Tundra runs bad after driving 5 to ten miles or so.
Discussion in '1st Gen Tundras (2000-2006)' started by Darrentundra2000, Jun 13, 2021.
  1. Jun 13, 2021 at 3:52 PM
    Darrentundra2000
    Darrentundra2000 [OP] New Member
    Darren
    2000 tundra sr5
    Hi I have a 2000 tundra sr5 4x2. This is what's going on. I start it up in the morning and it runs great. I drive it to work it's about 20 miles. No problems at all. Then after I get off I drive back home. Still running good. When I start to get into stop and go traffic it starts acting up. When I give it gas it's real sluggish almost wants to die. Starts backfiring, no power at all. I can get it up to speed but I can't give it too much gas or it will start bogging down. If I stop and turn the truck off and start it back up again it will run good for about 5min. And then start running like crap again.
  2. Jun 13, 2021 at 4:27 PM
    And Check engine lights? How many miles? A bad 02 sensor will cause driveability issues.
  3. Jun 13, 2021 at 5:30 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Had an issue like this when my cat was bad on a Camry. The honeycomb collapsed inside.
    Is it throwing any codes?
  4. Jun 13, 2021 at 7:04 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I'm gonna guess fuel filter if it hasn't been changed recently.
  5. Jun 13, 2021 at 7:06 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Start with a basic tune up (fuel, air, oil, spark plugs), clean MAF as well. To me, sounds like a coil misfire.
  6. Jun 13, 2021 at 8:18 PM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I had this happen on a sienna. It would run fine for 20 minutes and then act like it was running out of fuel. It turned out to be the fuel pump. If you are up in the 200000 mile club, it’s a possibility.
  7. Jun 13, 2021 at 9:16 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Since it starts going bad on you in stop n go traffic, my guess would be a heat related issue. Sounds like a fuel pump to me too, but since its in the gas tank, don't know why it would be intermittent. I'd take Southpaw's advice, hit the basics and see where that gets you. With the symptoms you've listed, you should be throwing codes. You could get more help from the people on the forum if you can list them.
  8. Jun 13, 2021 at 9:27 PM
    If this is the kind of thing that only happens at a low idle (assuming that it’s at high idle when stopping and starting up the truck again), it’s a possibility of water in the the fuel. Usually though that shows up as a random misfire. A bottle of dry gas and a 1/2 a tank of additional gas would help rule that out.
  9. Jun 14, 2021 at 4:30 AM
    Professional Hand Model
    Fred
    Hand Protectors
    My Fuel Tank Gasket was gnar gnar when I recently replaced the Fuel Pump in a Prevent Maintenance Mode. Glad I did. Water/Rust was a leaking into the tank. I never experienced problems, but guessing it was caught in time.
    When I had a bad coil, it was bad all the time. It went bad and stayed bad. It put the truck in limp mode and wouldn’t go over 30mph. Felt like engine was off balance. Couldn’t finagle or massage it. It was gnar gnar, too.
    https://www.tundras.com/threads/the...t-‘build’-a-chronological-story.46816/page-10
  10. Jun 14, 2021 at 7:32 AM
    TurdFerguson
    TurdFerguson New Member
    Waynesboro, Virginia
    2000 TUNDRA SR5 AC 4x4 V8
    2002 TUNDRA SR5 AC 4X4 V8 TRD
    Bad cat should throw a code. Haven't had this problem on my Tundra, but have had similar issues on a couple other trucks. Fuel pump was failing and acted up when it got warm. A clogged filter can also cause the pump to warm up and cause problems.
