impossible
Discussion in '1st Gen Tundras (2000-2006)' started by bewildered, Jun 11, 2021.
  1. Jun 11, 2021 at 12:20 PM
    bewildered
    bewildered [OP] New Member
    blue 2006 tundra sr5 v8
    I replaced the shoes on the rear drum brakes. Now the drum wont go over the shoes. I have the adjuster all the way closed. Help
  2. Jun 11, 2021 at 12:25 PM
    Is everything back in the correct position?
  3. Jun 11, 2021 at 12:51 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    I think you have to loosen this. Once the drum is on, there should be a slot on the other side to tighten/adjust it. It's been a long time since I've done a rear brake job though.
  4. Jun 11, 2021 at 1:33 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Ya. He said he had adjusted that ‘all the way closed’ already.
  5. Jun 11, 2021 at 1:35 PM
    Fred
    Hand Protectors
    Sometimes with the new Rear Drum Redo one needs to smack the Shoes (up and together) with both Hands to Reset the Mojo. Then retry the Drum Install.
  6. Jun 11, 2021 at 3:11 PM
    Take a look at the other side you didn’t do for comparison to see how everything is seated. Sometimes it just takes a slight reorientation to get it on there for the first time with new shoes. As a rule I always double check the new shoes to the old to make sure they’re identical. Sometimes just slapping both sides simultaneously gets them seated a little better to fit.
    If all else fails invite a friend over for a beer and ask them to help out. Sometimes it just takes someone who has done it more often to get it on there the right way.
    des2mtn and Tundra234 like this.
  7. Jun 11, 2021 at 6:28 PM
    bewildered
    Every thing is correct , except after further inspection of the old shoes
    I found a really odd wear pattern.
    The brake lining was worn thin on one end of the shoe and still ample at the other end. The drum was out of round. I should change this thread name to stupidity. Lol
    Jack McCarthy and Darkness like this.
  8. Jun 11, 2021 at 6:30 PM
    bewildered
    I had the adjuster loosened all the way.
  9. Jun 11, 2021 at 6:30 PM
    Does it need to go the other way maybe?
  10. Jun 11, 2021 at 7:39 PM
    BMET
    BMET New Member
    2018 Tundra Limited
    My bust. Looking at the picture and it looked like there was room to tighten it down.
    Darkness likes this.
  11. Jun 11, 2021 at 9:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Back to the OP's original problem. With the obvious uneven wear you found on the pads, and the fact that you are dealing with 15 yr. old drums, I would definitely just replace them. New drums, new shoes, happy camper.
    NewImprovedRon, rockmup and Tundra2 like this.
  12. Jun 11, 2021 at 9:18 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Any chance they're the wrong parts??
    Jack McCarthy and abcinv like this.
  13. Jun 11, 2021 at 11:46 PM
    bewildered
    Hahaaahaaahaha
  14. Jun 12, 2021 at 5:59 AM
    Fred
    Hand Protectors
    Our Original 1st Gen Brake Shoes usually wear unevenly as a norm. They’ll be thinner in some areas etc.
    Be careful if you go with new Drums as many aftermarkets will throw you a new problem in premature warping and shimmys. Many members have learned this the hard way.
    OEM Shoes are best bet on OEM Drums.
    I’m guessing the Drum Stretcher idea triggered some people here?:rofl:
    N84434 likes this.
  15. Jun 12, 2021 at 6:25 AM
    NIOSH
    NIOSH New Member
    2021 1794 CrewMax Army Green
    ELKA, 35", Harrop, lockers w 4.88
    Check the simple things like did you forget to release the Parking brake. Is the adjustment bolts below the drivers seat a set to tight.
    NewImprovedRon likes this.
  16. Jun 12, 2021 at 8:34 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Making the drum stretcher thing sort of real, OP see if there is a little burr or ridge at the mouth of the drum outside of where the shoes wore. Knocking that down with a flap wheel helps the drum go on. Beyond that, I usually hit the shoe faces with sandpaper until the drum will slide home.
  17. Jun 12, 2021 at 9:00 PM
    ToyotaJim
    ToyotaJim New Member
    You need to
  18. Jun 12, 2021 at 9:13 PM
    TILLY
    Massachusetts
    Jim needed to suddenly leave before finishing his thought. ;)
    N84434, onesojourner, Tundra2 and 3 others like this.
  19. Jul 2, 2021 at 1:00 PM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    Grind a little on the tabs at the contact, could be paint buildup on the new shoes
  20. Jul 2, 2021 at 4:30 PM
    Did you compress the brake cylinder all the way? Crack the bleeder and compress the brake cylinder all the way if not. Jiggle the shoes till they are "round" and not out of round. May help. Also grinding the lip off the drum may help.
    bewildered[OP] likes this.
