DIY Spare tire carrier
Discussion in 'Sequoia Builds' started by farnsrocket, May 28, 2021.
  1. May 28, 2021 at 5:08 AM
    farnsrocket
    farnsrocket [OP] New Member
    Not spending the money on a Wilco carrier. Saw some threads and videos about making this one and made a few changes to it. The main reason I did this was to keep my 5th wheel/tire from getting all jacked up underneath the truck. Thought I could do it all without welding but ended up having my buddy weld the connector since it wiggled too much. Everything else worked out good. I have less than $200 in to it. I may try to get it a little closer to the hatch and drill another hole in the hitch part. Thought about a spring to help it raise back up, it’s not bad but my wife can’t get it back up.
    S. Equoia likes this.
  2. May 28, 2021 at 5:10 AM
    farnsrocket
  3. May 28, 2021 at 5:56 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Cool! That’s a workout every time y’all need to open the back. Lucky you’re tires are not that big.
  4. May 28, 2021 at 6:00 AM
    Looks good!
    farnsrocket[OP] likes this.
  5. May 28, 2021 at 6:36 AM
    UtahBlues
    UtahBlues New Member
    Jon
    Park City, Utah
    2012 Sequoia SR5
    Good job! I like those wheels
  6. May 28, 2021 at 6:46 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Nice job!
  7. May 28, 2021 at 2:20 PM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    Wicked job, thanks for sharing!
  8. May 28, 2021 at 2:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Love the way it turned out! Just a thought, why not carry your stock spare rim and comparable size spare tire under the truck for daily use? Then when you go on an adventure where you need your fifth tire, you put your carrier on. That way you’re not working around it constantly.
    831Tun and farnsrocket[OP] like this.
  9. May 28, 2021 at 2:33 PM
    farnsrocket
    Thanks man! That’s not a bad idea!
    15whtrd[QUOTED] likes this.
  10. May 28, 2021 at 2:34 PM
    farnsrocket
    Managed to get it 2” closer to the bumper/hatch! Looks better! :cheers:
    Velocity72, S. Equoia and 15whtrd like this.
  11. May 28, 2021 at 3:16 PM
    Great work.:thumbsup:
  12. Jun 4, 2021 at 7:13 AM
    farnsrocket
    Put another clevis pin in to block the tube as the tire is on its way down so now it won't go all the way down. My kid can put it back now!
  13. Apr 23, 2025 at 2:46 PM
    20Seqouia02
    20Seqouia02 New Member
    Erik
    2002 Toyota Sequoia SR5 4x4
    Too many to list
    Do you have a parts list? I would love to make something like this for my Sequoia.
  14. Apr 24, 2025 at 7:31 AM
    farnsrocket
    This is the spare tire carrier I used.......I think I got it for $90 at the time.
    https://www.amazon.com/dp/B0009YIE1O
    If you can weld, you could weld up your own Curt type mount with 2x2 tubing and a metal plate to mount the wheel spacer to.
    I used this from Harbor Freight I used the actual hitch piece from an old bike carrier but you could use the piece you cut off from the Curt one. And I had some extra 2”x2” tubing I used fit the bottom half of my carrier.
    I ordered 2 of these:
    https://a.co/d/hrwGYPY
    My bolts holding it together are 1/2” stainless and the pivot bolt is a 5/8” Grade 8. I put some thin nylon washers between the plates and bar where the 5/8” bolt is to help it rotate smoothly.
    These are the 2 wheel spacers I bought
    ECCPP 2X 1 inch 5 Lug Wheel Spacers 5x150mm to 5x150mm 14x1.5 Fits for Lexus LX470 LX570 for Toyota Tundra Sequoia Land Cruiser Amazon.com: ECCPP 2X 1 inch 5 Lug Wheel Spacers 5x150mm to 5x150mm 14x1.5 Fits for Lexus LX470 LX570 for Toyota Tundra Sequoia Land Cruiser: Automotive -
    Got this at Tractor Supply for about $6
    2 PCS Red Handle Hitch Pin 5/8 Inch Tractor Hitch Pin Clevis pin Hitch Pin Accessories for Tractors 5/8X5-1/2 https://www.amazon.com/dp/B082ZK6XDR
    Just a side note, Napa has bolts, nuts and washers way cheaper than anywhere else!
    And use one of these to keep it locked on the hitch, no rattles or moving:
    https://a.co/d/gnYHqqo
    License plate light:
    https://www.amazon.com/dp/B07937BQYJ
    I bought an extra trailer wiring harness and wired it to this light so I just plug it in to the trailer wiring.
    License plate cover:
    https://a.co/d/0D0uETT
    Watch this video, it was my inspiration:
    Folding Tire Hitch Carrier Build + License Plate / Hi-Lift Mounts - S2E49 -
    And here’s a couple of threads about it:
    https://www.subaruxvforum.com/threads/diy-spare-tire-carrier-cheap.176165/
    https://www.overlandbound.com/forum...swing-down-hitch-mount-spare-tire-rack.15415/
  15. Apr 24, 2025 at 7:37 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    Is that for looks? I'm confused. You've basically blocked off your trunk doot. Tires on the rear door are usually installed on the hinge that can be swung out of the way when opening the door. Another way tire is mounted on the door is if whole door siwngs horizontally to the side. Our Suzuki was that way.
    Just FYI, you do have a wheel under the truck. Look underneath.
  16. Apr 24, 2025 at 8:10 AM
    farnsrocket
    Did you even read my first post at all?
    "The main reason I did this was to keep my 5th wheel/tire from getting all jacked up underneath the truck."
    Have you ever seen a spare tire after its been under a truck for a few years? It looks like a ship wreck, covered in road grit and the tire itself gets indentations from being pressed into the frame. I rotate my spare in with my other wheels so I wanted it to stay in good shape.
    And I didn't block off my trunk doot, whatever that is :confused:, I assume you meant hatch door. The tires swings down out of the way and I can open the hatch.
    AZTundra likes this.
  17. Apr 24, 2025 at 8:29 AM
    EmergencyMaximum
    If you rotate it on a regular basis, it's doesn't look bad. If you haven't used it in five years, then yes, it'll get a little nasty. Having the tire sitting like that all the time in the same spot will wear out pretty quick from uv.
    Doot=door. I do not agree this is the way. Keep it tucked away underneath and just loosen it up and wash off once a month. You can rotate it to prevent indentation if that's what you're worried about. Or maybe just add soft shims where tire meets frame. This looks to me the wrong way to do it what you are doing there.
  18. Apr 24, 2025 at 8:50 AM
    farnsrocket
    Nope, I treat it with protectant, its no worse off being exposed to UV than any of my other tires.
    I am not going under there once a month to take it down and wash it and rotate it.....that's ridiculous. And I am not messing with shims.
    On top of all of that, it's a 34" tire, it doesn't fit in my spare tire area anyways, so this is exactly and the only way to do it. :D
    Shanet421 likes this.
  19. Apr 24, 2025 at 9:23 AM
    EmergencyMaximum
    Well, that changes everything!:fistbump:
    Adding: I'd just go with those prius spares if that would work. To save weight, just to limp it home in case unfortunate happens. Or some plastic 'lego' inflatable type stuff you could store in your glove compartment.
  20. Apr 24, 2025 at 9:49 AM
    farnsrocket
    Sound advice.
