Help! Truck killed itself!
Discussion in '2nd Gen Tundras (2007-2013)' started by joseph_womack, Jun 4, 2021.
  1. Jun 4, 2021 at 10:26 PM
    joseph_womack
    joseph_womack [OP] @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    2007 Tundra, 4.7L V8
    Got home, turned truck off, went back out to truck hours later, started truck but didn’t move it (sat stationary while wiring), about 30 minutes in, makes noise (like continuing to turn the key after car has started) and dies (fights to stay on, odo lights flicker and truck shuts off), start truck immediately, same thing…
    Get out, check oil, coolant, battery (remove fuse tap that increases alternator voltage) all good, give it a second and look over everything, start it again but immediately shift into reverse and drive backwards, then forwards, neutral then rev to 3000, sounds fine
    Did it die because it didn’t move after being started? Oil not circulating?
  2. Jun 4, 2021 at 10:32 PM
    joseph_womack
    Joe
    Louisiana
    Just turned it on to check alternator, made the noise again, I killed the truck
  3. Jun 4, 2021 at 10:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Aftermarket remote start by chance?
    joseph_womack[OP] likes this.
  4. Jun 4, 2021 at 10:37 PM
    joseph_womack
    Joe
    Louisiana
    Nope, base model
  5. Jun 4, 2021 at 10:39 PM
    empty_lord
    05 rollover special
    What were you wiring while it sat? Sounds like an electrical gremlin is the issue.
    you could leave the truck idle for a week and do no damage.
  6. Jun 4, 2021 at 10:41 PM
    joseph_womack
    Joe
    Louisiana
    Dash camera and radar detector, had the a pillar off and was running wires next to the airbag wires in the pillar (dash cam and radar didn’t have power run to it) probably shoulda have been doing that with the truck off and battery disconnected
  7. Jun 4, 2021 at 10:44 PM
    empty_lord
    05 rollover special
    Did you use add a fuses by chance and remove any fuses with the truck running? Honestly I’d disconnect the battery for a bit and then reconnect it to let the truck “reset”. You will want to clean the throttle body though because it will lose its idle learn and idle a bit rough for a bit if not
  8. Jun 4, 2021 at 10:48 PM
    joseph_womack
    Joe
    Louisiana
    Nope, had not gotten to that stage yet, I think I may have a potential issue though, I might have grounded the battery to a bracket I made, moved the bracket, testing now
    JimboSlice413 likes this.
  9. Jun 4, 2021 at 10:50 PM
    joseph_womack
    Joe
    Louisiana
    Just got a sound clip, right after it idles down, it kills the truck
  10. Jun 4, 2021 at 10:58 PM
    empty_lord
    05 rollover special
    For the hell of it pull intake tube off the throttle and clean it out if you have brake clean or throttle cleaner handy. Doubt it’s the issue. But it might be by the way it sounds
  11. Jun 4, 2021 at 11:01 PM
    joseph_womack
    Joe
    Louisiana
    Will do in the morning, disconnected both positive and negative terminals for the night, sound clip is uploading
    while I was sitting in the truck, I could feel it idle up and down a lot (if that makes any difference)
  12. Jun 4, 2021 at 11:02 PM
    joseph_womack
    Joe
    Louisiana
  13. Jun 4, 2021 at 11:13 PM
    empty_lord
    05 rollover special
  14. Jun 5, 2021 at 6:09 AM
    joseph_womack
    Joe
    Louisiana
    Yeah that’s what makes me confused, I’m gonna pull the starter relay and see if it engages, only problem is it dies so quickly
  15. Jun 5, 2021 at 6:39 AM
    empty_lord
    05 rollover special
    You didn’t play with anything around the ignition switch right?
  16. Jun 5, 2021 at 6:48 AM
    15whtrd
    15whtrd Mr. Blonde
    Definitely sounds like the starter re-engaged and killed it.
    Filthyphil and joseph_womack[OP] like this.
  17. Jun 5, 2021 at 6:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Go over everything you touched while wiring. My bet, you grounded something out. You could’ve fried something. And it may not be located right where you were working but down in the loom somewhere. Maybe a wire up against something metal is now cooked and shorting out.
  18. Jun 5, 2021 at 6:57 AM
    joseph_womack
    Joe
    Louisiana
    Idling fine this morning, I also pulled the wires away from the a-pillar that I ran incase there was interference, granted it’s still idling high because it’s cold, pulled the starter relay while running and didn’t die, did hesitate though, reversed then put it in park, died when shifted to park but just acted as if the battery died, not the starter engaging
  19. Jun 5, 2021 at 7:21 AM
    joseph_womack
    Joe
    Louisiana
    Nope, did not
  20. Jun 15, 2021 at 3:41 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    check the main relay could be having issues with that. also for shits grins a giggle's check voltage of battery while off an on to confirm its charging also give the battery posts an cable connectors a clean. also what fuse slots did you use for piggy back fusing for item?
    unrelated but some contexts to things while putting rain guards in a vehicle I had a OEM battery take shit on me (4 of 6 cells died) an it was like the car was possessed.
  21. Jun 15, 2021 at 7:40 PM
    joseph_womack
    Joe
    Louisiana
    I did check the starter relay, not that, posts and terminals are good, battery is charging...
    I got rid of the resistor in the alternator sense circuit so that could've helped the problem, I also noticed that my air filter (CAI) had slipped off the tube, so my thinking is that, when it idles down, sucking too much air and could be confusing the truck then it kills because the map is getting confused (just like if the map isn't plugged in) I taped into the ignition fuse to activate and deactivate the aftermarket fuseblock, that was after the problem started and I don't believe its causing any issues
    all in all, the problem happened that Friday night, once Saturday morning, then once again the Thursday of that week. After that not once, its been driven 3 hours straight and no problems, I think it was the air filter being off to be honest
  22. Jun 15, 2021 at 7:58 PM
    empty_lord
    05 rollover special
    Oh yea. Air filter popped off? That’s it. Throws the mad readings off and basically the engines “lost” on how much it needs to fuel etc
  23. Jun 16, 2021 at 5:58 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Saw a YouTube video where a guy got towed from the middle of nowhere to have the dealer put his intake tube back on. ‘‘Twas even a tundra.
  24. Jun 16, 2021 at 9:47 AM
    joseph_womack
    Joe
    Louisiana
    sweet, that makes me feel a lot better, I figured that could've been the main issue, I was gonna test it and let it idle and pop the filter off and see what happens, still might but thank y'all for the input
