2000 tundra no start, no crank
Discussion in '1st Gen Tundras (2000-2006)' started by dppham, Jun 15, 2021.
  1. Jun 15, 2021 at 10:25 PM
    dppham
    dppham [OP] New Member
    A little history, 330k, original owner
    I have done 80% of the repairs and maintenances, exclude tranny and tires
    Love this truck. I have been using it for work, running everyday.
    last week got new tires and went to customers house no start, no crank
    tried jumping it, battery is new red top optima got it last year.
    it seem like the starter was not engaging to flywheel. i can hear the starter click once and spins
    all the acc, fan blows hard no dims.
    ive replace 2 starters already on this truck and i went with denso last time. but this time i went to auto zone and bought their gold durlast. installed it and does the same thing. one click and hear the starter spinning but not engaging.
    so i recheck the battery terminals and it was clean but looked underneath and saw this (see picture)
    its the positive side going to engine that distributes out to everything. i cut back and seen its corroded further back from the o terminal.
    could this be the issue and how would i go bout fixing it? what size gauge wire and any particular wire type?
    thank you all, my first thread
  2. Jun 16, 2021 at 1:26 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If the starter is spinning and not engaging it sounds like you could have a worn spot on your flywheel. If possible you could turn the engine by turning the crank pulley bolt and get the flywheel to a different position and see if it will crank there in order to determine if you need a new flywheel. I'm definitely no expert it's just the first thing that comes to my mind.
    dppham[OP] likes this.
  3. Jun 16, 2021 at 3:30 AM
    terrward
    terrward New Member
    2004 DC SR5
    You could have got a new starter with a bad solenoid. I would have put another denso in there.
  4. Jun 16, 2021 at 5:11 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Corrosion could cause many issues. Clean it up or replace the cable.
    We’ve seen a few stories of others come through here with this same problem and it lead back to bad cables.
    Two Starters is a lot of Starters to be going through so suspect something else.
  5. Jun 16, 2021 at 10:04 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    parasitic draw? Not enough voltage to the starter motor?
  6. Jun 16, 2021 at 10:34 AM
    dppham
    Good idea. Will try to rotate crank tonight!
  7. Jun 18, 2021 at 9:51 AM
    dppham
    Found the problem. Was the main positive harness. I slice the harness back 4 inches and broke up the corrosion and clean with wire brush. Starter right up. Thank you all for help
  8. Jun 18, 2021 at 11:47 AM
    Fred
    Hand Protectors
  9. Jun 18, 2021 at 4:21 PM
    I'd replace that cable then. It should be orangeish wire. Maybe a tinge of green.
