TRANSFER CASE
Discussion in '2nd Gen Tundras (2007-2013)' started by AnthonyC, Jun 13, 2021.
  1. Jun 13, 2021 at 3:09 PM
    AnthonyC
    AnthonyC [OP] TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    Has anyone ever rebuilt their transfer case in a 2nd Gen Tundra? I have a 2010 TRD. This coming Thursday I will be pulling mine apart. I drained it 3 weeks ago and I got a few flakes of aluminum out of it. A bearing has been making noise for a while and I just ignored it. When I pulled our new RV to Gettysburg, PA and back, the bearing noise is a little louder now. I got all the bearings and seals necessary to overhaul it. But I think something in there went hay wire to create a bearing noise to start off with. My older Brother (he passed 2 years ago April) lived on a mountain top in upstate, NY. His driveway is 3/4's of a mile long for real! Every time I went to visit I had my 4 wheelers on the trailer, low range because it's a pretty rough off road climb. A bearing in the transfer case would start making noise after about a 1/2 mile. It would only do it climbing that mountain, so I actually forgot about it until I pulled our RV. The flakes of aluminum bothered me more than finding fine metal particles. For some reason the bearing is not getting oil on a steep climb, and that it is. A steep climb! If anyone can bring light to me, please do.
    I've been around the block a little. The heavy equipment and 18 wheelers were working for private companies from 1971 to 2009. I feel if I could build a gearbox the size of my Harley Davidson, I can do a Toyota Tundra transfer case. If I can build Diesel and Gasoline engines, and rebuild my Harley Davidson transmission, I can rebuild a Toyota Tundra transfer case. I will do my best to inspect this transfer case, if any part of this case is gouged inside and I can't see why. I'll put a new case in it!
    If I can help anyone here, I will do the best that I can.
    Thanking you in advance,
    Anthony C
