Clunking when turning in 4hi - Rough Country 3.5" lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by BAM3, Jan 24, 2021.
  1. Jan 24, 2021 at 2:59 PM
    BAM3
    BAM3 [OP] New Member
    Houston
    2016 MGM CrewMax Platinum
    Nitto RGs, KMC wheels, DD fog lights, '21 LED Headlights, Retrax, 3" RC Lift, Tech12Volt Processor/JBL amp, TRD Sways
    Hey guys,
    New to the forum. Put in some time searching but didnt come up with anything close.
    I just got my 2016 CrewMax 4x4 after my 2012 flooded in Hurricane Zeta.
    Here are the details:
    2016 CrewMax 4x4 with 85k miles. Rough Country 3.5 level kit with spacers/upper control arms in the front, Rough Country shocks and spacers in the rear. KMC 20" wheels with 305 Ridge Grapplers on them.
    I noticed today that in 4hi there is a noticeable clunking when taking slow speed turns. This happens when turning left or right. Truck tracks fine in a straight line in 2wd, 4ho or 4lo.
    Any ideas what could be causing this? Thanks for the help!
  2. Jan 24, 2021 at 3:05 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    You're off the pavement when this happens right?
  3. Jan 24, 2021 at 3:06 PM
    biebs96
    PA
    It’s probably binding at the low speed in the dry ground.
  4. Jan 24, 2021 at 3:06 PM
    BAM3
    Houston
    No. Noticed it today on a smooth paved road.
  5. Jan 24, 2021 at 3:09 PM
    trucknut
    trucknut New Member
    Yea, try to stay in 2wd on pavement. That's expected when in 4wd if the tires have traction.
    15whtrd likes this.
  6. Jun 14, 2021 at 6:38 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    I'd stay away from concrete when using 4wd, unless it is extremely wet. You have no traction control in 4x4 so the side you're turning to doesn't slow down the wheel speed, thus you're hearing that clunking because the tire has to break traction to continue turning... this isn't good for the front or rear diff, and as such you can end up binding your gears and ruining your 4wd. But if necessary to use 4wd on concrete, make extremely wide, slow turns, you'll feel the truck start to slow or "bog" down when turning on concrete in 4wd, which will show you that you are turning too tight.
    15whtrd likes this.
  7. Jun 14, 2021 at 6:38 AM
    joseph_womack
    Joe
    Louisiana
    on a side note, how do you like the lift? have you taken it off road?
  8. Jun 14, 2021 at 7:09 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It’s because you’re turning on pavement in 4wd. You should only be turning in 4wd when the front tires are able to slip.
    15whtrd and joseph_womack like this.
  9. Jun 14, 2021 at 3:57 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Why are you in 4WD on pavement?
