OFFROAD TRAILER BUILD
Discussion in 'Other Builds' started by SK_MACHINE, Jun 7, 2021.
  1. Jun 7, 2021 at 7:40 PM
    SK_MACHINE
    SK_MACHINE [OP] New Member
    Wompy
    CA
    2021 DC TRD 4WD
    Scratches on paint, coffee stain on seat, nail in tire, dog saliva on rear windows
    Back story: I've looking to build an offroad trailer when my friend's 7x10 utility trailer he had sold came back up for sale. It's built right and handles great so I scooped it up from his friend and tore it down. I knew it would be a bit much for my Tacoma once fully fitted and since I could still get good money for it, I decided to sell it and get a new Tundra TRD SR5.
    The plan is to raise it 4", enclose it and and get the right stuff that I need for camping. Since I really hate the small doors in the teardrops I'm not making a short one for sure, and since tent trailers take time to pop up, need care and can get COLD, that's not an option for me (mostly my wife,lol).
  2. Jun 7, 2021 at 7:45 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    I like the level of commitment. These builds are fun to watch. I am looking forward to see what you come up with.
    Black Wolf, W3agle and SK_MACHINE[OP] like this.
  3. Jun 7, 2021 at 8:00 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    I am trying to stay within a budget of about $6k, so Timbren axles won't be part of this build as of yet. Maybe in the future. However ditching the original square drop axle for a new 3,500lb Dexter axle I did get the 24" height I was looking for. 17" Procomp steelies and 285/70-17AT tires will provide the cool guy look. Once installed I'll post pics; tires are on backorder. The trailer did come with tired shocks so I replaced them with Monroe 555003 and designed new lower shock mounts and sent to Sendcutsend.com for lasering.
  4. Jun 7, 2021 at 8:18 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    First rabbit hole I went down quite willingly have you is the Electronics dept. Here's what I came up with for my needs:
    Renogy 200Ah Battery (120lbs, yikes)
    Renogy 1000w true Sine Wave Inverter
    Progressive Dynamics 45W Converter/Charger
    Go Power! TS-30 30 Amp Automatic Transfer Switch
    Two Circuit 30A Load center Box
    12V fuse box, Amp meter, switches, circuit breaker, etc.
    Generac 7117 - GP2200i 2,200 Watt Portable Inverter Generator, 50ST/CSA
    (Solar is for hippies)
  5. Jun 7, 2021 at 10:16 PM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    This is exciting!
    Black Wolf likes this.
  6. Jun 8, 2021 at 6:12 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    A problem I ran into designing the rig is the crazy cost of RV doors and lack of custom sizes. I plan on putting my door at the rear left swinging to the right and locking open onto a latch. Size will be 24"x66" just tall enough for minimal ducking without making the trailer so tall. More on that later. I'm using 1-1/4 square tubing x .06 wall and found there's no nice budget friendly lock I could find and incorporate to the door other than the typical RV door latches which are fine and I've decided to use. I needed to mount/weld it somehow to the door so enough talk and here's another part I designed and had laser cut and bent from Sendcutsend.com for the lock. IMG_0082.jpg
  7. Jun 8, 2021 at 6:15 PM
    Following this....
    Squatting Pigeon and huntsonora like this.
  8. Jun 8, 2021 at 6:19 PM
    I bought this Texas Bragg trailer in Anchorage in 2011. Time to modify! First thing is to replace the wood.
  9. Jun 8, 2021 at 6:21 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    You can DOOOO it !!!!!!!!!!!
    Squatting Pigeon and Black Wolf like this.
  10. Jun 8, 2021 at 6:26 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Second thing is to stain the wood black.
  11. Jun 8, 2021 at 6:30 PM
    Definitely doable! Been sitting in the backyard ever since I got back...heh...heh...
    Have decent welders. One is old as f++k but high amps. My trailer is currently used as a Big Wheel launch pad....
  12. Jun 8, 2021 at 6:33 PM
    Blaaaaaaak!
    TheBeast and Darkness[QUOTED] like this.
  13. Jun 8, 2021 at 6:34 PM
  14. Jun 8, 2021 at 7:27 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Might be too late to change but I'm gonna suggest it.... have the trailer run the same bolt pattern as the tow vehicle. Have the same tire size for truck and trailer. Spare tire on the trailer and a spare on the truck that are interchangeable. You don't have to worry about the first flat, you have to worry about the second one.
    As for the walls, if you're gonna insulate them, use a foam insulation. Fiberglass with fall down over time from the vibration of going offroad.
    shawn474, Wynnded, rockmup and 4 others like this.
  15. Jun 8, 2021 at 8:08 PM
    Very good advice:thumbsup:
  16. Jun 8, 2021 at 8:17 PM
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Following this good luck on the build !
  17. Jun 11, 2021 at 12:15 PM
    2mchfun
    I cut up old bed liners and used the plastic to create a barrier between my floor and the elements. Just an idea for you.
  18. Jun 11, 2021 at 12:20 PM
    2mchfun
    I also built much of the floor after the sides and roof so my floor was never exposed, plus I sealed it all with several coats of black asphaltic driveway sealer. Never will rot out. Just saying, floor is critical.
    Black Wolf and SK_MACHINE[OP] like this.
  19. Jun 11, 2021 at 12:25 PM
    2mchfun
    More advice for you guys, I keep old dried out tires on my trailer to help prevent theft, good tires are mounted up and ready in my garage. Impact and 15 min to get ready.
    Black Wolf and Baja Mike like this.
  20. Jun 12, 2021 at 4:06 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    Thanks for your input. I'm using foam insulation for sure and plastic polywall sheet glued to the insulation and the bottom of the trailer then sandwiched together with wood strips on top to keep it rigid. An anti theft device as well is my lock n roll tongue hitch designed only for this type of connection so if the thief doesn't have that type of hitch then it's going to make it way harder to move. Plus I'll make some type of anchor into a fresh poured concrete footing and a bell to alert the hounds.
    I ran into a little miscalculation on my part today. I grabbed 27" leaf springs instead of 25-1/4 so its pushing my axle center/ tires back a bit. Going to exchange on Monday. Check out those 33's though. Lug pattern is 6x 5.5 like my old Tacoma so I'll most likely be carrying two spares. Maybe in the future when I change idler hubs I can go with 5 x5-1/2 and get wheel adapters for 150mm BC.
  21. Jun 12, 2021 at 4:08 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    In the meantime check out these trick ABS plastic pieces I designed for my tail light setup.
  22. Jul 16, 2021 at 11:22 AM
    sportrider
    sportrider New Member
    Stephen
    2017 White Crewmax Limited
    How is the build coming along? Have been waiting for new updates.
  23. Jul 24, 2021 at 8:14 PM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    Nothing new lately since I've been working a bunch and it's pretty hot when I get home. But It's on the ground and rolling and I did order and receive my 1x1 square tubing to start the frame and 1-1/4 tubing for the door. FYI, Evolution chop saws work really well but the saw blades don't last too long which I expected. I have the smallest 7-1/4 chop saw which cuts steel tubing fast and clean.Here's something cool though...I make custom Harley parts and I redesigned my switch perches and added mirror mounts to them. I'll start these Monday on the HAAS at work. IMG_0503.jpg
    Baja Mike, Wallygator and Black Wolf like this.
  24. Jul 24, 2021 at 8:21 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    :threadjacked:
    :threadjacked::smack:
  25. Jul 25, 2021 at 2:21 AM
    Nice switch perch design! Did you get the 25 1/4" leaf springs swapped in? Looking forward to watching how this project progresses!
  26. Jul 25, 2021 at 5:07 AM
    Not jacking at all. Following. Quite interested how this project works out since I have a trailer that I want to do a makeover with and looking forward see what things OP does with it. Posted pics of my trailer for OP to see. OP positively acknowledged. That was nice. That's what counts. :smack:
    2mchfun likes this.
  27. Jul 25, 2021 at 7:12 AM
    Wallygator
    Subscribed!:thumbsup:
    SK_MACHINE[OP] likes this.
  28. Aug 7, 2021 at 10:37 AM
    SK_MACHINE
    Wompy
    CA
    2021 DC TRD 4WD
    Update !!! Subfloor and 2" foam going in !!!! Control center plate cut out and fitted to electronic switches, gauges, and stereo. Here's something cool I'll be using: The stereo comes with a back up camera which I'll place somewhere outside and if we hear a noise at night we can flip the stereo on and switch to camera mode to see what wildlife are outside.
    2mchfun, Wallygator and Black Wolf like this.
  29. Aug 7, 2021 at 12:45 PM
    Nice :thumbsup:
  30. Aug 7, 2021 at 1:03 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    You actually gave me an idea to just add cams to every corner of a travel trailer. Now I have to find the cheapest way to do it and display on iPad
