Misfires/rough idle
Discussion in '1st Gen Tundras (2000-2006)' started by Dadof5boys, Jun 12, 2021.
  1. Jun 12, 2021 at 12:29 PM
    Dadof5boys
    Dadof5boys [OP] New Member
    Jamie
    2003 Tundra limited 4.7L
    I've posted about this problem before but I have new info now. Engine started running rough and i had misfires on 2 and 5. I took all the plugs out and did a compression test. I have 0 compression on cylinder 2. I put everything back together and started the truck and it runs rougher than before. Code reader says misfires on all 8 cylinders. I took out all plugs again and they are soaked with gas. I had an old original set sitting around so I put those in. Truck barely starts and still misfires on all 8 cylinders. I dont know what to do next.
  2. Jun 12, 2021 at 12:46 PM
    Professional Hand Model
    Fred
    Hand Protectors
  3. Jun 12, 2021 at 12:58 PM
    Dadof5boys
    Jamie
    Your message was blank.
  4. Jun 12, 2021 at 12:59 PM
    Fred
    Hand Protectors
    I tagged a Toyota Mechanic. Hopefully he can help.
    MS22 likes this.
  5. Jun 12, 2021 at 1:02 PM
    Dadof5boys
    Jamie
    Ok. Thank you. Hopefully he will respond.
  6. Jun 12, 2021 at 1:03 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You had 0 compression on 2? If that’s the case then we have a big problem here
    15whtrd and Jack McCarthy like this.
  7. Jun 12, 2021 at 1:04 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    leaking fuel injector seals? If the engine is flooded then it wouldn't create spark.
    BubbaW likes this.
  8. Jun 12, 2021 at 1:05 PM
    empty_lord
    05 rollover special
    If injectors were plugged in when the compression test was being done, there’s a good chance cylinders are flooded. But the big red flag is 0 compression. In cylinder 2
  9. Jun 12, 2021 at 1:14 PM
    Dadof5boys
    Jamie
    Yes, injectors were plugged in. I didnt know to unplug them. I just unplugged the individual ignition coils and removed all spark plugs to do the compression test. But that was all done last week. I had no compression on cylinder 2. After putting it all back together, I got misfires on all cylinders. Today, I swapped the plugs with the original set and that's when i noticed all the plugs were wet with gas. When i put the other set of plugs in,the truck didnt start right away and when it finally did, it wont stay running without giving it gas.
  10. Jun 12, 2021 at 1:27 PM
    empty_lord
    05 rollover special
    One dead cylinder can drag all the cylinders along with them. I would redo the compression checks with all the cylinder dried out and injectors unplugged and see what readings you get
    Filthyphil likes this.
  11. Jun 12, 2021 at 1:32 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    not a mechanic but have always done how I was taught many years ago which matches the FSM.
    15whtrd likes this.
  12. Jun 12, 2021 at 1:32 PM
    Dadof5boys
    Jamie
    Ok. How long should I let the cylinders sit to dry out?
  13. Jun 12, 2021 at 1:58 PM
    Dadof5boys
    Jamie
    When I did the compression test,I pulled the fuel pump relay so no fuel should have been pumped through the injectors.
  14. Jun 12, 2021 at 6:30 PM
    Dadof5boys
    Jamie
    Could this be that my timing belt jumped a tooth?
