Drive shaft play
Discussion in '2nd Gen Tundras (2007-2013)' started by Ricos, Jun 7, 2021.
  1. Jun 7, 2021 at 10:55 AM
    Ricos
    Ricos [OP] New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Hi guys,
    My tundra has play on the drive shaft see YouTube link :
    https://youtube.com/shorts/RD19gb_IfsA?feature=share
    also since I lifted the front and back I think the shaft has come out a little but in my opinion it now has to much play and a too big gap.
    what do you guys think ?
    I have no tundra to compare it too...
  2. Jun 8, 2021 at 12:41 PM
    Ricos
    Ricardo
    Never stopping ...
    Anyone that can make a picture for me from the gearbox driveshaft gap ?
  3. Jun 8, 2021 at 1:45 PM
    15whtrd
    15whtrd Mr. Blonde
    I went out to get a video for you and my transmission driveshaft looks nothing like that. You must have a 2x. AF2E422D-C90C-424D-913B-06C870439BB3.jpg
  4. Jun 8, 2021 at 2:00 PM
    Ricos
    Ricardo
    Never stopping ...
    Im sorry if forgot to mention I’m looking for a 2WD/RWD picture , 4x4 is differtent I can tell by your post
    15whtrd[QUOTED] likes this.
  5. Jun 8, 2021 at 3:03 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I have a 4wd too or I would look. Is this a two piece driveshaft with a center support bearing? If so, how is the center support bearing?
    On most transmission, there is a bushing in the output housing.
  6. Jun 8, 2021 at 9:11 PM
    Ricos
    Ricardo
    Never stopping ...
    Yes 2 piece drive shaft with a carrier bearing in the middle.
    I already replaced the carrier bearing once , but it got damaged during wheel aligning I guess, so I ordered a new one.
    What do you mean by there is a bushing in the output housing ?
  7. Jun 9, 2021 at 4:17 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Inside the extension housing at the rear of the transmission, just behind the rear output shaft seal, is a bushing. This bushing centers and supports the smooth outer surface of the driveshaft yoke. If it starts to wear, it will allow the yoke to move, side to side, like in the video. The only fix is to have this bushing replaced.
  8. Jun 9, 2021 at 8:51 AM
    Ricos
    Ricardo
    Never stopping ...
    I think because of lifting and (changing the leaf springs by previous owner) the axle came out more from the gearbox and it’s now on the last end.
    so I wonder am I the only one where the axle is out of the gearbox that far.
    I think I need a drive shaft spacer like this :https://youtu.be/-_yy3hUIAwo
  9. Jun 10, 2021 at 7:36 AM
    TechWrench
    Gary
    Hawley, PA
    If it isn't too expensive, I would give it a shot. When you remove the driveshaft, you will be able to tell how much of the yoke is actually inside the tail housing.
  10. Jun 11, 2021 at 10:43 AM
    Ricos
    Ricardo
    Never stopping ...
    Got one made to solve to driveshaft problem and have a new carrier bearing as well
    Danny3737 and 15whtrd like this.
  11. Jun 14, 2021 at 8:51 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    NueveTundra, Danny3737 and 15whtrd like this.
  12. Apr 16, 2022 at 3:40 AM
    Ricos
    Ricardo
    Never stopping ...
  13. Apr 30, 2022 at 1:19 PM
    Tundraroller
    Tundraroller New Member
    Rico’s did you figure it out? I’m having the same issue.
  14. Apr 30, 2022 at 11:02 PM
    Ricos
    Ricardo
    Never stopping ...
    No I did not figure it out yet…
    Wasn’t able to find the part that causes the play on the partscatalog,have to dig deeper into it, what do you experience because of the play ?
  15. May 1, 2022 at 8:15 PM
    Tundraroller
    Thanks for the reply. It’s a buzzing grinding noise, when I increase or decrease the accelerator. It’s starts around 30mph but gets louder the faster I go. It’s brief when it makes the noise, like something is spinning and being moved by the drivetrain when loaded and unloaded by the gas pedal.
  16. May 7, 2022 at 9:23 PM
    apad143
    apad143 New Member
    James
    2008 tundra 2wd
    4” lift
    Mine was all out like yours until i replaced my center support. It went in a little bit but i also have play Like yours if not worst. I couldn’t post a video but i did on a FB group page. I have a 08 crew cab on a 4” lift kit. Have you figured it out???
  17. May 7, 2022 at 11:51 PM
    Ricos
    Ricardo
    Never stopping ...
    No I didn’t figure it out, my centre support bearing is new OEM.
    I have not been able to point out the part that is causing this on the parts catalog, I was hoping someone expierenced this before and points me in the right direction
  18. May 8, 2022 at 11:08 PM
    apad143
    apad143 New Member
    James
    2008 tundra 2wd
    4” lift
    How’d you make it?
