Where is the sweet spot power wise in the 5.7L
Discussion in '2.5 Gen Tundras (2014-2021)' started by GatorBodine, Jun 13, 2021.
  1. Jun 13, 2021 at 8:25 PM
    GatorBodine
    GatorBodine [OP] New Member
    New member here, just got my first Tundra. I also have a 05' 4runner w/ the 4.0 (wife's). Anywho, I was able to snag a 21' TRD OR limited in army green, a day ago. This is not a gripe, but I thought the 5.7 would have a little more umphfff. I have not got into the pedal yet, as I like to break in a motor a bit before doing so. I know the 5.7 is a great motor, just never driven one until now. I'm coming from a 6.7 powerstroke and have a Bullitt mustang w/ 480hp. The 6.7 was 400hp and 800 pounds of torque. So maybe I'm just used to the power in those, but I feel like the 5.7 is a little lacking in the bottom end. Truck has the TRD dual exhaust so I'm curious if that affects the bottom end of this motor. Does the 5.7 like the 4-5K range of the rpms? Am I off base with my opinion of the lacking bottom end power? I'm learning, new territory for me here.
    BTBAKER likes this.
  2. Jun 13, 2021 at 8:27 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Well put your foot into it and see. But it’ll never have the low end of a diesel.
    tttrdpro, Saltyhero13 and 15whtrd like this.
  3. Jun 13, 2021 at 8:37 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Pick your poison ..
  4. Jun 13, 2021 at 8:54 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  5. Jun 13, 2021 at 9:51 PM
    GatorBodine
  6. Jun 13, 2021 at 10:13 PM
    GatorBodine
    Gonna have to give tow/haul mode a try
  7. Jun 14, 2021 at 12:39 AM
    AZBoatHauler
    So.Arizona
    It will never be a PSD but it does like 3k+ RPM. Tow/haul does help off the line.
    15whtrd likes this.
  8. Jun 14, 2021 at 1:28 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    What the PSD stand for? My guess is "piece shit diesel"?
    SnowyTundra and 15whtrd like this.
  9. Jun 14, 2021 at 2:57 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Powder Smoke Die-sel.
    15whtrd likes this.
  10. Jun 14, 2021 at 4:28 AM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I had a 6.7 PSD and that turbo would spool and push you back into your seat as it catapulted that 8,500 pound truck into orbit. There’s no comparison—the Tundra has nothing on the PowerStroke. But… it will last for 300,000 miles without fear of such scary things as: DEF, Nox sensor failure, EGR valves, Cetane, $150 fuel filter changes, 16 quarts of synthetic oil at one change, too small parking spaces, cold-start babying, gas pump whoops, etc. And yes, the bed on the Toyota is actually bigger.
    I miss some things about my diesel, but it was a wiser move to get the Tundra. Enjoy it for what it is!
    R65, 15whtrd, Terndrerrr and 2 others like this.
  11. Jun 14, 2021 at 4:47 AM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    Yes a duel duel exhaust does cause you to lose a little low end torque.
    15whtrd likes this.
  12. Jun 14, 2021 at 5:26 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Give the pedal commander a try. The 5.7's do tend to feel a little sluggish on the low end, especially compared to a PSD. If that's not enough go with a DAP tune and/or supercharger.
  13. Jun 14, 2021 at 5:32 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    You will never replace the grunt feeling of a diesel no matter what you do to the 5.7L Tundra. Diesels are just far superior in all aspects of low end power and torque. Gas engines especially the 5.7L Iforce need to rev out to get you in the power band.
    15whtrd likes this.
  14. Jun 14, 2021 at 5:32 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The 5.7L is rated at 381 hp @ 5600 rpm; 401 lb.-ft. @ 3600 rpm
    You can add a supercharger for more umphfff... making the truck, wheels and tires as light as possible will also help.
  15. Jun 14, 2021 at 5:38 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    push tow haul button, your concern will quickly diminish. Toyota in their quest for better fuel mileage has alot of deadband in the accelerator pedal. You accelerate slower you get better fuel mileage. If you like tow/haul mode you will love the pedal commander. It manipulates gas pedal displacement vs throttle input. Big difference though is the transmission shifts normally. I left a F250 6.7 for Tundra. At least the Tundra can turn, not rattle your teeth out, not live in regen, blah blah blah.
    As far as torque I am pretty sure my Tundra with my 5Klb boat being towed (in tow haul mode) could out run my 2017 Powerstroke to 60 mph from a dead start. Assuming both towing the same boat. Now when that changes as far as trailer load I don't know but it is not 5Klbs. Maybe 8klbs. Obviously a Tundra can't tow 15Klbs but an F250 can.
  16. Jun 14, 2021 at 5:50 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    I'm coming from a tuned '18 F150 EcoBoost so I feel your pain. When you're done breaking it in and are entering the on-ramp on the highway, lay into it. You'll get a good idea of where the power band is ;).
    I've got a Stillen CAI and DirtyDeeds exhaust system on my Tundra, so it has some balls, but you're never gonna get the jump off the line with these 4million pound, naturally-aspirated trucks that you'll get with anything turbo-charged like your diesel or a better power-to-weight ratio like your Mustang.
    GatorBodine[OP] and 15whtrd like this.
  17. Jun 14, 2021 at 6:53 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I drove an F150 with the 3.5 eco boost. Maybe there was something wrong with it. If I crushed the gas pedal, after a slight hesitation it would take off, normal driving staying out of the gas it was a dog. Nothing for free. Best drivability will be displacment, all the turbo have lag......
    15whtrd likes this.
  18. Jun 14, 2021 at 7:00 AM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    Yeah that hesitation is turbo lag. Like I said, my 3.5L EcoBoost had a tune. It hauled ass and had zero turbo lag, but any un-tuned turbo charged vehicle (like OP's diesel) will have turbo lag.
    But I'm not here to argue about Ford vs Toyota. I obviously traded in my Ford for my Toyota for a reason.
    I'm just saying that the powerband in the 5.7L is DEFINITELY not felt off of the line like a turbo charged vehicle, it's felt at 5K RPMs+.
  19. Jun 14, 2021 at 7:00 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Turn the nannies off and drive in "S" mode.
    My 2¢>
    tttrdpro likes this.
  20. Jun 14, 2021 at 7:37 AM
    GatorBodine
    I appreciate the informative posts fellas! Much more helpful than the stupid ass acronym comments the haters gave. I knew the Tundra wasn't gonna compare to a 6.7 in power. I wanted a Tundra and I was getting tired and concerned of the maintenance the 6.7 would need as miles racked. Figured I'd get out while I was ahead before, turbos, injectors, death wobble, etc etc ate me alive. I'm excited about my Tundra.
  21. Jun 14, 2021 at 7:37 AM
    GatorBodine
    Gonna give that a try today!
  22. Jun 14, 2021 at 7:40 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    After owning a supercharged 5.7, I'll never own another gas vehicle without boost...I came from a diesel too and know I made the right decision on which gasser to buy...but the SC'r is the bug reason why...
    snivilous and GatorBodine[OP] like this.
  23. Jun 14, 2021 at 7:44 AM
    14crewmax
    14crewmax New Member
    Oroville Ca
    2014 TRD off road crew max 4x4 silver sky metallic
    Stock
    bully dog tuner woke mine up
  24. Jun 14, 2021 at 8:19 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    You might try the Nanny Delete operation.
    1: Hold the VSC button ~3 seconds (long enough to see traction control light on the dash) and release.
    2: Hold the VSC button ~3 seconds again (you'll see traction control and another dash light not sure what it is) and release.
    3: Tow/Haul mode for the better shift points.
    Boom!! Feels like an instant 50 more hP :bananadance:
    15whtrd and sask3m like this.
  25. Jun 14, 2021 at 8:23 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Comparing my since traded 08 to my 19 the newer Tundra are definitely not as responsive as the older ones were in lower speeds. My gas mileage has improved a bit so I suspect this has something to do with it.
    GatorBodine[OP] likes this.
  26. Jun 14, 2021 at 8:23 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    can someone explain what turning this off actually does to improve performance?
  27. Jun 14, 2021 at 8:36 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I have no idea, but combined with tow/haul it works well. Aptly named Beast Mode by some. Throttle response is much quicker, etc., feels like you are driving a more powerful truck.
  28. Jun 14, 2021 at 8:39 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    The truck feels like a dog with the traction control retarding the ignition or applying the brake to a spinning tire. With those features disabled you can actually apply as much of the 381 available hP as you want to.
    15whtrd likes this.
  29. Jun 14, 2021 at 8:40 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    The main thing is it will keep the ecu from cutting the throttle when it detects wheel spin. Can’t burn a proper donut with that shit turned on.
    15whtrd and Bikeric like this.
  30. Jun 14, 2021 at 8:43 AM
    Rex Kramer
    Georgia
    My 2007 has it's original "hyper sensitive" gas pedal, and I love it. Maybe you could find one of these old gas pedals for your truck, because a lot of guys replaced them with one that is not as sensitive.
    15whtrd likes this.
