2002 Tundra Illumination lights not working
Discussion in '1st Gen Tundras (2000-2006)' started by Tiltrelia, Jun 5, 2021.
  1. Jun 5, 2021 at 7:17 PM
    Tiltrelia
    Tiltrelia [OP] New Member
    Greetings, I have an 02 Tundra SR5 that currently has 3 interior lights which are not working, these are the fog light switch, dimmer switch, and cigarette ring. All other lights are fully functional, and the bulbs in all of these are good, there is no power at the socket. Anyone know what might be unplugged causing these not to work? All of them should come on together but they don't for whatever reason.
  2. Jun 5, 2021 at 7:54 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Have you checked the fuse to the cigarette socket?
  3. Jun 5, 2021 at 7:57 PM
    I would think blown fuses first. Have you checked them?
    Welcome from NY.
    jerryallday likes this.
  4. Jun 6, 2021 at 7:09 AM
    Tiltrelia
    Yeah I checked the fuse, it’s fine. The actual socket works but the plug going into the light does not output any power, same goes for the fog light switch and the dimmer dial lights. All of the lights in the center console work, and the dimmer does effect them. Just seems weird that all 3 of the lights don’t work, but they are otherwise functional. I should note that they did work at one point, just don’t know why they are out now.
  5. Jun 6, 2021 at 7:12 AM
    common harness for them unplugged?
  6. Jun 6, 2021 at 7:14 AM
    Tiltrelia
    That’s my guess, I just don’t know where it is at for sure. I have a copy of the technical manual with all the electrical diagrams, and the only common point I see is on a connector behind the main dash with all the indicator lights, and I doubt that is where the issue is.
  7. Jun 6, 2021 at 7:24 AM
