Front shocks and springs .
Discussion in '1st Gen Tundras (2000-2006)' started by sr52000, Jun 12, 2021.
  1. Jun 12, 2021 at 8:46 PM
    sr52000
    sr52000 [OP] New Member
    2000 Toyota Tundra SR5
    Hope you guys are having a good weekend .
    Newbie question , I'm in the process of replacing my front shocks and springs from stock to Eibach with about 2 inches lift , took the old one off , replaced with the new one , secured the top of the shock but can't get the bottom to align with the holes in order to get the bolt on . Any tips or tricks to get the shock to align ? thanks in advance .
  2. Jun 12, 2021 at 8:55 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    A big ass prybar helps
    sr52000[OP] likes this.
  3. Jun 12, 2021 at 9:20 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Disconnect those four bolts underneath next to the lower ball joint for more play
    Edit: make sure to hold it up with a jack or something because it’ll want to flop over
  4. Jun 13, 2021 at 2:45 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Disconnect the stabilizer bar bushing, then a medium ass prybar will work
  5. Jun 13, 2021 at 5:36 AM
    badmotofing3r
    Zach
    Wyoming
    Hot Tamale
    Yeah I suppose a big ass prybar would be like a 4 footer. Medium ass should suffice.
  6. Jun 13, 2021 at 7:49 AM
    Ratchet strap from the frame to the lower shock mount. tighten until the holes line up. May be able to use a small ass prybar then.
    sr52000[OP] and Tundra2 like this.
  7. Jun 13, 2021 at 8:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is what I did. Worked pretty good, and felt safe.
  8. Jun 13, 2021 at 1:09 PM
    sr52000
    Damn bud you saved my day ... been playing around with huge , big , medium ass pry bars with no success . A ratchet strap did the trick , thank you very much !!!
  9. Jun 13, 2021 at 1:10 PM
    sr52000
    Thank you very much fam !
  10. Jun 13, 2021 at 1:12 PM
    sr52000
    finally got the sucker to align
  11. Jun 13, 2021 at 1:43 PM
    sr52000
    Things get more and more interesting LOL
    Jack McCarthy likes this.
  12. Jun 13, 2021 at 2:31 PM
    That's a modified version of the technique I used, glad it worked for you. I attached the ratchet strap to the inboard portion of the frame at the level of the lower eye of the shock. I used the ratchet strap to pull the shock in towards the frame effectively using the lower A arm as a ramp to guide the eye up into the hole. Your technique of using it to slightly shorten the assembly seems to have worked well also.
  13. Jun 13, 2021 at 2:35 PM
    How much torque were you using on that stud that broke? If it was the prescribed amount (about 83ft/lbs I believe) and it broke, I would probably replace them all. If you just went he-man on it with a breaker bar and it broke, I would probably replace them all, since you've likely stretched them all out and weakened them.
  14. Jun 13, 2021 at 2:50 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Also, I would recommend getting a Lisle stud install tool.
  15. Jun 13, 2021 at 3:58 PM
    Whoa, someone needs to turn down the PSI on their compressor when tightening with an impact wrench or as as another member here might say, “Do not exceed 25 ugga duggas”.
  16. Jun 13, 2021 at 3:59 PM
    sr52000
    I went all in with a breaker bar , I thought it would be overkill but was not expecting it to brake .
  17. Jun 13, 2021 at 4:00 PM
    sr52000
    def went above 25 on that one LOL
  18. Jun 13, 2021 at 4:00 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Probably just got weak overtime.
  19. Jun 13, 2021 at 4:03 PM
    sr52000
    Here's how it's sitting with the Eibachs shocks/springs (bought from 1stgen assembled) .
    Beefnbread likes this.
  20. Jun 13, 2021 at 6:33 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
