Engine Light - codes PO420 and PO430
Discussion in '2nd Gen Tundras (2007-2013)' started by Jinxie, Jun 7, 2021.
  1. Jun 7, 2021 at 6:52 PM
    Jinxie
    Jinxie [OP] New Member
    Hi
    2008 double cab with a 4.7 and 176,000 miles. Truck starts great, runs great and is smoother than any other V8 I’ve owned. However.....it throws these codes.....only these codes at the same time.
    PO420 below threshold bank 1
    PO430 below threshold bank 2
    I can clear them with my code reader.....but they reappear after 50-70 or more miles. Totally random. What do these codes mean? How and where can I start troubleshooting this?
    Truck still runs great.....will the light on affect anything??
  2. Jun 8, 2021 at 8:26 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Whatever you do, don't freak out and buy new cats or anything like that.
    Also don't freak out and start throwing 02 sensors at the truck.
    Go to your local autoparts store and buy a can of MAF sensor cleaner. Pull the negative cable off your battery, remove the MAF sensor, then clean it.
    https://www.youtube.com/watch?v=xQGSkWEC_u4
    Because you have both P0420 and P0403, this points very strongly at the MAF sensor. If you have a scanner that leads live data, you can drive around and monitor what the MAF is doing to see if it makes sense (reading more air the higher the RPMs are, dropping back down as expected, and showing approximately the correct value at idle).
  3. Jun 8, 2021 at 8:36 PM
    Jinxie
    Thanks
    I’ll try this tomorrow
    I was also reading up on the spark plug foulers mounted in the o2 sensors
  4. Jun 8, 2021 at 8:37 PM
    audiowize
    Paul B.
    The non foulers will likely be more annoying than just fixing whatever is triggering the problem. If you just had a P0420 and nothing else, and maybe you had a Nissan, I'd say go for it on the non foulers!
  5. Jun 8, 2021 at 8:38 PM
    G3N1U5
    G3N1U5 New Member
    Gerald
    2008 Tundra Max
    Following to see if this works. I am having the same issues.
  6. Jun 8, 2021 at 10:43 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
  7. Jun 8, 2021 at 10:49 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Any chance you have long-tube headers?
