Exhaust Advice?
Discussion in 'Performance and Tuning' started by Anubis001, Jun 14, 2021.
  1. Jun 14, 2021 at 5:27 PM
    Anubis001
    Anubis001 [OP] New Member
    Black 2016 Tundra 4wd SR5 5.7L
    Only a Borla muffler
    Hello Everyone,
    Back in 1997 (when I was 17 years old), I rolled my '95 GMC Jimmy and was lucky enough to stumble upon a totaled 1994 Ford Lightning pickup with a clean title. I bought it for around $6,000 and repaired all of the damage for around $4,000. I initially intended to flip it for a profit and repeat the process until I made enough to buy a nice, relatively new vehicle, but after the first time I drove the Lightning I was hooked. I added Hooker headers, cut out the cats, and added a side-exit Borla cat-back exhaust system (just running straight-pipes between the headers and the cat-back system. I didn't sell that truck until I started dating a girl with kids in 2004. I loved the way it sounded and never once had an issue with the exhaust on that truck. When I got my 2016 5.7L Tundra SR5 in 2016, I wanted a similar sound (throaty under acceleration, but relatively quiet at idle), so I just swapped the factory muffler for a Borla 40670 muffler.
    It sounded great and everything seemed to be fine until about 4 years later, when the weld on the sleeve connecting the muffler to the tailpipe apparently rusted out and dropped the entire tailpipe on the freeway. My girlfriend was driving at the time, but luckily she noticed, pulled over, and retrieved the tailpipe. I took it back to the the Tuffy that originally did the muffler swap, and they said that they could reattach it for another $200, but I should expect the same thing to happen after another 4 or 5 years. I suspect that either the tech who did the work did something wrong when welding the adapters in place or they just used cheap steel for the adapters (as you can see in the pics, the factory pipe is completely rust-free, and the muffler itself is aircraft-grade stainless, so I know it hasn't rusted either, and even most of the adapter sleeves themselves look to be rust-free; it's only the welds themselves that rotted out), largely because the welds on my Lightning held up in the exact same environment for 7 years without ever even hinting at rusting out.
    I'm thinking I probably just need to buy quality stainless adapters myself and then have another shop in my area perform the repairs. Does anyone know what size the OEM pipes are on both sides of the muffler?
    My apologies for the duplicated pics below; for some reason when I paste them, it duplicates them as well...
    Thanks!
  2. Jun 14, 2021 at 6:01 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  3. Jun 14, 2021 at 6:31 PM
    15whtrd
    15whtrd Mr. Blonde
    Too bad they couldn’t just use stainless to patch it in. Our exhaust systems are stainless which is why when I did mine I wanted one just as quality or better. I went with Dirtydeeds 6 inch. Fully stainless and should last a long time. It costs but I think it was worth it. If you can find a good exhaust shop willing to build it out of stainless for cheaper, you could try that out.
    Anubis001[OP] and Rex Kramer like this.
  4. Jun 17, 2021 at 5:36 AM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    Looks like the weld wasn’t 100% welded to begin with causing the condensation from the exhaust to seep through resulting in the rusting and deterioration of the pipe
    Anubis001[OP] likes this.
  5. Jun 21, 2021 at 12:51 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Hello,
    I would call Keith Carty of Dirty Deeds Industries and pick his brain. No one knows Tundra's like Keith does. He is out of the office most days, but is always available via phone. You can call or text him anytime at 760-877-4234. He does take many calls and texts a day, but is very good at getting back to everyone.
    Thanks, Shawna, DDI
    Anubis001[OP] and 10TundraSR5 like this.
  6. Jun 21, 2021 at 12:58 PM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    You can't beat their customer service and this is proof. I've talked to Keith before and he is legit.
  7. Jun 22, 2021 at 9:03 AM
    Anubis001
    Much appreciated everyone, thank you!
    15whtrd likes this.
