lift Kit, Fuel Wheels and Tires, Tesla Screen, NFab Bumper, Star headliner, And Programmer
  12. Jun 17, 2021 at 6:30 AM
    fish2keel
    fish2keel New Member
    Im assuming if you got a TRD package you already got the TRD front sway bar?
  13. Jun 17, 2021 at 6:34 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nope. That'll be extra.
  14. Jun 17, 2021 at 6:35 AM
    fish2keel
    OOOO a new toy then!
  15. Jun 17, 2021 at 6:37 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Shiny new toy!
  16. Jun 17, 2021 at 6:44 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    standard sway bar is a tube whereas the trd sway bar is a solid piece. The difference is about 15 lbs between the 2. I installed both the trd rear and front sway bar at the same time so I cannot say how much of a difference just the front makes, but the truck handles so much better after installing both of them.
    Badknees and Rob's Inferno like this.
