Running wires from engine bay to cab
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Jun 12, 2021.
  1. Jun 12, 2021 at 2:43 PM
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    I’m trying to figure out how to run wiring for the front locker into the cab and would like some input/your opinions. I’ve run some wires through the section on the driver side but there isn’t room for the harness.
    Harness:
    Driver side that’s pretty much stuffed:
    I ran the compressor wiring through here but the harness for the locker is fairly thick which makes me hesitant to run it here:
    Did see this on the passenger side and considering cutting a hole to fit the harness:
    Any thoughts on which location would be best, any areas you all have run wires not in above pics?
    Thanks!
  2. Jun 12, 2021 at 3:08 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've been able to push different connectors through both those driver and passenger grommets, you should be able to as well. Carefully cut a hole, stick a piece of bailing wire through first and either wrap it or tape it to that connector to help work it through. If you're worried about water getting through the incision when you're done, use some epoxy or liquid tape to seal it back up.
    Darkness and Voss[OP] like this.
  3. Jun 12, 2021 at 3:19 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I went through the floor pan on the passenger side. But I happened to have a spare grommet from the driver side floor pan
    Darkness, Voss[OP] and des2mtn like this.
  4. Jun 12, 2021 at 3:21 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    De-pin the connector and fish wires through the existing hole?
    Or cut, feed through and splice back together after.
  5. Jun 12, 2021 at 3:38 PM
    Voss
    2003 AC TRD 4x4
    Thanks guys!
