Can I get away with 305/70R18 BF Goodrich KO2s WITHOUT changing to 0/25 offset wheels?
Discussion in 'Wheels & Tires' started by Tundra18overland, Jun 5, 2021.
  1. Jun 5, 2021 at 11:42 AM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Hi everyone,
    I know this question gets asked a million times a day, but I am looking for some input.
    I am wanting to upgrade to 35” tires from 33s. My current set up is four Bilstein 5100s with the fronts on top settings (approx. 2.3” of lift) and factory wheels with +50-60mm offset. I am currently running 33x12.5x18 M/Ts. I am having an ARB Summit bumper installed on the front which I know will pull my front end down some. (i am upgrading my coils later to heavy duty ones)
    I know the upgraded bumper will give me some leeway, but I know that ideally I need upgrade my wheels to wheels with offset from 0 to +25 to prevent rub on my cab/body mount, especially if i wanting to run true 35s. I am leaning more towards +25 because I think the 0 offset wheels will stick out further than my liking.
    I am fine with either 17 or 18” wheels but would like to run 17s.
    My question is do you think I can get away with running a 305/70R18 BF Goodrich KO2s WITHOUT changing to 0/25 offset wheels AND run them WITHOUT rubbing? They have a diameter of 34.8" and a width of 12.2"
    All input is appreciated! TIA!
  2. Jun 5, 2021 at 11:55 AM
    woodlandFF
    woodlandFF New Member
    2019 SR5 Cement Tundra CrewMax 4x4
    Black Rhino 20s
    Yes, with a BMC
  3. Jun 5, 2021 at 11:57 AM
    Tundra18overland
    Jesse
    GA
    Do you think new wheels with proper offset, I could avoid a bmc?
  4. Jun 5, 2021 at 12:09 PM
    Tundra18overland
    Jesse
    GA
    Also considering Toyo AT3 (295/70/R18s)
    34.3” and 11.8” wide, but I don’t want to lose that much width.
  5. Jun 5, 2021 at 1:10 PM
    woodlandFF
    Black Rhino 20s
    The wheels and tires and suspension stickies should have all your answers
  6. Jun 5, 2021 at 1:20 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The wider wheels put the tire closer to the body mount vs oe wheels
