Rack and pinion problems
Discussion in '1st Gen Tundras (2000-2006)' started by Tundracula, Jun 17, 2021.
  1. Jun 17, 2021 at 5:34 AM
    Tundracula
    Tundracula [OP] New Member
    06’ Toyota Tundra
    So my truck was been making grinding sounds when turning or hitting bumps, I didn’t know it was the rack and pinion until my dad looked under the truck and pointed out these things looking wrong, my rack and pinion looks horrible, I need to know did that area where the bushing is grind into the rack? I need help figuring out what I should do, would appreciate and advice!! Thank y’all
  2. Jun 17, 2021 at 5:36 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    You need to replace your Rack and Pinion, Upgrade to Urethane bushings why your at it.
    Tundracula[OP] likes this.
  3. Jun 17, 2021 at 5:59 AM
    Tundracula
    06’ Toyota Tundra
    Lol straight up, so it’s that bad huh? :confused:
  4. Jun 17, 2021 at 6:03 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I would first try cleaning up all that grease, then replace the inner tie rod and boot. That’s less than $50 in parts and maybe 1-2 hours in labor. If the noise goes away, then get an alignment. If it doesn’t, then replace the rack.
    Sunnier likes this.
  5. Jun 17, 2021 at 6:16 AM
    Tundracula
    06’ Toyota Tundra
    ok I like that idea, at the same time I would like to just replace it all and be done with it but then again money lol, thank you
  6. Jun 17, 2021 at 6:24 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Replacing is probably your best bet as the age of our trucks demands it. We see many with leaky racks at 15 years and many have replaced theirs here with Reman’d Racks with success. You could also do a New OEM Rack (which is the route I’ll take on my 2002) when she finally blows after having a slight weep going on 4-5 years.
    Yours being a 2006 might be troublesome in terms of parts cost for a New OEM Rack as that year is expensive for some reason iirc. Other problem with Remans is they tend to develop leaks sooner than OEM per some members here and you’ll end up with another job on your Hands.
  7. Jun 17, 2021 at 7:06 AM
    Tundracula
    06’ Toyota Tundra
    Glock 40 likes this.
  8. Jun 17, 2021 at 9:05 AM
    I like how you capitalize hands.
  9. Jun 17, 2021 at 9:38 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Well, let's not jump so fast. I don't see damage here other than a split boot, which frankly doesn't do much harm.
    Let's start with the small things first. If your rack was groaning you might be low on power steering fluid. I see an oily film under your truck but very hard to tell what it is from. Check your power steering fluid reservoir, it is in the engine bay on the passenger side. Wipe the top of it off before removing the cap. Check the fluid level out.
    Is it low? If so look for a leak. Could be leaking at the pump, at the rack, or anywhere along the two lines that bring fluid through the steering system.
    It isn't low? Okay, how does the fluid look? This can be confusing because power steering fluid tends to be clear or slightly yellow, however transmission fluid can be used in place of power steering fluid and would most likely be red/pink. If you see brown fluid and maybe bits of crap, try changing the fluid first. It will cost you 3 or 4 quarts of trans fluid. Research how it is done if you will take it on, it can get messy.
    As far as that ripped boot, unless your tie rods are thrashed I wouldn't replace the inner ones. The boot can be replaced by removing the outside tie rod and slip a boot on. Inside tie rods can be hard to pull out, I'm at 240k miles on original ones.
  10. Jun 17, 2021 at 12:10 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Im sure it can be rebuilt, just about anything can be rebuilt.
    A replacement would be the route i'd take.
  11. Jun 17, 2021 at 10:30 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    If you buy a new rack and pinion, be careful with the boots when you install it back in. Couple years ago I replaced the rack and pinion on my 03 Ram 1500 and ripped up a boot while sliding it in. Then again I’m just a dui home mechanic
  12. Jul 6, 2021 at 10:41 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I was researching the same issue as you I have a 06 double cab 167k. My driver side boot looks like someone melted the underside. My bushings have also seen better days. Going to try and replace the boots on both sides and all the rack bushings.
    my fluid was at the low line in the reservoir and I have some squeaking during cold starts when I play with the steering wheel left and right.
    I thought it was my tensioner pulley and belt since the chirp was only at cold starts and the noise went away but continued a week after I replaced (not sure If it’s related)
