Pulling bumper corner on 2021
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Jun 13, 2021.
  1. Jun 13, 2021 at 12:28 PM
    eagleguy
    eagleguy [OP] New Member
    Like an A$$ I jack knifed my utility trailer while backing in a hurry. The end result was that I pushed in the PS corner of my 21 Tundra SR5 rear bumper about a half inch in while scraping the painted bumper side (gouged as well) and a 2" piece of my quarter panel. I was thinking off using a come along to pull the bumper out prior to the expensive trip to the body shop to make like new. Was a slow moving accident and I am pissed the bumper bent so easily. Worried I might make it worse trying to pull it out!
  2. Jun 13, 2021 at 12:33 PM
    grichg
    grichg New Member
    rich
    my 16 has that also. Prob will just replace with used or new one or leave it until it gets hit again
  3. Jun 13, 2021 at 12:47 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  4. Jun 13, 2021 at 1:13 PM
    eagleguy
    Pictures
  5. Jun 13, 2021 at 1:21 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Ouch! That sucks. The first cut is the deepest...
  6. Jun 13, 2021 at 1:30 PM
    eagleguy
    I see that I can buy replacement black textured caps for the bumper ends on Ebay for about $100 a set. Problem is that I kinda like the color matched ones I have. Obviously if I replace the caps and straighten the bumper my only issue would be the QP damage. I am sure they would want to spray the whole quarter to match the paint which would not be cheap. Someone just lightly keyed my wife's 17 Highlander while at Walmart down two doors and a little part of the quarter. Tried buffing to no avail and now its a $700 respray to fix. Bad week!
  7. Jun 13, 2021 at 3:37 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Since the truck is brand new you might be able to get away without paint matching the other panels. See if a body shop can pull it out and correct the scratches. I just paid 280 for both panels under the headlights to be sanded and painted and they are just about the same surface area as what you need.
  8. Jun 13, 2021 at 4:30 PM
    The rear bumper is nothing but cosmetic on these trucks. If you look at my build thread, you will see that there is not much too them at all.
  9. Jun 13, 2021 at 4:32 PM
    eagleguy
    I am not looking to change things. Just looking to make as NEW.
  10. Jun 14, 2021 at 4:56 PM
    eagleguy
    $800-$1000 to fix.
