6112 bilstein 1.9 w/stock off-road rear or something else??
Discussion in 'Suspension' started by ArdnuT trd, Jun 9, 2021.
  1. Jun 14, 2021 at 10:34 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    It would pay just for piece of mind.. Loosen the nut on the upper control arm pivot bolt on each side. its the long bolt up near the engine and then lower the truck back down onto the ground and re torque them. This will set the OE rubber bushing in its neutral position rather than hold it at its factory position if it wasn't done during your install. Torque spec is 125 ft lbs but must be done with the truck at ride height.
  2. Jun 14, 2021 at 10:43 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Thank you.
    I'll try that this weekend..
    Barrett50 likes this.
  3. Jul 16, 2021 at 8:16 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Sorry newbie question here, but what does that mean 6112 assembled with “new hats”.
  4. Jul 17, 2021 at 4:50 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    If you ordered 6112's "unassembled" you would need to remove the top hats off your original coilovers to assemble them. Although more expensive, buying them assembled makes for a quicker swap and your able to keep your original coilovers intact.
  5. Jul 17, 2021 at 5:45 AM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    I plan on going 6112 highest setting and, if needed, a shim up front on the driver's side to account for lean. 5100s and +2 CB shackles for the rear. With a canopy I am hoping this will give me a 1/2 "or 3/4" rake and make room for big tires. I will also be running JBA UCAs. Hoping the ride is still enjoyable and the truck won't sit too high for the kiddos!
  6. Jul 17, 2021 at 6:09 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    I’d consider +3. I have 1/2” rake with +2 at 1.9 setting with one shim. Have a topper. F4BEAF88-4CDB-4EEA-A049-77299171CF9B.jpg
  7. Jul 17, 2021 at 6:55 AM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Thanks for the heads up. I have everything on order already but am waiting on the CB stuff. I wonder how much of a difference there would be with a CM too.
  8. Jul 17, 2021 at 1:04 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Good point. Didn’t think of that. Guess you’ll find out soon enough.
  9. Jul 17, 2021 at 4:06 PM
    Nubby
    Nubby New Member
    AZ
    2021 TRD Army Green
    ‘Are those tires in this pic the 285x75’s?
  10. Jul 17, 2021 at 4:59 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    I put 6112's set at 1.9 with stock UCA and 5160 with stock rear height on at 115,xxx miles. The ride was Night and day, I got the kit installed on a Thursday and left on a 3200 mile road trip on Saturday. I've got a set of Coachbuilder 1" shackles and Freedom Offroad UCA's setting in the Garage waiting to be installed, I cant wait to install so we can go on another 3000+ mile road trip this fall.
    Skew12 and GELCW like this.
  11. Jul 17, 2021 at 5:11 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I installed my 6112/5160 at 1.9” in the front and stock height in the back. I haven’t measured it, but it seems close to level. I would like to add 1” with rear shackles, but it isn’t a priority. I agree with others that the ride quality improved a lot. I had 240lbs of sand in the bed with the stock suspension to stop bed bounce and smooth out the ride. The 6112/5160 setup rides notably better than the stock did with sand, especially over rough roads, speed bumps, etc.
  12. Jul 17, 2021 at 5:24 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Did you add shims too in the front? I’m on the fence about it….. mine gets installed at 1.9 as well.
  13. Jul 17, 2021 at 5:56 PM
    Nubby
    Nubby New Member
    AZ
    2021 TRD Army Green
    Here is mine with 6112’s. I think 1 shim added to balance weight of full 38 gallon tank.
    GELCW[QUOTED] likes this.
  14. Jul 19, 2021 at 10:23 AM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    They are 295/70's
