HU Replacement, what are these?
Discussion in 'Audio & Video' started by point08, Jun 12, 2021.
  1. Jun 12, 2021 at 7:41 PM
    point08
    point08 [OP] New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Hey hive mind,
    I'm replacing the stock stereo HU with a Pioneer DMH-1500NEX + Maestro RR (only thing I can find in stock) and I am perplexed by what these two cables are for? One is black, one is white. Both have the same connection on the end. Are these for Sirius XM and something else? Everything seems to work outside of the Factory microphone. I can't tell if I am able to retain that or not with the Maestro or if I have to use the one that shipped with the HU (which I'd rather retain the factory microphone if possible).
    The Maestro instructions don't mention them and Crutchfield didn't offer any cables for them when attempting to piece out what I needed for the swap.
    Thanks!
  2. Jun 12, 2021 at 7:57 PM
    The factory microphone is not retained with the Maestro. The black connector looks like either the GPS or sat radio antenna. I don't recall the white one when I installed my Pioneer.
    point08[QUOTED][OP] likes this.
  3. Jun 12, 2021 at 7:59 PM
    Forgot to mention that not all cables with the Meastro will be used. Most of the functions are in the data cable. You won't use the OBD port cable either.
    point08[OP] likes this.
  4. Jun 12, 2021 at 8:02 PM
    point08
    Kyle
    Thanks for the quick response. Shit. I was hoping to save the factory mic. Guess I'll run it up to the steering wheel to mount it. Oh well. I'll quit googling for an answer I'll never find.
    Looks like I need to pick up the TO2 harness. Not that I necessary need it but may as well hook it up.
  5. Jun 12, 2021 at 8:02 PM
    point08
    Kyle
    I don't need this for the gauge output?
  6. Jun 12, 2021 at 8:12 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    In my 2015 with the non-JBL radio the 2nd antenna connection was not there and it was needed to set the clock in the radio that I replaced it with.
    I replaced the radio with a newer better but still non-JBL radio and I had to buy a cheap Sat Antenna just so the stupid thing can set the clock at all.
    It somehow uses the Sat radio tuner to set the clock.
    So the one is for the Sat Radio and the other is to set the clock.
    Guess how long it took me to figure that one out?
    So you should not need that second one for any other radio I have ever seen anywhere.
    For sure one of the strangest "Features" that I have ever seen?
  7. Jun 13, 2021 at 8:25 AM
    liddown
    liddown New Member
    First picture the wire with the foam around it is the GPS antenna, the second picture is the satellite antenna.... There is a separate wiring harness beyond the T02/3 to adapt these. Both adapter come in a single kit...
  8. Jun 13, 2021 at 8:42 AM
    point08
    Kyle
    Thx for confirmation. If I don't have nav on the stock unit, what would the GPS be used for?
  9. Jun 13, 2021 at 8:46 AM
    liddown
    liddown New Member
    I do not believe that is used for anything... It would have been there as a normal chassis build, so if the Nav has been included as an option the antenna would be in place... The antenna itself sits just under the top of the dash.... So if you are not installing an after market radio that needs GPS then you can leave it disconnected...
  10. Jun 13, 2021 at 9:55 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I think the GPS antenna may be used when you hook your phone up to the HU.
    But I don't even see a GPS antenna plug on your HU.
    Did it come with one?
    If yes, use it and tuck under the area of the center dash speaker.
    If you want Sirius/XM you'll need a SiriusXM 3.0 tuner.
    But in all honestly, it will sound better if you run off your phone with the Sirius/XM app.
    It is easier to navigate on the screen with the SiriusXM 3.0 tuner, but the sound is so much better off the app.
    I don't even use the SiriusXM 3.0 tuner in my Tundra anymore.
    I use wireless Carplay and app.
    As to the bluetooth mic.
    I tucked my wires thru the dash behind the steering wheel and up behind the pillar and headliner.
    It is easier if you remove the pillar.
    I don't even notice mine is there anymore..
  11. Jun 13, 2021 at 4:30 PM
    point08
    Kyle
    Was able to wire the new stereo mic up in a few minutes. Wife said I sounded really clear when testing. I ordered the missing harness and it will be here when it gets here.
    Tested it out with and without the OBDII sensor and definitely need it if I want the car features gauges. Though I don't seem to have transmission temp or tire pressure.
  12. Jun 13, 2021 at 4:42 PM
    liddown
    liddown New Member
    Tire Pressure will work when you get the cable... However the Transmission temp and oil temp do not work on the RR... Maestro has told me that those codes are not being sent on the CANBus channel they are listen too... Oh and I have 2019 CrewMax as my reference...
  13. Jun 13, 2021 at 5:16 PM
    point08
    Kyle
    Which cable? The GPS and Satellite XM cable?
  14. Jun 13, 2021 at 5:21 PM
    liddown
    liddown New Member
    Sorry the TO2 or TO3 whichever is the one that is spec'ed for you model/year...
  15. Jun 13, 2021 at 10:47 PM
    point08
    Kyle
    That cable will enable tire pressure?
    I ordered whatever idatalink said to get that I'm missing. Should be here in a week.
