I sincerely apologize
Discussion in 'Wheels & Tires' started by Hambone1, Jun 5, 2021.
  1. Jun 5, 2021 at 5:21 PM
    Hambone1
    Hambone1 [OP] New Member
    Blaine
    2015 tundr limited
    Not much yet
    I know I'm going to catch the devil for this but something just doesn't seem right. I bought a 2015 limited a little over a year. While I have been waiting for the tires to wear out I really have been doing my due diligence and reading thread after thread and trying to teach myself. Now my dilemma and lack of knowledge.. .
    Thru custom wheel offset I have my cart full with:
    Falken tow/haul 2.25 shocks.
    Fuel crush wheels and KO2 tires
    My question is they gave me options on what would fit. 20x10s with -18 offset
    and 20x9 with +20 offset..... Aren't these 2 offsets on complete opposite sides of the spectrum?
    Says either could be fitted with 305/55 R20..... Anyone positive this will fit? I have OEM fender flares and want tires flush with them.
    Hate to ask but there is almost too much info on this site to find a definitive answer.
    Which offset would put me where I want to be?
    I am also going to grab a set of 2inch coachbuilder shackles and a set of jba uca's. Thanks so much to whomever decides to answer.
    Leo's first, Black Wolf and Cg13055 like this.
  2. Jun 5, 2021 at 5:32 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    This won’t fully answer your question: I have some +20 Fuels and they stick out about 1/4” to 3/8” on fenders with no flares.
    Cg13055 likes this.
  3. Jun 5, 2021 at 5:35 PM
    Hambone1
    Blaine
    2015 tundr limited
    Not much yet
    What size tires and what size wheels......thanks
    YotaMan likes this.
  4. Jun 5, 2021 at 5:36 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    A good way to find an answer is to search your tire setup, and compare suspensions with what you find. Message the person to see what they did to make them fit, or if they needed to cut anything.
    You’re correct on the offset question, but you should be able to find someone with each setup.
    RobertD likes this.
  5. Jun 5, 2021 at 5:37 PM
    fireman02
    fireman02 New Member
    20 SR5
    Pretty sure you want the +20 offset wheels. The -18 push the wheels out quite a bit. I had +25 offset on my last Tundra, & will most likely going that route again, and I thought it put the wheels perfect. I’m not a fan of the minus off set look, but to each his own.
    Black Wolf likes this.
  6. Jun 5, 2021 at 5:39 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    With flares go with the -18.. but all depends on what kinda look your going for
    OEM is positive 60 I believe, I have positive 20 and they stick out about an inch to an inch and a half. The lower the number, the further they go
    Tires .. I currently run a 295/60r20 (34.5x11)
    I have no rub with 3 inch Toytec coilovers for the front and coachbuilders in the back (2 inch with extended shocks)
    Black Wolf and BlueRibbon4x4 like this.
  7. Jun 5, 2021 at 5:44 PM
    Hambone1
    Blaine
    2015 tundr limited
    Not much yet
    Dang..... See my dilemma of searching and reading forums. Already 2 different answers. And I can promise I have just about read every thread covering this subject...... Just don't want to order everything and it get here wrong
  8. Jun 5, 2021 at 5:45 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Forgot to add, my wheels are +18
    Also, you can fit 33's stock
  9. Jun 5, 2021 at 5:46 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    All ya gotta do is ask pimpin :cool:
    Lot's of knowledge here
    BlueRibbon4x4 likes this.
  10. Jun 5, 2021 at 5:48 PM
    Hambone1
    Blaine
    2015 tundr limited
    Not much yet
    Thanks brother man
    YotaMan likes this.
  11. Jun 5, 2021 at 5:49 PM
    Crunch527
    Iowa
    20” x 9 with 275/60/20.
  12. Jun 5, 2021 at 5:51 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Also 20x9 vs 20x10 don't make a damn .. it's the tire you mount it on
    Any tire will perfectly accept these rims
  13. Jun 5, 2021 at 5:54 PM
    Hambone1
    Blaine
    2015 tundr limited
    Not much yet
    That's what I figured. Just wondering why a positive offset on one and a negative on the other.
  14. Jun 5, 2021 at 5:58 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    2 different options, different strokes for different folks. -18 will be way out. +20 will be about 40mm out past stock wheels.
    Plug your numbers in here for a visual...but don't go -18 unless you have or want an ultra aggressive looking truck and the hardware to back it up. These are my +10 on 8.5" wheels with Fallen Wildpeaks. I would have preferred +25 or +35, but couldn't find wheels I liked in that offset.
    Fronts stick out slightly more than rear.
    Bob_Wiley and Black Wolf like this.
  15. Jun 5, 2021 at 6:07 PM
    Hambone1
    Blaine
    2015 tundr limited
    Not much yet
    Great info. Thanks
  16. Jun 6, 2021 at 2:15 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Wheel width absolutely makes a difference as to where the outside of the wheel/tire will end up for a given offset.
    A 20"x10" wheel will stick out 12.7mm more than a 20"x9" wheel with the same offset.
    Wheel fitment is one of the most challenging things to figure out. Luckily the Tundra hasn't changed for a long, long time, and plenty of folks have figured out what works on these trucks. A 9" wide wheel with a +25 to +18 offset is the sweet spot for these trucks.
    With the tire size the OP mentioned the 20x10 -18 wheels would be nearly two inches further out than the 20x9 +20 wheels.
    The +20 wheels would already be pretty flush with a truck with fender flares. The -18 setup would put you really wide and much further outside the fender flares.
    This is a 9" wide +25 offset wheel with 275/70 tires. A 10" wide wheel with a -18 offset and the same tires would be sticking another 55mm further outboard. Not ideal unless that's the look you're going for.
    BravoDeltaRomeo likes this.
  17. Jun 6, 2021 at 2:32 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    To give you another visual, I’m running 35x12.5r18 Nitto Trail Grapplers on 18x9 Method MR 306 rims with +18 offset on an Icon stage 6 3” lift. Had to do a body mount chop to get it to fit.
    Unless you’re really wanting your tires to stick out, +18 to +25 is generally the sweet spot for the Tundra. Best thing to do is cruise the thread below and just look at other setups to find the one you like best.
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/
  18. Jun 6, 2021 at 5:40 AM
    joey2018
    joey2018 New Member
    I have +1 on mine. In hind sight I would have gone +18 to +20. The +1 stick out just a little too much. Here's mine with Fule 20x9 and 305-55-20 Toyo AT3'sTruck back.jpg Truck Side.jpg
  19. Jun 6, 2021 at 5:48 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    ^^^^This will be my next size tire. I also have the Falcon tow haul. Currently running 33's till warranty expired. Will do what it takes to fit 35's.
  20. Jun 6, 2021 at 6:50 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    If you want flush you'll want the +20. Stock wheels with spidertrax wheel spacers equals out to roughly a +26 offset and pokes out of the fenders some with no flares.
  21. Jun 6, 2021 at 6:25 PM
    Hambone1
    Blaine
    2015 tundr limited
    Not much yet
    Thanks for all the help. Ordered everything today......will post a pic when it is all installed
  22. Jun 6, 2021 at 6:41 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I have (will be posting to sell soon) some fuel vapor 20 x10 rims -18 offset. With the 285/50r20 tires I had almost 3 inches of poke. So yeah, unless you want a really aggressive look you're better off with the neutral or slightly positive offset. But damn did they look good :D.
